08-23-2012, 10:38 AM | #67 |
Rep 12,570
I think that's aluminum, not sure how much weight savings you'd get with that. I'm sure it'll be lighter but relative to cost, might not be worth it. Roof, doors, hood and hatch would be the only pieces "worth" it imo.
BTW - apologies for the stupid question. I know CF is stronger than steel but what happens during impact/accident? Steel obviously bends/dents/crushes but how would the CF piece hold up? Would it just crack? Last edited by 3002 tii; 08-23-2012 at 10:46 AM.. |
08-23-2012, 11:56 AM | #70 | |
40
Rep 1,481
Cf alone in an impact can be designed to be brittle or extremely crush resistant. It all depends on the cloths original lay-up schedule. CF mixed with Kevlar in construction as well as core materials or honeycomb all play a roll in the final build and engineering goals. Example, the nose cone of an F1 car. It is specifically designed for mass impact crushing forces and engineered to collapse and absorb energy all the while being SUPER light weight to keep over axle taxing down. I use core bulkers as well as honeycomb matrices in my engineering of parts to fit their real-world scenarios. To a hatch.....it must be built rigid enough to hold its own form through multiple slamming and opening events yet, still be able to collapse under a rear-end collision or impact with a wall/barrier etc. In order for me to replicate the goal and at the same time make it lighter, I have to work materials or lay-up schedules to perform as such. The only thing steel has over composites is it cheaper current cost and ability to retain heat. Steel can rip/tear in certain situations whereas CF mixed with Kevlar will not. I foresee any wreck containing my parts to give proof that the OEM surrounding steel parts will fail while the composites hold together well and provide safety. Bare in mind....I am NOT removing ANY crush/fold shapes from BMW's stampings on these components. They will still have all engineered load fail points for sake of safety. BMW did all of the destructive testing needed for this to pass. I will be simply making the parts with more exotic,lighter and stronger material. Also, someone asked me if a my composite panels will dent or crack ? The answer is no. Strike a hood with a fist sized rock and you'll need a new hood....do the same on a CF hood and it might need to be re-cleared at worst. Same with hatch, doors etc. I'll make an effort to do some videos for destructive tests on any parts I make that are considered 'seconds' or 'flawed' to show this. It is amazing to witness. |
08-23-2012, 12:24 PM | #71 |
40
Rep 1,481
TC Kline Carbon Coupe CF fender by btmlinedan[/QUOTE] I would imagine most will paint the outer skin of their doors the color of their car and leave the door-jamb area in cleared CF just as a way of proof.-(see picture above in its jamb area). |
08-23-2012, 01:33 PM | #72 | |
Rep 11,669
I'm just saying if it was 150lbs (e.g.) being shaved off, that would grab more attention & promote the project better. ....someone needs to take a door off, strip it down & weigh it. too bad shipkiller didn't weigh his when he did his rebuild. If one was to do CF hood; hatch; roof & doors, I wonder how much would be shaved off? ...the car might blow away in a cross wind
08-23-2012, 02:22 PM | #73 | |
40
Rep 1,481
I'd imagine we really won't know the door weight until I can pull this set apart and weigh them. Because even if we get the PO to weight them...it won't be in stripped form and that won't be a fair assumption from there. Weight of glass,regulator,motor,handles and latches all has to be considered as a wash before the door shell weight will be accurate. This is almost like nobody wants to date the new pretty girl until everyone thinks she's also pretty,lol. |
08-23-2012, 02:26 PM | #74 | |
Rep 11,669
...in for $50
08-23-2012, 02:33 PM | #75 |
40
Rep 1,481
Rawsome !!
1).- Roffle Waffle--(Tom)------------------------------------------+$50.00 2).-Twisted Six/Dark Schnitzer-(Vince)----------------------------+$50.00 + (not to mention I'll have thousands in the molds : ) 3).- Mexico BMW (Diego)-------------------------------------------+$50.00 4)-K3N R3D--------------------------------------------------------+$50.00 5)-inTgr8r-(Ian)---------------------------------------------------+$50.00 6)- 7)- 8)- 9)- 10)- 11)- 12)- 12)- 14)- 15)- |
08-24-2012, 11:53 AM | #76 |
Rep 11,669
detailed door DIY from Ron Stygar
http://www.bimmerfest.com/forums/sho...d.php?t=210510
08-24-2012, 07:14 PM | #78 | |
Rep 1,663
As an aside, how will it sound/feel when you open/close the door?
08-24-2012, 07:32 PM | #79 |
40
Rep 1,481
Way more solid and sound. It will have a nice thunk ! And that is with no Dynamat.
08-24-2012, 08:27 PM | #80 |
Rep 11,669
I wish there was a practical way to avoid putting all the crap back in.
Eg. Coupes need the power windows to have that auto up/down with door opening &closing. I would definitely like to eliminate the inner door card.
08-24-2012, 09:23 PM | #81 | |
40
Rep 1,481
Most guys aren't as track heavy-minded as you and our Arizona friend ! |
08-24-2012, 10:07 PM | #82 |
Rep 1,663
All right, I'll throw in $50 to get it off the ground. Purchase pending on weight savings.
08-25-2012, 02:10 AM | #84 |
707
Same here. I'd love to cut a chunk of weight out of this car. Roof, doors, hatch, if those deliver that plus seats and we're really talking some improvements! I'm too tired to figure out how to put money in tonight, but will get to it over the weekend.
08-25-2012, 07:38 AM | #85 | |
Rep 11,669
A plain flat cf trim panel would work for the lower.
08-25-2012, 10:01 AM | #86 | ||
Rep 2,460
08-25-2012, 11:58 AM | #88 |
Rep 2,460
2).-Twisted Six/Dark Schnitzer-(Vince)----------------------------+$50.00 + (not to mention I'll have thousands in the molds : ) 3).- Mexico BMW (Diego)-------------------------------------------+$50.00 4)-K3N R3D--------------------------------------------------------+$50.00 5)-inTgr8r-(Ian)---------------------------------------------------+$50.00 6)- Beta.............................................. ...........................+50.00 7)- 8)- 9)- 10)- 11)- 12)- 12)- 14)- 15)- |
