      06-27-2011, 09:19 PM   #155
BTM
Drives: A///MERICAN!!!
fronts will be fine...not sure about rears...just put 18x9.5ET22 on mine and it's pretty "flush" with the fender to borrow a term I hate...maybe that helps...
      06-27-2011, 09:19 PM   #156
BTM
Originally Posted by Mirko View Post
BTM ... How are those rims to clean? They look good!
Can't comment...they are my friends wassup61, we just test fit them on my car to see if they would fit
      06-28-2011, 05:33 PM   #157
Bigmac834
Drives: 2008 Z4 M Coupe
Thanks. I will look into that...Those are the rears that I can get at a very good price...Or else I will have to purchase new...Thats why I was asking
      06-30-2011, 07:40 PM   #158
Bigmac834
I tried on 18x10 6" BS et12 ccw classics just for the hell of it. It would look badass if it actually fit.
Next up 18x10.5 ET19, hopefully these will fit better.
http://s42.photobucket.com/albums/e3...cw%20classics/
      07-02-2011, 11:12 AM   #159
brandobot
Drives: 06 Z4M
I'm currently running 245/35/19with 32mm offset in the front on my z4m roadster with no issues.
I'm having a hard time deciding whether to purchase 275/30 or 285/30 rears. The rear offset is 22mm on a 10" rim. I know 285 is closer to the stock size, but I don't want it to rub or stick out excessively. Is anyone running a 10" rim with similar offsets with a 275 or 285 tire?
Currently lowered on h&r springs with 15mm rear pads.
      07-10-2011, 08:27 AM   #160
beamon
Drives: 07 M Coupe
Brandobot,
I'm running a similar setup with stock suspension, no spacers, and no rubbing issues.
Front is 19 x 9 with 38 mm offset and 245/35/19
Rear is 19 x 10 with 28 mm offset and 275/30/19
With your lowered suspension, I'm not sure if yours will rub or not. I think some have done it without problems but using 275. Perhaps your tire shop can check out 285 fitment for you. Good luck!
      07-11-2011, 06:07 PM   #161
Duck360198
Drives: 2018 F30 340i Laguna Seca Blue
Can someone tell me if this setup would work:
19x8.5 32mm Front
19x9.5 28mm Rear
235/35-19 Front
265/30-19 Rear
Thanks in advance!
      07-12-2011, 05:16 PM   #162
BTM
yes
      07-19-2011, 11:43 AM   #163
ZStig
instagram 997turbotom
286
Drives: Interlagos Z4MR
18 x 9 et 40 fronts? lowered but gonna run -2 camber up front
      07-29-2011, 08:58 PM   #164
Duck360198
All right, here's another one I need confirmation on:
19" x 8.5" front (+35mm)
19" x 9.5" rear (+30mm)
235/35-19 front
265/30-19 rear
The main question is can I run the rears as is WITHOUT spacers?!? Please say yes!!!
THANKS!
      07-29-2011, 09:13 PM   #165
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
If you want to flush them out, you will need spacers.
      07-29-2011, 09:30 PM   #166
Duck360198
Will it look ridiculous if I don't??
      07-29-2011, 09:51 PM   #167
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
No not ridiculous...
It will EXTEND 6mm out more than the OE wheels
      07-30-2011, 09:01 AM   #168
ZStig
286
What size tires do you recommend for
18x.8.5 et 35
18x 9.5 et 25 ?
I wanna go as wide as possible in the back, and not stick out
245/40/18
285/35/18?
      07-30-2011, 10:35 AM   #169
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I find the E90 offset calculator pretty good for figuring wheel offsets.
      07-30-2011, 11:01 AM   #170
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
18x.8.5 et 35
18x 9.5 et 25 ?
245/40/18
285/35/18?
..soooo many factors.
It depends HUGELY of which tire you choose.
Depending on the make, a 285/35 can have considerably different specs for cross section & tread width.
Tire design is also a factor; e.g. Star specs are a little more square than NT-05s
It also depends on your rear camber.
FWIW....
I'm currently running 265/35x18 NT05s on 9.5" width wheels.
I have a net offset of 22.
My rear camber is -2.0
I'm right at the limit for what I can run on the track w/o rubbing.
Personally, I'd be looking at 10" wheel if 285 is your goal.
      07-31-2011, 12:46 AM   #171
vortex_tuning
Drives: E92 M3
18x.8.5 et 35
18x 9.5 et 25 ?
245/40/18
285/35/18?
If you are on stock suspension the front will not stick out. The rear *might* depending on the tire.
      08-11-2011, 10:02 PM   #172
IWantAnE92
Drives: 2008 E90 M3 6MT
Originally Posted by Daemonblitz View Post
So stock in Z4M is:
F 18 x 8 ET 42 225/45
R 18 x 9 ET 30 255/40
I can get a great deal on a set of e9x M3 rims Style 220M, they are the following specs (with these size tires already mounted on them):
F 19 x 8.5 ET 29 245/35
R 19 x 9.5 ET 23 265/35
Online Calculators showing:
Up front rim would stick out 19mm more.
In the back rim would stick out 13mm more.
I don't think the rears would be a problem but i am worried about the fronts sticking out too much and rubbing. Currently i'm on bone stock suspension and camber.
Am i going to rub or is it a safe set up ? anyone else running these specs for their 19s ?
Did you get this working in the end? Or has anybody else confirmed whether it works or not?
      08-11-2011, 11:25 PM   #173
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
Never got a chance to try those particular wheels on, they were sold before i went to pick them up .
With stock suspension if you max out your front camber you SHOULD be fine, if there is any rubbing at this point i think you would only get it at full lock.
I only know of 3 members to try the e92 wheels on. F360C (http://www.zpost.com/forums/showthread.php?t=460759), EndlessZ4M (http://www.m3post.com/forums/showthread.php?t=467130) and Taku (http://www.zpost.com/forums/showthread.php?t=160440)
F360C and Taku both said you'd need a fair amount of neg camber to be on the safe side and not rub. EndlessZ4M however, was on stock camber and I don't believed his wheels were rubbing, but i could be wrong.
      08-12-2011, 05:29 PM   #174
IWantAnE92
Thanks Daemonblitz. I'm actually buying the wheels of endless who says there isn't any rubbing with 1/2" drop. Just wondered if anybody else had tried it on stock suspension though which is what I'll be putting them on.
      08-18-2011, 07:30 PM   #175
nooooorb
nooooorb's Avatar
Drives: BMWZ4MC
Will these fit?
Z4M Coupe on stock suspension.
18x8.5 et43 (will run 10-15 mm spacer) on 245s.
18x9.5 et20 on 275s.
Thanks for your help.
Sold the Z. Got the G. Sold the G. Got a Z... 4... M. I still want a Jeepney!
      08-19-2011, 05:15 PM   #176
apexstrafer
Drives: Z4 M Coupe
Yes that'll fit, though you'd want a 5mm spacer up front. 10-15mm might be too much, depending on your camber.
