07-24-2010, 05:39 AM | #133 | |
Rep 932
I would go back to the dealer and insist they program it right. Last edited by RobMCoupe; 07-24-2010 at 05:41 AM.. Reason: spelling |
07-27-2010, 01:18 AM | #134 |
Rep 2,882
Installed the alarm kit this past Sunday...somewhat easy to do. It chirp once when armed and twice on disarmed. The clown nose does blink, but only after about 1/2 a minute or so after arming (locking). I'm going to have the dealer code it soon (still needs to call around for price quote), but how do you guys check/test to see if the alarm is actually working after the coding? I tried locking the car using the remote with the windows down, then reach inside to open the door from the inside door pull, but to my surprise, the door wouldn't unlock...is this normal? The only way to unlock the door was to use the remote. When the door is lock using the inside lock button or autolock upon driving off feature, you can normally open the door with 2x pull. But, when locking with the remote, you can't open the door from the inside at all...anyone else ran into this problem?
07-27-2010, 07:12 AM | #136 | |
Rep 11,669
07-27-2010, 07:22 AM | #137 |
Rep 11,669
Hey ShipK;
Just to clarify, what do you mean by works? Did you get yours activated? or Are you talking about the chirps that work after install w/o activation? Mine works fine on install with chirps (1 armed, 2 disarmed) & clown nose. I'll be in to see my Indi on Friday, so I'll see what happens wrt activation.
07-27-2010, 01:41 PM | #138 | |
Rep 2,138
Drives: Me
07-27-2010, 01:42 PM | #139 | |
Rep 2,138
Drives: Me
I really wanted the chirps on lock/unlock.... and that works just fine. |
07-27-2010, 01:48 PM | #140 |
Rep 11,669
thanks
Since there seems to be a variety of results with activation. I'll post my activation results after Friday.
07-27-2010, 10:41 PM | #141 |
Rep 2,882
Popping the trunk with the key shouldn't make the alarm go off, should it? Since you are opening it with the key, I would assume that it's smart enough to know that and should not set off the siren. On my X5, with the alarm activated, popping the trunk with the key won't set off the alarm. I'll see if I can reach down far enough to pop the hood
07-27-2010, 11:00 PM | #142 |
Rep 416
To set off your alarm if activiated, I sat in my car activiated the alarm and just pressed the unlock button on the center console. I opened the door and alarm went off =) i just slid the serive advisor 50 dollars under the table to activate my alarm along with daytime running lights and auto lock after going above 10mph
07-27-2010, 11:55 PM | #143 | |
Rep 932
07-28-2010, 12:59 AM | #144 | |
Rep 2,882
07-28-2010, 06:40 AM | #145 | |
Rep 11,669
I thought it was an activation option for the alarm to work(enable/disable) with fob only or with both fob & key.
07-28-2010, 09:33 PM | #146 |
Rep 932
I selected option to arm/disarm with remote and key. The key will arm/disarm when driver door is lock/unlock. I find it strange the hatch do not work like the door. I am not going back to dealer for that. It took them two hours to get all my programs back with single chirp to arm and double chirp to disarm. My car had the symptom where it did not chirp when arm.
07-28-2010, 09:56 PM | #147 |
Rep 11,669
Thanks...
It sure would be nice to know what they did for the arm chirp.
07-30-2010, 06:16 PM | #148 |
Rep 11,669
I had mine activated by my Indi today.
Worked like a charm; no issues with the chirps.
07-31-2010, 10:25 PM | #149 |
Rep 2,882
Had my dealer activated the alarm today. Took them 3+ tries and over 2+ hours and the arming (single) chirp only works about 20%-30% of the time. It's very strange that the chirp only works intermittently. I would expect it to either chirp or don't chirp upon arming, but find it weird that it will only intermittently chirp when I arm it. I'll let it "sleep" overnight and see what happens...may have to bring it back to the dealer next week to get this sorted out
08-03-2010, 10:40 PM | #150 |
Rep 4,320
Drives: '07 Z4 M Coupe
So I'm about to order alarms for my coupe and my dad's roadster, and just trying to clarify things... seem like there are 3 versions of the alarm?
Basic Alarm (65730302424) $38 Chirps on lock/unlock; and alarm will sound if doors, hood, or trunk (maybe) are opened. Regular Alarm (65730309944) $120 Adds the incline sensor. Alarm with Motion Sensor $245 Adds the interior motion detector for the roadsters. Is this right? And are any additional parts needed for any of the kits?
08-04-2010, 06:44 AM | #151 | |
Rep 659
Garage List 2022 M5CS [0.00]
FYI, like you, mine chirps in disarming but not on arming...
08-04-2010, 10:14 PM | #152 | |
Rep 352
Dubbedown, Thanks for the great find! Wow summer has just flown by... just ordered one still at the same great price. (Yes I'm two months plus behind)
OEM Strut Brace / UUC SSK / Zeck CDV / Clutch Stop / ZHP Shift Knob / Stubby Ant / Top Covers / Dinan K&N / M Seats / SP / PP |
08-05-2010, 12:47 AM | #153 |
Rep 2,882
Don't think that's it. I tried your suggestion and waited until the interior lights goes out (which meant the car has recognized all doors are shut) prior to arming the alarm...still no chirp
08-05-2010, 07:28 AM | #154 |
Rep 12,570
Glad you were still able to get in on it
