      06-07-2021, 12:51 PM   #1
sknobs
sknobs's Avatar
23
Drives: 2016 F82 SO/Extended Black 200
New Keyfob?
I would like to replace the old keys as the batteries are not holding a charge any more. All I see is a EWS 315mhz and EWS 433mhz.
What key would work?
It is an E85 Z4M.
      06-09-2021, 07:12 AM   #2
rsutoratosu
Drives: Z4 3.0i
I think its the 315 one.. you can buy blanks off ali and use ak90+ to program it.. or lock smith with similar tools. I got the blade folding type.
My aliexpress history got purged, its something like this you can switch to.. ill look when I get off work again..
https://www.aliexpress.com/item/32842898049.html
-Roranji
      06-16-2021, 08:08 AM   #3
GyroF-16
GyroF-16's Avatar
15
Drives: Z4 M Coupe
New keys are $170 here.
https://www.thebmwminipartstore.com/...86-66126955748
I just got one to replace a key for my E46 from there. (Same type key).
      06-22-2021, 08:33 AM   #4
sknobs
sknobs's Avatar
23
Picked up 2 folding keys and sent them to a locksmith to get cut. $50 locksmith, $50 for the 2 keys and $30 for the programmer. $130 for 2 keys vs dealership $220 per key.
      06-24-2021, 09:26 AM   #5
rsutoratosu
Drives: Z4 3.0i
Yup.. dealers are ripoff..
-Roranji
      06-25-2021, 04:21 PM   #6
fcar807
fcar807's Avatar
Drives: BMW Z4 Coupe E86
if you got original key already you just need to get them cut and you should be able to pair both keys yourself and for engine start,
I managed to get one done as a spare not upgrade as you like, but followed this guide worked perfect.
https://store.bimmernav.com/blogs/ho...5-e46-x3-z4-z8
      06-26-2021, 01:33 PM   #7
sknobs
sknobs's Avatar
23
Did you get your key from BMW? All the locksmiths that I asked said you need to use the AK90+ to program any new cut key. I thought that process only worked if you get the key cut from BMW with your VIN programmed into it.
      06-29-2021, 04:59 AM   #8
fcar807
fcar807's Avatar
I got my key from ebay, hopefully a decent one.
I then paired it to open the doors with buttons,
then went and got it cut, at a small local locksmith £25
then i tried to open the door worked fine,
but no ignition obviously not paired.
I then followed the guide i linked above, and put my original in ignition turned it to position 1 i think and then put new key and it turned over now a working spare.
I was warned not to play with pairing my own keys as i could lock my car out somehow but i followed above and worked for me.
good guide, but scary part is pairing it to start engine when i tried to turn it was a bit stiffer but after it sync with alarm its fine now as a spare key.
had to follow guide exactly.
dont try if your worried about getting car locked out, your need bmw to sort that i heard.
      06-29-2021, 05:00 AM   #9
fcar807
fcar807's Avatar
you need a working key that currently opens doors and starts to do this procedure,
i was quoted £145 cheapest so tried it myself.
      08-01-2021, 03:55 AM   #10
fcar807
fcar807's Avatar
No went to a small local locksmith, he kept saying same thing tell him you only want it for opening the doors in case you lock your good one out is what I said and he cut it. Don't use timpsons they just say needs a programmer, I just tried that key and it's not starting the car weird it worked before and a week after wonder if it's a cheap key and somehow lost its pairing
      03-09-2022, 10:03 AM   #11
HelenBr
Drives: BMW 320i 1987
You might better call a locksmith south croydon to fix this issue of yours in the future. As far as I know, a locksmith can replace you the key and reprogram it.
