03-11-2020, 02:00 PM | #111 | |
Rep 12,318
Didn't have to roll the rear did you?
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
03-11-2020, 02:28 PM | #112 |
Rep 12,570
Nope 265 is pretty conservative. But then again I’m not slammed neither so hard helps...
03-12-2020, 09:39 AM | #113 |
Rep 12,318
That's great. I think your ride height is also spot on. Big fan of the way this car looks! I'll definitely keep this in mind.
Current:
3002 tii2303.50 |
08-05-2020, 02:38 PM | #114 |
Rep 6,830
Z4M coupe on Race Silver EC-7s
Big thanks to Dino for sending in these shots of this super clean Z4M coupe!
APEX wheel specs:
Suspension:
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey |
11-25-2020, 02:43 PM | #115 |
Rep 6,830
Checkout our customer Josh's beautiful 2006 Imola Red Z4M with APEX 18" ARC-8 wheels.
APEX Wheel Specs: Front: 18×8.5 ET38 ARC-8 in Hyper Black
12-05-2020, 10:16 PM | #116 |
Rep 1,373
Thought I would make a contribution to this thread.... both cars are on the same spec wheels. 9.5' et 35 front and 10' et 25 rears with with square 275/35/18 tires.
Untitled by Adam McGregor, on Flickr Untitled by Adam McGregor, on Flickr IMG_5008 by Adam McGregor, on Flickr IMG_5096 by Adam McGregor, on Flickr IMG_5090 by Adam McGregor, on Flickr Untitled by Adam McGregor, on Flickr _DSC1555 by Adam McGregor, on Flickr _DSC0913 by Adam McGregor, on Flickr IMG_1959 by Adam McGregor, on Flickr IMG_2497 by Adam McGregor, on Flickr _DSC1924 by Adam McGregor, on Flickr
07 Z4 M Coupe AW/IR |
12-21-2020, 06:22 PM | #117 |
Rep 138
F360C,
Love the look. Want to go square setup for canyon/track use. I like 275/35/18 setup you have. What suspension setup do you have. Any fender rolling, etc. Does it rub on street?
2007 Z4M Coupe. KW3, Stoptech ST60/ST40, SSK, AKG Bushings, 4:10 Diff, ARP Wing, ARP Splitter, MFR Splitter Underpanel.
12-31-2020, 06:51 PM | #118 |
Rep 6,830
ARC-8s always look good on a Z4M Coupe, especially when its Satin Black on Interlagos Blue!
APEX Wheel Fitment Specs:
01-12-2021, 06:58 PM | #119 |
Rep 6,830
Post pics of your Z4s with APEX wheels if you've got them! Both Z4 coupes and roadsters alike look best with a set of APEX wheels!
-Ian
01-16-2021, 08:49 AM | #120 | |
Rep 1,373
I am running MCS and the blue car is running Ground Control. Tiny bit of fender rolling in the front and rear on both. Both are -3.3 front camber. My car runs a 5mm spacer in the front for strut and brake caliper clearance. With the EC7's and the GC suspension on the blue car you can get away without a spacer if you dont run the car super low. If you do run the 5mm spacer you can run the car a lot lower with the Ground control suspension vs the MCS. The cars are both very stiff (750lbs front springs and 850lbs rears) so they dont rub a ton on the the street. Just a bit here and there with bit dips, off camber parking garage entrances, etc but its not terrible. A 265 front would def fit with out issue but I like the extra grip on track.
02-02-2021, 05:13 PM | #121 |
Backroad Warrior
64
Rep 112
Drives: Z4MR
Z4MR Specs:
Front: 18x9.5" ET35 APEX ARC-8 in Satin Black with 255/35-18 Michelin PS4S tires Rear: 18x10" ET25 APEX ARC-8 in Satin Black with 275/35-18 Michelin PS4S tires 987 Cayman Spec: Anthracite SM-10 18" details unk
02-04-2021, 06:21 PM | #122 | |
Rep 6,830
-Ian
05-20-2021, 06:53 PM | #123 |
Rep 6,830
11-04-2021, 07:27 AM | #124 |
Rep 399
APEX EC-7R Forged
APEX EC-7R Forged wheels
Front: 18x9" ET31 with 245/35-18 Rear: 18x10" ET25 with 275/35-18
Powered by
Steeler2430.00 Expert@ApexWheels3593.00 |
11-06-2021, 12:55 AM | #125 | |
Rep 5,329
lovely setup.... would you expect this to rub alittle ? currently running 18x8.5 et29 with 235/35-18 18x9.5 et23 265/30-18 on an r comp tyre. i can just and i mean just glance the front inner fender at maximum attack on a track, it doesn't rub through the fender given how light the contact is , im running an aggressive track geo with lots of neg camber. i see these setups and they look amazing but i wonder can the car be driven properly without eating itself . what would you recommend , id love a set of forged 8rc. also whats the lead times for the UK on the forged 8rc line in brushed clear.
11-08-2021, 08:02 AM | #126 | |
Rep 399
with -2.5 camber on the front i have no Issues, no rubbing
Powered by
11-10-2021, 05:59 PM | #127 |
Rep 5,329
awesome feedback, im abt the order the new vs sprint line... one last question.... what made you go brushed clear.... soooo tempted to choose this but just not sure... ???? also AK, can you confirm the rear is rub free? i cant imagine it being an issue.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 11-11-2021 at 12:29 PM.. |
11-11-2021, 05:11 AM | #128 |
Rep 5,329
ordered the New APEX Vs sprint series forged in brushed clear. cant wait man!
AK72286.00 Expert@ApexWheels3593.00 |
11-11-2021, 09:58 PM | #129 |
Rep 918
Perhaps I missed the memo, but I noticed not many SM-10 wheels sizes are available anymore for Z4 sizing. Are they discontinuing the series?
Andre - 2J into a Z4 Coupe!
01-12-2022, 12:11 PM | #130 | |
Rep 6,830
-Tom
08-16-2022, 03:58 PM | #131 |
Rep 6,830
Paging BMW owners in the Bay area! If you're interested in free professional photos of your car on brand new APEX wheels, we are looking for volunteers for testfiitting and photoshoots! Volunteers will get copies of the photos, a discount on a future set of APEX wheels, and APEX goodies/swag. If you are interested in volunteering, please complete our online webform here. Show us what you've got! If you'd like to take an inside look at what the photoshoots involve, our good friend Blake made a video detailing the process of an 18" photoshoot on his F82 M4 recently: Another look at the process of shooting an E46 race car with our Creative Director Yo!
01-31-2023, 05:20 PM | #132 |
Rep 6,830
