      09-20-2011, 07:55 PM   #23
EMP07
EMP07's Avatar
37
Drives: Z4M
I'm at what would amount to be 1.25? or 6 clicks from soft.
This is mostly a daily driver first so I'm dialing for that and then figure out the delta for the track.
      06-01-2012, 12:36 PM   #24
tikamak
Lebanon
58
Originally Posted by beta View Post
No worries f1soul! Please post away. What did you set your rebound to and how do you like it? the recommended is 0.75 i think. Also let us know what your camber ends up at once you get it aligned.
can someone pleaaaaaase explain to me how the hell is the damn bump/compression dialed ? and what the hell is 0.75 open turns.
WTH is this shit, i don't understand anything, the instructions are mixing up the metrics big time or i am becoming extremely stupid due to working so hard all day long :S
anyone ? KW V3 owners ???
      06-01-2012, 12:51 PM   #25
tikamak
Lebanon
58
is 0.75 open turn mean almost full hard and you need to move the tool provided 0.75 times the area allowed in the rear ?
or does 0.75 turn mean 3 times 90 degree turns ? means 270 degrees (360 degress being a full turn )
      06-01-2012, 03:31 PM   #26
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
Your second example is the correct interpretation. 0.75 = 3 times 90 degree turns.
