      05-29-2021, 04:18 AM   #67
M-Cast
M-Cast's Avatar
Drives: 2007 M Coupe
2007 E86 Coupe  [0.00]
2006 Z4 3.0si Coupe  [6.00]
2002 330 CI  [0.00]
2018 BMW 240M  [0.00]
2007 M Coupe  [10.00]
Yeah, it has been a busy year. The 3.0si has been coming along nicely and with every race we are getting the car closer to being dialed in. The N52 is turning out 268 whp which, the newly rebuilt s54 Stroker motor is due back from the builder in June allowing us to get back on the install.
The Goke body kit has been fitment has been fairly easy with only small modifications. I will post up more pictures soon, we are sending the chassis out to paint next week.
wdb4762.50
      05-29-2021, 09:13 AM   #68
racerbruce
racerbruce's Avatar
3858
Drives: 21 X3 & 13 335is E93
GO M-Cast GO!
Such buiid(s)....such precision.
You and Vanne lead the way in creating bespoke racing machines....the mere mortals watch and cheer you on.
Racerbruce
      05-29-2021, 04:28 PM   #69
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Originally Posted by racerbruce View Post
GO M-Cast GO!
Don't forget Micheal, he local near me look up LTW Z4 M
      05-29-2021, 06:50 PM   #70
racerbruce
racerbruce's Avatar
3858
Well said -
Michael - we are in awe at the transformation from a sought after sports car to a racing machine at the highest level....so awesome.
Racerbruce
      05-30-2021, 12:49 PM   #71
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Prep day with the Z4 3.0si
Thought this would give you guys a closer look at the Z4 Endurance car. we still have a few items to finish her up, these are great cars for those looking for reliability and lower consumables.
Weight: 2705 lbs
WHP: 268
Cost to Build: $55,435.95 (*not including labor)
Chassis
2006 BMW Z4 E86 3.0 si $10,000.00 Est
Suspension
MCS 1 way dampers $2,750.00
Ground Control Sway Bar Kit $699.99
Ground Control Coilover Kit (Springs, Mounts Links) $839.99
Ground Control Race Camber Plates $419.99
AKG Lower Rear Lower Adjustable Control Arms $280.00
"SyncroDesignWorks RTAB's, Rear trailing arm bearings" $265.00
Rouge solid Inner and outer trailing arm bushings $150.00
AKG Rear Shock Mount Set Aluminum – Spherical Bearings 12mm $150.00
AKG - Differential Mount Bushings, Poly 75D – BMW E46, Z4 (Non-M) $140.00
Welded in strut tower reinforcements $500.00
Upper Strut Mounts $250.00
Ultra Racing Lower Rear Strut Mounts $250.00
AKG - Front Control Arm Bushing Set (66 Mm), Poly 75D $80.00
Drivetrain
AKG Motor And Transmission Mounts, Poly 75D $180.00
Syncro Custom differential 4 clutch ramp 3.73 gear ratio $3,400.00
Bimmerworld Differential Cooler $659.00
NB Engineering Shifter $399.00
AKG Selector Road $150.00
JB Lightweight Flywheel and Clutch Combo $899.99
Aluminum Pedal Upgrades $125.00
Mason Engineering Clutch Pedal
Rouge Barke Bushing upgrades $320.00
Braking
Stoptech slotted Rotors $300.00
Stainless Steel Brakelines $150.00
Hawk Pads $600.00
Brake vents and backing plates $350.00
Wheels & tire
APEX 17x9.5 forged wheels $1,550.00
Hoosiers $1,350.00
APEX 18x9.5 ARC 8 Flow Form wheels $1,000.00
Yokohama Avant 052
Exterior
M front bumper with VRS and APR splitter $1,500.00
M Aero Rocker Panels $750.00
Lexan Rear and side windows $650.00
APR 250 GT 61" rear wing $1,600.00
Exhaust
Active Werks Headers $600.00
Custom straight pipe $750
SuperSprint Race Pipe & Exhaust cans $899.00
Interior
OMP Halo Seat $980.00
6 point harness $450.00
OMP seat mount $150.00
Carbon Floor pans Driver and Passanger $325.00
Bimmerworld floor mounts $150.00
OMP 330 steering wheel $299.00
OMP hub and quick release $550.00
Cool Suit Kit $565.00
Helmet Blower $325.00
Harness Thinning & Rainlights $1,250.00
Safety
Full Cage $3,680.00
Fire System $468.00
Inner Driver Safety Net $180.00
Driver Safety Nets $350.00
Engine
Epic Tune $998.00
Kassel Tune $900.00
AFE Cold Air Intake $450.00
Dinan Larger Throttle Body $925.00
Modified Intake Lift Valvetronic Supports (MILVs) $300.00
Bimmerworld baffled oil pan $1,750.00
Cooling
Upgraded Silicone cooling hoses $225.00
Replacement of water pump & thermostats $500.00
Differential Cooler Bimmerworld $650.00
Mishimoto Oil Cooler Kit $300.00
Custom Radiator Shroud for air flow $150.00
Zionsville Race Cooling kit ( radiator, overflow tank, electric fan and shroud) $1,600.00
Electronics
Braille Battery $345.00
AIM DL2 Solo with OB2 Upgrade $699.00
AIM SmartyCam 2.0 $1,100.00
Mylaps X2 Transponder $239.99
Motorola CM300 2-way radio $325.00
Battery Aux Cut Off Switch $40.00
Start and switches $85.00
wdb4762.50
Vanne1623.50
racerbruce3857.50
pyshin110.50
RvsBmw13.00
      05-31-2021, 10:35 AM   #72
racerbruce
racerbruce's Avatar
3858
M-Cast,
SO incredible.
