      09-27-2025, 01:08 PM   #1805
MassWholeBimmer
MassWholeBimmer's Avatar
5405
Drives: 2023 X5 M50i
My $11.95 house project. Our dining room has been morphing into my wife's "owl" room from the more formal look... The chandelier was 35 yr old from when we built the house, was brass, and wanted a change.. and i was sick of it. Planned on buying a new light, when my wife's friend said try spray painting it. Was going to throw it away anyways. So a few cans of spray paint later... thought it came out ok... it'll do...
2023. X5 M50i (The better 1/2's car)
2025. Ford F150 King Ranch Powerboost. (My baby)
RickFLM413113.50
Buug95930751.00
hubbahubba13858.00
      10-01-2025, 05:06 PM   #1806
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
30159
Drives: '22 Chalk Gray Porsche C2S
After 14 days of curing for the gunite, work has finally commenced. The 12’ wide by 4’ high water/fire feature was erected this morning. Once the cinder blocks set, the 5’ water shear will be installed (..in the open space) and the remaining cinder blocks will be added to finish off the structure. Next up will be tile.
Appreciate 7
Llarry30098.50
RickFLM413113.50
MoeTE872519.50
unluky8048.00
hubbahubba13858.00
      10-01-2025, 05:22 PM   #1807
Watching The World Burn
Lengthy but not a Girthy Member
2462
Drives: 1971 Honda Civic
Awesome, now that its cured is it going to move pretty fast you think? Did they give you an idea of timelines?
Sedan_Clan30159.00
      10-01-2025, 05:32 PM   #1808
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
30159
I think so. Once they finish the structure, they will tile the pool, spa and water/fire feature. After that they’ll do the decking throughout the yard and both outdoor patios, spray the pebble and fill the pool. After that they will build the outdoor bar under the covered patio with a Blackstone and a grill, and tile the wall behind the bar…..then it’s off to landscaping. Timeframe for completion is the end of the month. Fingers crossed.
Llarry30098.50
Buug95930751.00
wrickem2874.50
MoeTE872519.50
      10-02-2025, 01:41 PM   #1809
jaffles
jaffles's Avatar
797
Drives: 2010 e93 330d m sport
What filtration management you running with. I can highly recommend Astral eQuilibrium chlorinators or similar. They monitor and dose the pool with acid and from my experience on 2 different pools, my impute is about 5%. Work with sand or cartridge. No weekly testing, no weekly or fortnight trips to pool shops for chemicals. Just a crystal clear pool. I clean the sensors 1-2 times a year with acid, and 5lt of acid to make the system work last 4 to 12 weeks pending season. Tremendous bang for the buck.....not popular down the pool shop oddly enough.
      10-02-2025, 07:15 PM   #1810
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
30159
That’s a great question. I know the entire system is a new generation Hayward salt system. I’ll have to ask our builder about the filtration management system specifically.
      10-02-2025, 08:08 PM   #1811
SpeedBuggy
Comfortably Numb
SpeedBuggy's Avatar
Drives: '18 x1/'13 X3/'06 330i
2006 BMW 330i   [9.00]
Had painters in a month ago and completed painting three bedrooms and a computer/office room.
Once they finished, spent the next three weekends pulling up carpet and padding in said rooms. Pulled up all the staples from padding also.
I elected to pull up the carpet myself as I had some areas in the floors that squeaked, so went and tightened down all the underlayment prior to having new carpet and padding put down.
Was about 90% successful in reducing the squeaks prior to the padding and carpeting being put down.
We went with 1/2" padding with a moisture barrier and Dream Weaver Reflections II Carpet with Pile Thickness of 29/32"
The thicker padding and the higher pile carpet helped to absorb/ reduce the small amount of squeaks left in the floor. Still a little noticeable in a spot or two, but nothing compared to the noise we had prior.
Going to work from the bottom side in the basement as I think I have a floor joist that is actually making the small squeak I have left
Winter project is to reduce the amount of noise from the HVAC ducts.
One project left this fall, waiting for contractor to demo old decks and replacing with all new decks in composite material.
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada
18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec
Sedan_Clan30159.00
MoeTE872519.50
jaffles796.50
Buug95930751.00
      10-03-2025, 11:46 AM   #1812
Velvet Fog
Velvet Fog's Avatar
Drives: 2023 M850
2023 BMW M850i  [10.00]
Took about 16 hours to assemble this thing by myself. Degree of difficulty = 9.0.
Lots of many small parts.
Appreciate 7
RickFLM413113.50
vreihen1630811.00
Sedan_Clan30159.00
wrickem2874.50
Buug95930751.00
Needsdecaf10915.50
      10-03-2025, 12:31 PM   #1813
jaffles
jaffles's Avatar
797
You might have to stand your ground if you want it. My experience is pool builders and shops sell what they know. They appear to have negative views but also little experience with them. Yes the system cost more but you will make that back in one year if not buying chemicals every week or two.
