      04-23-2008, 07:11 AM   #1
freeman
Drives: 06 M roadster
Arrow SS brake lines for M Z4?
I plan to upgrade my stock rubber brake lines to SS lines.
I am not sure if we have the same brake lines on M Z4 as
E46 M3 with competition pkg or M3 CSL. They all should
have the same brake systems ,but i am not sure about the
brake lines.
Can anyone confirm this?
      04-23-2008, 08:44 AM   #2
MMMazing07
MMMazing07's Avatar
181
Drives: Z4M
get stoptech stainless steel brake lines. Top notch stuff. They have a set for the Z4M so you dont have to worry about fitment.
      04-23-2008, 01:14 PM   #3
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
I have Stoptech lines on my car. They fit like a champ.
You have to be 100% behind someone before you can stab them in the back.
David Brent
      04-23-2008, 01:29 PM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^+1
Zeckhausen
      04-23-2008, 05:11 PM   #5
freeman
Thanks for the info!
That is exactly i need to know.
Is your brake pedal noticeably firmer after installing the SS line and racing brake fluid change?
      04-23-2008, 05:34 PM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
There is, but TBH, for normal street use it's not a huge difference.
On the track, when things heat up (fluid especially) there's a definite difference.
      04-24-2008, 08:30 AM   #7
RussRamz
M Slut
RussRamz's Avatar
No, it won't make your pedal feel more firm. The difference will be a more consistent pedal feel after the brakes and fluid get hot. If you don't track the car, I wouldn't recommend messing with the brakes.
David Brent
      05-08-2008, 07:32 PM   #8
freeman
Yes. Consistent pedal feel at high operating temperature is the goal i am trying to achieve. I only use my car for track days and weekend mountain sprint , since i got a new Sti as DD now
PS: I just installed my StopTech SS lines,and replaced old brake fluid with ATE Superblue this morning. My clutch and brake pedals actually felt smoother for street
driving.
      05-20-2010, 10:22 AM   #9
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
bumping an old one....
Does anyone if a complete 6 line set is available for the Z4M ???
UUC makes them for other models but nothing listed for Z4M.
      05-27-2010, 08:09 PM   #10
RBull
Drives: 2007 M Coupe
Go here for a response to your question.
http://www.zpost.com/forums/showthread.php?t=388351
post #10
      05-27-2010, 09:55 PM   #11
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^thanks
      12-02-2010, 03:36 AM   #12
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
I ordered off the part #'s that Zeckhaussen listed, but only got 4-piece line kit? What's the 5th and 6th line for? Anyone have the part #'s to these?
      12-02-2010, 10:00 AM   #13
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
4 line kit is correct.
follow the link in RBull's post.
      12-02-2010, 12:50 PM   #14
The HACK
The HACK's Avatar
1821
UUC kit is 6 lines. There are two separate "soft lines" in the rear.
      12-02-2010, 02:40 PM   #15
mfanatic325
///M-fanatic
Taiwan
193
Hmm...are there any part #'s for these two "soft" lines for the rear? I can't find the Z4M kit on UUC's web site.
      12-02-2010, 03:06 PM   #16
The HACK
The HACK's Avatar
1821
http://www.realoem.com/bmw/showparts...00&hg=34&fg=17
Parts 5 & 11 are the "soft" lines, although part 5 has a partial hard line and then a soft rubber line.
Call UUC for the MZ4 lines. I don't think they list it on the website because, well, there's really only limited application for it. If you want it, I can sell you mine (although one of the rear lines has a small scuff on it and a little bit of the outer layer was worn away from the scuff).
      12-02-2010, 03:42 PM   #17
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
I got mine from turner...itching to put mine on when it gets warmer...
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      12-02-2010, 05:07 PM   #18
mfanatic325
///M-fanatic
Taiwan
193
I ordered through JSW, using these part #'s from Zeckhaussen:
F- 950.34001
R- 950.34523
But those #'s only came with 4 total lines. I need the #'s for the extra 2 lines for the rear setup?
Hack, what do you mean by parts 5 and 11? I'm totally confused...
I was wondering about StopTech part #'s?
      12-02-2010, 08:06 PM   #19
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Stoptech replaces the 2 soft plus the intermediate hard with one longer line.
It eliminates all the extra fittings
      12-02-2010, 08:17 PM   #20
mfanatic325
///M-fanatic
Taiwan
193
ohhhh I see, so it's correct that I got 4 total. Okay, gotcha. Thanks!
      12-02-2010, 08:26 PM   #21
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Yes.
The OLD Stoptechs used to only replace the one soft line at the caliper.
The NEW Stoptechs replace all three with one long line.
The new rear line should measure ~26"
      12-02-2010, 08:39 PM   #22
mfanatic325
///M-fanatic
Taiwan
193
Yes.
I will double-check the package contents later tonight, thanks Ian