Such detail - such commitment to create this racing machine.
Any ideas on the estimated hours invested??
Racerbruce
      05-31-2021, 06:54 PM   #73
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
M-Cast,
SO incredible.
It's hard to say, probably around 150 to 200 total hrs.
racerbruce3857.50
      06-09-2021, 12:27 PM   #74
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
2022 BMW X3 M40i  [10.00]
2011 BMW 135i  [10.00]
2007 BMW Z4M Coupe  [10.00]
1991 BMW 318is  [10.00]
Weight: 2705 lbs
WHP: 268
Solid numbers and I am a huge fan of the N52 engine in my E91 wagon, smooth and easy to wring out. Looking for a Z4 3.0 coupe donor was tough with the enthusiast tax, settled on a 99' Miata to get my feet wet building a HPDE car and already brainstorming the next creation. Just completed my first 3-day weekend out in the car after 180+ hours building it out in the garage - tremendous feeling!
      06-09-2021, 12:28 PM   #75
eggman51
Drives: 2006 BMW Z4 M Roadster
This is a brilliant build and that parts list is super helpful - thanks!
      05-11-2022, 11:39 AM   #76
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Updates on GT4 Race Conversion
Its been a while since I have posted the progress of my GT4 project. The car is classified under C-Mod with BMW CCA Club Racing.
Took a little while to get the fabrication completed. The engine is a 3.46 liter S54 with a DCT 7 Speed Transmission. The project should start moving a little quicker now. I have had a number of people give a list of all the mods, but to be honest, this car is bespoke and the list is long.
Steeler2430.00
XMetal1167.00
wdb4762.50
racerbruce3857.50
      05-11-2022, 02:20 PM   #77
wdb
dances with roads
wdb's Avatar
4763
Wow! That is going to be one very stiff platform. Are the rear fenders widened?
      05-11-2022, 02:34 PM   #78
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Yes, the front and rear are 40mm wider at each corner and the whole body is Carbon Fiber
wdb4762.50
      05-11-2022, 05:14 PM   #79
eggman51
insane. love it!
      05-11-2022, 06:02 PM   #80
racerbruce
racerbruce's Avatar
3858
Well done M-Cast!
This is indeed bespoke and the design and construction looks so precise.
Any thoughts when you will perform testing and when you will enter competition?
Racerbruce
      05-12-2022, 08:49 AM   #81
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
My friend is running a Z4MC in C-Mod BMWCCA on the west coast, certainly would be fun to have another Z competing! I know he looked into the Flossman kit and OEM BMW endurance gas tank - too pricey for his current budget.
TC Design in CA did the roll cage fabrication
racerbruce3857.50
M-Cast707.50
wdb4762.50
      05-12-2022, 04:19 PM   #82
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Well done M-Cast!
I am hoping to have it all shaken down before the Carolina Motorsports Park race in October, if I can have it ready by the Sept Race at Road Atlanta would be ideal. Until then I will be running my H Prepared car.
racerbruce3857.50
      05-13-2022, 06:46 AM   #83
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
He should look at the GOKE kit, either way, I would have to disclose any of these kits require a lot of fab work to get it done correctly. If he could make it east he would enjoy the seen out here as it's much more active.
racerbruce3857.50
3GFX722.50
      05-13-2022, 02:47 PM   #84
ANILE8
ANILE8's Avatar
No_Country
180
Drives: Z4 M Coupé - Carbon Black
New Rear Suspension is in and should have this back to a rolling chassis so I can get it back to the fab shop next week.
I might have missed it in this thread with all the info but can you confirm what the red subframe bushings are?
They look like a poly bushings but I would have thought you would have favoured a solid alloy mount for the subframe, especially considering the intended use of this vehicle.
      05-13-2022, 04:39 PM   #85
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
I do not use solid mounts as they can crack the subframe. These are AKG Reds which are marble hard. We do use solid trans mounts with these in combination.
https://www.akgmotorsport.com/produc...yurethane-75d/
wdb4762.50
      05-14-2022, 03:59 PM   #86
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Yes he is running custom control arms already to correct suspension geometry and travel at race height (roll center?) in addition to rolling the fenders for 18x10 square. Additional diff cooling, more I am forgetting certainly.
The select few running these cars hard on track are certainly the DIY type. A unique and rewarding car to pilot.
wdb4762.50
      06-21-2022, 12:32 PM   #87
NLE
Drives: BMW M3 & Z4M
Awesome build!
      08-14-2022, 02:26 PM   #88
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Updates on Z4 Touring Car GT4
It's been ages since I have posted and we have made some updates converting the car over to DCT. Not sure if it's the first S54 DCT conversion in an M Coupe but it fits as it should.
wdb4762.50
racerbruce3857.50
Steeler2430.00
RvsBmw13.00
