02-23-2016, 07:55 AM | #178 |
Rep 1,041
Hi Artemis, Thanks for the comprehensive tread on this! I am wondering if you can help, I have the Bimmertech Smart View installed in my car, so able to mirror my i-phone to my i-drive it uses Wi-Fi, if the Head-Up screen is installed will it be possible for me to use the Garmin sat nav app from and mirror the map to my idrive on the basis the navigation uses WIFI/WLAN too?
With the Smart view I am able to mirror my i-phone while mounted on my media cradle, and mirror any app on via Airplay, the Smart view connect to my phone via WI-FI. I hopping the mart view (Mirroring) option will give me the map on the idrive as well as the direction on the Head-Up display, this will of course be the perfect setup. Thanks for all your support. |
02-23-2016, 08:31 AM | #179 | |
Moderator
31509
Rep 13,308
Please note that I sold my 1M (including the Head-Up Screen) in the meantime.
///M is art ↔ Artemis
02-29-2016, 04:12 AM | #180 | |
Kind of a big deal
303
Rep 1,674
Drives: an 1M not often enough
02-29-2016, 06:18 AM | #181 | ||
Rep 3,292
I haven't dug into the details as to how both can coexist being they both use WiFi for connectivity. One thing of note though, the SmartView system runs off of TCP/IP as its transport protocol. When you first fire up the system and switch to the SmartView display on your nav, on the right lower corner, you'll see the IP address SmartView is using. It's a 192.168.x.y address. I don't remember right now what value the x is. I'm not sure how the Garmin system works. But make sure it's not using the same IP address range. |
02-29-2016, 05:33 PM | #182 | |
Rep 1,041
Thanks folks for your input, still not decided on Head Up Display but interesting to see how you managed 2 connections, when I get the chance I run a test similar to yours.
The one thing now not working with my SatNav App on my phone is no voice out when my phone is placed on the media adapter, so I get the full map showing on my i-drive with no voice, but I believe this is an issue between the SatNav App and the Media adapter in my centre console, and not the smart view. Quote:
02-29-2016, 08:26 PM | #183 | |
Rep 3,292
I opted to do it differently though. I decided to plug the SmartView cables (including audio) into the multimedia box for the rear camera retrofit. I then used the audio outs of the multimedia box to connect to the aux in under the arm rest. Doing it this way will allow me to utilize the other A/V inputs on the multimedia box to send their audio signal through the aux in of the car. And this is a stupid point but I'm putting it out there, make sure you switch your audio input under media to use the aux in. |
03-06-2016, 07:11 PM | #184 | |
Kind of a big deal
303
Rep 1,674
03-06-2016, 07:45 PM | #185 | |
Rep 3,292
03-07-2016, 03:27 AM | #186 | |
Kind of a big deal
303
Rep 1,674
03-07-2016, 10:25 AM | #187 | |
Rep 3,292
Part of my is to consult and sell wireless network equipment so I do know a bit more than the average person. As I said before, I haven't had a chance to dig into why this is even possible. But I'm glad it's working as it gives me options. I have Sprint for phone service but I also have Verizon for mobile data via a MiFi hotspot. If I get into a performance coverage issue with Sprint, I just fire up my Verizon MiFi and I'm good to go. |
03-13-2016, 05:44 AM | #188 |
Rep 1,834
Drives: 2020 X4M CS
so many better DIY HUD Smart phone apps like Torque Pro (In HUD MODE) or a' HUD AWESOME' OR goto amazon and get d 5" OBD....Use a clear thin piece of plastic to stop the double image from the laminated glass..
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
03-28-2016, 10:25 AM | #189 |
Rep 17
Hi guys,
I have video interface in my car and iPhone connected through it - although I can get screen clone on my F10 navigation it's not possible to output Garmin HUD screen due to app limitation. When you open Garmin HUD app while iPhone is connected to the 2nd screen you will get message that that option is disabled and that screen mirroring is not supported Just try it on your TV or through Airplay so you will know what I am talking about… I tried like couple of months ago but I doubt they changed that if there was even any updated to the Garmin HUD app in the meantime. So bottom line is: you can't get picture from Garmin HUD app at your BMW factory screen and directions on HUS. It would be neat but it doesn't work... |
05-09-2016, 06:26 AM | #190 |
Eric_Y
104
Rep 458
Drives: 2016 340i, 2010 E92 M3
One thing I didn`t get it, how does a E92 read speed limit? I haven`t heard the car had been integrated with any camera that can validate this function.
05-09-2016, 11:56 AM | #191 |
Rep 1,834
Drives: 2020 X4M CS
$30 Amazon 3" ACTUAL HUD....Paying over $400 for THAT? Seriously?
