03-26-2016, 08:00 PM | #728 |
Rep 12,570
New wiper blades, so exciting!
03-26-2016, 08:51 PM | #729 | |
Rep 439
Stock ones were crap, so I was happy to have a set that performed better and looked more suited to the car.
Remote Start /// LEDs /// 20% Tint /// SGT Headers /// Gloss Black Roof /// Aero Sides DKF Resonated S1 /// Mstache V2 /// Rear Diffuser /// CF Mirror Covers /// Eventuri Intake MRR GF7 Wheels /// Evolve Tune /// CF Spoiler /// Michelin PSS |
03-28-2016, 02:02 AM | #730 |
Rep 2,882
Had the "SoCal S54 Guru", Kevin ("kaiv" from M3forums and here) helped with installing/changing all items from post #687 - essentially an inspection 2 + Vanos upgrades + 4 coolant hoses. The car is now running sooooo well. It's super smooth and quiet - all the Vanos rattles are virtually gone!
Here are some pictures from Valve Adjustments and Installing Beisan Vanos Upgrade stuffs: All the Beisan upgrade stuffs done and ready to go back in New pump disk installed - all hub/disk contact slacks removed The original disk looked pretty good, not much scoring by the hub The upper chain guide, on the other hand didn't look so good. This is only with a bit over 44k miles on the motor! Lastly, the obligatory picture with Kevin's recent project - 325iT to M3 conversion. More info of that project can be found here => http://www.m3forum.net/m3forum/showthread.php?t=540964 |
03-31-2016, 09:14 PM | #731 |
Rep 453
Drives: 2007 Z4M Coupe
Stromung exhaust, new OEM rotors, Akebono Pads, ECS 10 mm spacers, oil change, brake fluid flush, painted reflectors, CDV delete and best of all aero side skirts. After 3 weeks on Jack stands, I'm Looking forward to getting her back on her wheels
03-31-2016, 10:12 PM | #732 |
Rep 204
I got a "stubby" antenna today. I'll probably swap that out tonight.
@milamookie: That's a sharp looking Z! I'm looking forward to the finished pics. |
03-31-2016, 10:36 PM | #733 | |
1624
Rep 4,296
Powered by |
04-01-2016, 10:10 AM | #734 |
Rep 2,882
He has done this so many times that he can probably knock it out in a few hours on the M3. He told me the Vanos unit is a bit more finicky to wiggle out due the the front cross brace of our cars that he wanted to take a bit more time on it, so I left the car with him overnight. Plus, I had him work on a bunch of other things that I didn't mind leaving it in his hands. He is very detailed and meticulous as you can see some of the pictures in his work that I don't ever want to rush him through anything. He had help me do a similar Vanos work on my M54 X5 a couple of years ago and it only took him about 2.5 to 3 hours and that was with him explaining things to me as he work on it and with me pestering him with questions
04-01-2016, 04:50 PM | #736 | |
Get Some
226
Rep 759
Drives: 07 Z4 3.0si
04-01-2016, 05:00 PM | #737 |
Rep 870
Drives: 2006 BMW Z4M Roadster
They look really good. It's a shame they get covered up, isn't it.
Salty
04-01-2016, 06:10 PM | #738 | |
Rep 1,923
I never met someone that is incredibly detailist and careful.... he literally works on people's car like it's his. my inspection 2 was done by him too. lot of reputable shops call for advices and instructions.
04-01-2016, 06:12 PM | #739 | |
Rep 355
Left the cover off initially Salty, but its such a nice piece,will put it back on soon.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
04-01-2016, 09:55 PM | #740 |
1624
Rep 4,296
Preventative or was the car running crap?
Powered by |
04-01-2016, 11:29 PM | #741 |
Rep 355
was actually running fine(24k),figured i'd give them a try. Guess i have 6 oem coils as backup now.
04-01-2016, 11:49 PM | #742 |
636
Rep 3,124
^ I replaced mine with "Amazon" (stock) coils at 93k.
I was doing a valve adjustment anyway, and I figured they had a good run. Bought 7 so I would have a spare. Plus I kept the ones with 93k on them, so I should be coiled for life.
04-02-2016, 12:07 AM | #743 | |
Rep 439
How much does a new set of coils run?
04-02-2016, 12:14 AM | #744 |
636
Rep 3,124
May 2013:
Items Ordered Price 7 of: Bosch 00124 Ignition Coil Condition: New Sold by: Amazon.com LLC $22.86 Total before tax: $160.02
04-02-2016, 03:42 PM | #745 |
Rep 439
Not a bad price at all.
04-02-2016, 07:56 PM | #746 |
Rep 439
Ordered a new set of wheels. MRR GF7s in gloss black. 18x8 et35 and 18x9 et 23. Should arrive Wednesday, have an appointment for tire mounting and road force balancing on Thursday.
04-04-2016, 10:46 AM | #747 | |
Rep 321
04-10-2016, 10:40 AM | #748 |
Rep 1,550
Well, after about 9 years.....it was time. I finally swapped out the battery that came w/ the car back in '07 and picked up a new battery....went w/ the AGM 48PLT from O'Reilly.
Install didn't go as smooth as it could have, though. The head of the plastic screw that holds the plastic bracket for the cover retainer stripped immediately so I had to back it out by hand w/ a socket. Then, once everything was disconnected, the battery wouldn't slide out. It seems that, at some point, there was some trauma to the tall bolt that holds down the battery clip. I noticed that it was slightly crooked when I took the bolt out. It appears that the metal disc/receptacle raised up slightly on one end so the battery would catch on it. Slightly tilting the battery got it over and out. I'll probably replace the tray and bolt at some point. Interestingly, the OR battery has a little color indicator for sufficient charge, insufficient charge, and replace battery. It still indicated sufficient charge, but the battery only sat at 6.3V despite having been on a battery tender for days.
- Jeff
bosstones' flickr |
