01-10-2016, 06:48 PM | #1 |
Rep 2,705
Brake Pad Wear Sensors
Are they necessary to be installed?
Will I get a brake warning light if not installed? I do my own maintenance and so check pads as routine each year end.
01-10-2016, 06:54 PM | #2 |
Rep 11,668
I have mine still plugged in to the harness & coiled up.
You should be ok to completely remove though. They work by shorting between the 2 wires, so as long as there is an open cct you should be good.
01-10-2016, 06:57 PM | #3 |
Rep 2,705
Thanks Ian
01-13-2016, 04:48 AM | #4 |
Get Some
226
Rep 759
Drives: 07 Z4 3.0si
They constantly slip out on my stoptech bbk, so I just zip tied them out of the way. As long as you check your brake wear often enough, shouldn't be an issue imo