OK so the cheap Amazon HUDs don't display NAV, (I thought that was what that 7" screen AND VOICE INSTRUCTION was for... )
For Us, meaning gear heads, I want to know my Temps, by Alt is working prop, and most importantly the Speed and RPM. Especially in a BMW, where its hard to accurately access speed w/o looking. Even this $30 unit has "speed correction" to display true speed not the optimistic 8% + BMW Speedo...Warning Flashes and/or noises at user defined RPM, or High Temp Warnings. And the icing on the cake is it matches the gauges. Heres a vid of me beating my "friends" rental car w/ this unit....Its visible during the day and looks much better in person... Please stop with this BMW retrofit BS HUD, its insane. LOL
05-13-2016, 12:05 AM | #192 |
Rep 1
Hello
I was wondering if anyone has had problems when you update the hud? I had one that I update and then got the screen completely black and did not do anything more with it. got a new one on the guarantee and would update it and it was the same? Anyone know anything? |
09-13-2016, 08:30 AM | #193 |
Rep 61
Having just driven a hire car with factory-fitted HUD, I want this in my BMW. From the web searching I have done, I have come to the opinion that no current after-market arrangement would meet my needs. Why ? well I already have a GPS near my eye-line on the dash which displays speed but I found that the benefits of having the HUD image focussed at the same distance as the road was what made the whole thing worth having, because anything less and your attention is diverted while you re-focus to read the "HUD" display. I post this because not enough is made of the need to deal with the issue of focus in any retro-fit "HUD" and I wouldn't want people to discover this only after shelling out a large sum for a supposedly "OEM" solution that differs from the factory fit HUD in this crucial regard.
Edit - OK, this after-market model appears to do the job as far as focus is concerned: http://www.pioneer-car.eu/eur/products/spx-hud01 "No need to refocus Using a DLP projector for high contrast and deep colour saturation, the NavGate HUD projects navigation instructions on what looks like a 30-inch display, sitting about 3 metres in front of you, reducing re-focus times to almost nothing." Last edited by poiuytre111; 09-13-2016 at 09:01 AM.. |
09-14-2016, 02:31 AM | #194 | |
Rep 1,041
Judging by the link, this product is already archived! Looking at the size I am not surprised it is no longer available, it makes the BMW head up display accessory look like a factory-fitted option!
10-25-2016, 11:43 AM | #195 | |
Rep 17
http://f30.bimmerpost.com/forums/sho...3&postcount=98 http://f30.bimmerpost.com/forums/sho...&postcount=160 |
01-13-2017, 05:16 PM | #196 |
Rep 160
Hello! I have the retrofitted Integrated Navigation (see video below) and the HUS installed. The dealer promised that the HUS will work/communicate with the integrated navigation I have, however till this day it does not. I've tried updating the firmware using the HUS app but that only resulted in the HUS getting bricked... Luckily the dealer replaced the unit free of charge, but about the Navigation/HUS connection they seem to not know anything about it... To be honest I also had the strong impression that it will work seeing on etk being listed as "INTEGRATED NAVIGATION W/ HEAD-UP SCREEN": http://www.etkbmw.com/bmw/EN/search/...ECE/03/03_2283
I'm still waiting on an answer from BMW on their behalf, but I'd like to know if you know about this? EDIT: So appearently the Head Up Screen that works with my integrated navigation comes with a different part number, as shown from the above link. The one the BMW dealer installed was the standalone version. I've consulted my BMW dealer and they're going to order the HUS unit with the part number I was given and replace it again.. I hope it will work finally after the replacement. Last edited by Frankly30; 01-17-2017 at 07:54 AM.. |
01-20-2017, 07:52 PM | #197 |
Rep 310
No E60? If it works in the E90 then the E60 should be same basic harness and configuration.
And you may ask yourself, "Where is that large automobile?"
04-17-2017, 10:54 AM | #198 |
Rep 582
Old thread bump. So I had my dealer install the feds up screen into our 2014 X1. It works but intermittently. Here is the odd part the altitude always shows up. It always connects with my phone and all nav works. But what is intermittent is the speed, power, and torque (plus the cruise control when on).
I went back to the dealer thinking a loose wire but the tech's comment was that the data is in serial with the CAN so if a loose wire I would be seeing warning lights going off because other data would not be getting through. Part of me believes that but given it is intermittent I am back to a bad connection. I am going to pull things apart and take a look myself but in the mean time the dealer is going to try and get another unit as the tech says it is the CAN or the display itself. Any thoughts? |
