      02-05-2022, 10:49 AM   #1
Jack London
Drives: MR2 Z4
Question Sport Button not working.
Hey all, new member. Think this is the right forums. It's throttle related but didn't see a more appropriate subforum
I'm looking at a couple of Z4Ms right now.
One of them has a non-working sport button. Doesn't light up and doesn't seem to change the throttle response either.
Any idea what the issue might be here? Is it as simple as a broken button, fuse, loose connector? Or is there a bigger issue and expensive fix somewhere I need to know about?
Thanks for any help
      02-06-2022, 03:04 PM   #2
wdb
dances with roads
wdb's Avatar
4732
Sorry, no troubleshooting help here. But I will say that I never touch mine anyway. The only thing it changes is throttle mapping, and it makes it worse. I wouldn't let it change a purchase decision.
      02-06-2022, 03:16 PM   #3
couchflyer
couchflyer's Avatar
97
Drives: M4; X4 M40i
I use mine when I go on a spirited drive. I like the throttle response. Maybe the one that is not working has a tune. Plug in a code reader to see is it shows anything.
      02-06-2022, 04:50 PM   #4
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
I use mine on every start.
Racerbruce
      02-07-2022, 01:44 PM   #5
AustinZ4
Drives: 2007 Z4 3.0i SMG
2007 BMW Z4  [0.00]
If it isn't lighting up then there is probably a loose connector. Pulling the center console apart post purchase can resolve this.
      02-07-2022, 06:32 PM   #6
vt100
vt100's Avatar
126
Drives: '06 Z4MC, '12 128i
In this case (and AFAIK) you're experiencing only ~70% of the power available
      02-07-2022, 07:28 PM   #7
wdb
dances with roads
wdb's Avatar
4732
If you equate throttle response with power, then, maybe. But I see 6K+ RPM with regularity and that is where the power lives in the S54.
In my type of driving, on my eastern seaboard roads that are essentially walking paths and wagon trails that eventually got paved, the sport button just makes the car jerky and and overly antsy. Maybe if the roads were wider and faster it might be different. I can tell you for certain I'd never touch the button on the Tail of the Dragon. Other roads, well, I'll keep my mind open.
kaybat125.50
      02-07-2022, 08:14 PM   #8
vt100
vt100's Avatar
126
I don't remember where I read it (but I read it on several occasions from different sources) but you never open the throttle fully in regular mode. It's just never goes to WOT. So it's not just the reaction on the throttle pedal, it's also the amount of fuel/air you let into the chamber.
      02-10-2022, 06:02 PM   #9
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
Have you actually seen a Driver demand map that does what you describe?
I've look at dozens of BMW drivers demand and torque maps and I've never seen one that does not provide full power unless it's an emergency map or similar. The difference between sport and regular mod is simply the shape of the curve.
kaybat125.50
wdb4732.00
      02-12-2022, 03:13 PM   #10
vt100
vt100's Avatar
126
I stand corrected... searched it deeper and yep, you folks are right - it goes to WOT in normal mode, just not as fast as in sport. Please ignore my "fake news" in this thread
rjahl996.00
wdb4732.00
KMG13.50
