05-02-2018, 07:01 AM | #1 |
Rep 2,476
Drives: Satan's Chariot 2.0
Tired of my desktop lagging
This just randomly started recently & won't go away. It sometimes lags so bad that whatever audio or video I have playing is unlistenable. It doesn't just lag when audio/video is played FYI.
I've run defrag, turned off Adobe & Anti-virus & nothing made a dent. I changed no settings & did not install anything new right before this started either. Windows 10. What gives? |
05-02-2018, 07:13 AM | #3 | |
Rep 2,476
EDIT: Just ran CCleaner & no change. Last edited by Never_Enough; 05-02-2018 at 07:23 AM.. |
05-02-2018, 08:27 AM | #7 |
Rep 2,476
05-02-2018, 08:28 AM | #8 |
Rep 2,476
05-02-2018, 08:35 AM | #9 |
Rep 280
05-02-2018, 08:36 AM | #10 |
Rep 1,929
05-02-2018, 08:37 AM | #11 |
Rep 4,136
If you are playing saved media files, then most likely hard drive is starting to fail. Although those specs are pretty shitty. I run an i7,8gb ram, SSD and have no problems. Those are my specs in a laptop, so for a desktop to have those specs, you can upgrade for cheap and make a powerhouse. Buy a SSD it will change your life
05-02-2018, 08:44 AM | #14 |
Rep 2,476
05-02-2018, 08:47 AM | #15 |
Rep 1,965
For a work PC I'm actually surprised he was able to run some of the warez he has. We are locked out of everything, especially installing without admin approval. If it's a larger company seemed like a no-brainer.
Also...."Have you tried turning it off and on again?" |
MightyMouseTech4341.50 |
05-02-2018, 08:49 AM | #16 | |
Rep 4,136
Exactly what I was thinking. I can't do anything on my comp besides whats already on it...let alone run a virus scan |
King Rudi13065.50 |
05-02-2018, 09:08 AM | #17 | |
Rep 4,365
My suggestion was going to be to get a mac... the specs still run pretty fast on the iOS system (my 2011 Air has much worse and still runs ok - Those are similar specs to my newer MBP) Sucks that this is with a work computer. Fighting IT to get replacements or upgrades is way harder than it should be... as they should be computer people and realize how much more productive you can be with a good machine. Thankfully my company recognizes this and just upgraded (most of) the company to new Lenovo Carbon X1 and Dual/Triple 24" Monitors. i7-6600 and 16GB of ram. Much more similar weight/speed compared to apple that I contemplated actually buying a Carbon for my personal computer instead of the new MBP I got. Having said all that... I have no suggestions for you aside from bribing your IT/Facilities for a newer machine.
2007 Z4 3.0si Coupe 6 MT Black Saphire Metallic PP SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide Denim Black V&H Tune 2021 BMW x30i Phytonic Blue Metallic Fully loaded |
King Rudi13065.50 |
05-02-2018, 09:13 AM | #18 |
Rep 348
Ccleaner & Malwarebytes as a combo worked wonders for every single computer I've ever used. Run them every couple months and it should be smooth sailing. However, sometimes when computers go on a while, they start to accumulate many conflicting registry files. You may need to clean registry too but this part is a pain, many people just resort to reformat at this point. Finally, it may be hardware related, have you ran a hard drive test? Defraging the HD may help.
05-02-2018, 09:16 AM | #19 |
Rep 2,335
As an end user their isnt much you can do, I would just contact IT and tell them whats going on.
There's also a possibility the lags are due to something IT may be running behind the scenes i.e updates, scans or any type of patch management. |
05-02-2018, 09:34 AM | #20 | |
Rep 2,476
05-02-2018, 10:24 AM | #22 |
Bergspyder
1553
Rep 1,239
OOOPPPPS spilled my coffee into it....(kidding)
Never_Enough2216.50 |