For a while I graced perhaps the USs biggest pool forum Trouble Free Pools. They practice this test weekly habit with associated chemicals. I've had my pool 3 years now and had the water tested once after initial set up. I tested because after a month of rain the management system was struggling to deal with the volumes of fresh water, so I added salt, chlorine, something else and all went back to normal. Honestly pools are meant to be easy and fun, not a job.
      10-03-2025, 04:07 PM   #1814
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
30159
Sweet! Where did you purchase that?
Our pool builder is a friend who built a pool for my lady at another residence. We are getting A LOT for our money on this project. A very basic hole-in-the-ground with no upgrades is $100k these days, so for the $148k we spent, we are getting lots of bells and whistles; this is a full blown yard redo. He gave us the option for Pentair, Hayward, etc. …..salt/chlorine, UV systems, etc.
The fire/water feature is complete, so it’s onto tile and decking as of Monday.
Llarry30098.50
jaffles796.50
Buug95930751.00
      10-03-2025, 09:06 PM   #1815
Velvet Fog
Velvet Fog's Avatar
Drives: 2023 M850
Amazon of course. Comes in many sizes.
https://a.co/d/64nwr7A
Sedan_Clan30159.00
      10-04-2025, 08:07 AM   #1816
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
We have had some aluminum ones and some wood ones at multiple properties and now buy only wood. Water would get into the aluminum posts and expand in winter and crack the posts. Not an issue unless you are in an area with below freezing winters. The aluminum also looks worse as it weathers with age compared to wood. Also note that snow load varies depending on the quality of the structure. The better ones have snow ratings.
If you live in an area that has occasionally serious storms with strong wind gusts, beware that wind ratings vary from none specified to very high. Now we buy only high quality wood ones with aluminum roofs, both A frame and Hip style roofs, from companies like Yardistry. We try to look for and wait for sales if possible since the big names are expensive.
Spent 14 hours with 2 other experienced DIYers (one a professional carpenter) assembling a 12 x 16 Yardistry Meridian a few months ago. The worst part was peeling the plastic off both sides of every roof panel and roof trim piece. That alone took 3 hours. I helped assemble one of these a few years ago and the protective plastic film was much easier to remove.
Sedan_Clan30159.00
      10-04-2025, 02:29 PM   #1817
jaffles
jaffles's Avatar
797
There is an Australian movie called The Castle, in it there is a line "can we move the toyota to move the ford to get to get the mazda" or words of that effect to access a car in the drive way. There is a process to achieve a goal .
And as in all building/construction there are delays, stuff ups and set backs. Well I have to paint the BMW in the garage before the garage becomes bedrooms.
This was meant to be cherry red metallic....WTF
Size:  87.1 KBName:  B2.jpg
Size:  82.3 KBName:  B4.jpg
Size:  127.7 KBName:  Black Cherry candy.jpg
Sedan_Clan30159.00
wrickem2874.50
lakefront759.00
Buug95930751.00
hubbahubba13858.00
      10-04-2025, 03:35 PM   #1818
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
30159
Attachment 3831077Attachment 3831078Attachment 3831079Attachment 3831080
Excellent work for a garage spray. Damn!
wrickem2874.50
vreihen1630811.00
jaffles796.50
Buug95930751.00
      10-04-2025, 10:52 PM   #1819
vreihen16
Recovering Perfectionist
vreihen16's Avatar
30811
Drives: BMW-less :(
You mean bedroom spray.....
Currently BMW-less.
      10-04-2025, 10:54 PM   #1820
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
30159
Spraying in the bedroom is a good thing.
vreihen1630811.00
Buug95930751.00
      10-04-2025, 11:05 PM   #1821
jaffles
jaffles's Avatar
797
Its actually going to be two bedrooms and an entry.
All I know when you paint a car, its a bit like painting the house, tiling the bathroom, building a kitchen; every second person you meet wants to know if you do a bit on the side.
Sedan_Clan30159.00
Buug95930751.00
Llarry30098.50
Velvet Fog1039.00
      10-08-2025, 01:25 PM   #1822
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
30159
Framing for the concrete slabs to support the decking pavers began yesterday and continued into today. Tiling of the pool begins tomorrow (..water feature, water line, spa, etc.), and once that is complete, the contractors will pour the concrete and install the decking pavers.
hubbahubba13858.00
vreihen1630811.00
Buug95930751.00
jaffles796.50
      10-08-2025, 03:15 PM   #1823
hubbahubba
hubbahubba's Avatar
13858
Drives: M3CX
Sedan_Clan Man, what a project. Looks great! Did you consider a slide from the top of the walls?
Sedan_Clan30159.00
RickFLM413113.50
      10-08-2025, 04:28 PM   #1824
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
30159
Now wouldn’t that be fun?!? Haha! I can jump off the pergola though.
hubbahubba13858.00
RickFLM413113.50
      10-11-2025, 02:48 PM   #1825
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
30159
A few pics of the water line (..eye design) and spa tiles process. They made pretty quick work of the tile. Only the rain slowed them down!
Buug95930751.00
Llarry30098.50
      10-12-2025, 03:31 PM   #1826
jaffles
jaffles's Avatar
797
Nice, what colour pebble you thinking? Reckon you'll make Christmas?
Sedan_Clan30159.00
