04-23-2012, 03:30 PM | #1 |
Rep 159
Strut tower reinforcements
Has anyone installed the e46 strut tower reinforcements in their car? I have seen a thread with them installed, so I know they will fit, but not sure if they are a good idea or not. There was a post by Randy about how he thought it was a bad idea, but no explanation beyond that. Interested in putting them in with a new suspension as peace of mind, since the towers look flimsy to begin with, and the roads I drive on are far from smooth.
04-23-2012, 04:55 PM | #2 |
Rep 11,667
I have them, IMO, If you're running coilovers its a good idea.
Most coilovers have a smaller surface area at the top plate & usually stiffer springs. That leads to more mechanical loading stress in that area. I haven't seen any failed Z4 towers reported but for the cost they're cheap insurance.
04-23-2012, 09:01 PM | #3 |
Rep 398
It is incredible how some of these M cars have such failures especially the e46 with the rear sub-frame and shock towers and our Z4's with the sway bar and possibly shock tower.
I understand it stems from going beyond intended street use, but... Any who, got them on order now.
BSM Z4M Coupe
04-23-2012, 09:50 PM | #4 |
Rep 12,565
Part numbers?
04-23-2012, 10:29 PM | #5 |
Rep 159
Here's link to only other thread I could find that was z4 specific, includes part numbers:
http://www.bimmerfest.com/forums/sho...d.php?t=346508 |
04-24-2012, 05:23 AM | #6 |
Rep 11,667
Rogue eng has them (OE part)
The E46 plates fit. http://www.rogueengineering.com/rogue/REIN/REINFT.html
04-24-2012, 07:20 AM | #7 | |
Rep 12,565
04-24-2012, 09:11 AM | #8 |
Rep 11,667
They will help, but I wouldn't say it's the same.
I really liked the idea of the combination of a full plate underneath & the STB mount on top. & for only $25 it made sense to me. One thing to watch out for is the length of the studs on your coilovers. My Clubsports were fine, but I was helping a friend with GC coilovers & the studs weren't long enough for the added plate thickness.
04-24-2012, 10:59 AM | #9 | |
Rep 12,565
04-24-2012, 11:56 AM | #10 |
Rep 11,667
if you have about 3 threads showing at the nut now, you should be OK
04-26-2012, 03:51 PM | #11 |
Rep 541
Drives: 2022 X3MC
Just purchases the re racebrace today and figured I might as well get the strut tower reinfor plates.
What are the torque specs with strut bar? 35nm?
'00 328i // Sold
'04 Z4 3.0i // Sold '22 X3MC LCI |
04-26-2012, 04:10 PM | #12 |
Rep 5,328
imo these are must if you got coilovers, they are really thick pieces of metal, dont be fooled by the pics, they are thick and will add significant "load" spreading... with these in place ill be happily running along with my clubsports without a worry..... cheap insurance for sure, added with the SB uptop i think you simply protecting your car.... They are heavy plates however....
04-26-2012, 10:21 PM | #13 |
Rep 12,565
I called Vorshlag and was told unfortunately these would not work with their camber plates, oh well...
04-27-2012, 06:07 AM | #14 |
Rep 5,328
why??? its only a case of them adding a very slightly longer bolt??? lazy bastards.
04-27-2012, 11:05 AM | #15 |
Rep 12,565
Nah, it's b/c of the rounded lip of the oe reinforcement plates limit the camber adjustment. But reading up on m3forum, turns out I can just cut out some notches so the plates have more play. Going to go that route...
04-27-2012, 11:49 AM | #16 |
703
04-27-2012, 06:39 PM | #17 | |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM Last edited by Caddyshk; 04-27-2012 at 06:40 PM.. Reason: add |
04-28-2012, 04:22 PM | #18 |
Rep 12,565
What's wrong with the oe bar?
Btw -installed the oem reinforcement plates today. I asked Ben at Rogue to trim off the curved lip of the plates that way camber could be adjusted freely. Pix of how it looks installed: |
04-28-2012, 04:24 PM | #19 | |
Rep 4,531
How do you like your Vorshlag Plates? Range of adjustment good and easy to do? |
04-28-2012, 04:39 PM | #20 | |
Rep 12,565
PS - when I left it there for the first day or two, the contact from adjuster & strut tower caused a squeaking noise so that's why I brought it in. |
04-28-2012, 04:58 PM | #21 |
M = Midlife Crisis
65
Rep 2,006
Not enough stud left on the GC's once the bar is installed.
04-28-2012, 05:13 PM | #22 |
Rep 12,565
Can you you ask GC to send you longer studs?
