02-17-2014, 03:34 AM | #45 | |
Rep 711
I started looking at aliexpress. Found these: http://www.aliexpress.com/item/4pcs-...243730618.html Claims 700 lumens with few LEDs and only 25w. That seem ridiculous to you?
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R| |
02-17-2014, 05:18 PM | #46 |
636
Rep 3,124
Says 4.9W and 350mA, so they're driving them harder that the ones I found at 3W and 200mA.
They'll make more light that way, but may impact life span. It comes down to whether you believe the seller. The big question is will they fit in the headlight housing. I just pulled a taillight assembly and there's gobs of space in the panic brake light. I don't think the front turn signals are as roomy.
02-17-2014, 11:23 PM | #47 |
636
Rep 3,124
Pulled the trigger
Got tired of hemin' n hawin' about it.
Just bought everything CREE for the rear assemblies: Turn signals, PY21W/7505, Bimmian WTSZZY5AB Main brakes, P21W/1156/7506, Bimmian WTSZZY8XB Backup, W16W/921, eBay 30W CREE Panic brakes, H21W, eBay 50W CREE I'll give the H21Ws a fitment test in the front turn signals. If the Bimmian PY21W pan out, which I think is a good bet, I'll be selling the 2 Silver Visions I just bought for $25/pair, firm, shipped CONUS. Get your dibs in now. They're about $20 each, so this is about 1/2 price, and you know you'll need them before long.
TRiCC264.50 |
02-17-2014, 11:28 PM | #48 | |
Rep 711
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R| Last edited by Devious21; 02-17-2014 at 11:34 PM.. |
02-26-2014, 11:47 PM | #49 |
636
Rep 3,124
Rats!
I just figured out the glowing LED hamburgers, and how my car knew there was a front turn signal out before I used the turn signals.
It continuously pulses all the bulbs at low duty cycle to see if they're there, even when not in use. The H21Ws for the panic brake lights may set a bulb warning even if I don't do a high-G stop. Calculated how much resistor would be needed, and not surprisingly, since the LEDs pull next to nothing, to simulate a 20W bulb you need a 20W resistor. The Bimmian bulbs are supposed to be error-free, but there's no way they're hiding a 20W resistor in there. How do it do dat?
02-26-2014, 11:51 PM | #50 | |
Rep 711
02-27-2014, 12:04 AM | #51 |
636
Rep 3,124
So I was sanity checking all the bulbs with a 9V battery.
All the white ones look pretty respectable, given it's 9V and not 14V. Then I got to the Bimmian amber turn signals. Holy mother of pearl. I hope my vision returns to normal by tomorrow. Actually, could be a capacitor with a modest bleeder resistor. Too bad my scope's a Tek 545B from the 70s. It's the size of a hotel mini-fridge and weighs twice as much. If I knew the duty cycle and rep rate, I could calculate an R/C combination. Man. My right eye is still jazzed from that turn signal bulb.
02-27-2014, 12:36 PM | #52 | |
"The Midas Touch"
521
Rep 1,055
Drives: F87 LBB ///M2
http://www.ebay.com/itm/130895183538 Hope it matches. |
02-27-2014, 12:44 PM | #53 | |
Rep 711
Did you get a chance to test fit the bulbs up front? Or did the self induced blindness push that back to a later date
02-27-2014, 11:41 PM | #54 |
636
Rep 3,124
The weather this weekend is going to push that out until next Friday.
I'll be spending tomorrow researching how to cure the bulb-out warning.
02-28-2014, 02:50 AM | #55 | |
Rep 711
Found this: http://www.a5oc.com/forums/a5-s5-top...stor-do-i.html Contains a formula I think is applicable.
02-28-2014, 09:38 AM | #56 | |
Rep 2,882
The only way to avoid a high power resistor is to do some type of RC circuit (to filter out those pulses) per stickmon's suggestion. |
02-28-2014, 10:22 AM | #57 | ||
Rep 711
02-28-2014, 01:41 PM | #58 |
636
Rep 3,124
V=I*R
P=I*V The rest is an exercise for the student. Anyhoo ... The Cree H21W was a fail. The distance from the "head" to the locking pin is just a mil or so too short to allow it to go far enough into the socket to turn and lock. Could probably file down the end of the socket, but I wasn't willing to just yet.
02-28-2014, 02:10 PM | #59 | |
Rep 711
02-28-2014, 03:44 PM | #60 |
636
Rep 3,124
No that was the front. I decided to do it this weekend after all.
The rear is going swimmingly. Last night I found the solution (I think) to the bulb-out on the panic lights. It was a "Duh" moment. I disconnected my somewhat elaborate transistor/relay circuit that lights the panic brake lights all the time and just jumpered them to the main brake lights. I tried that before with the incandescents, which was silly, and it drew to much current from the main and set the bulb-out. I'm lucky I didn't break the driver in the light module. But with LEDs, no problem. The left side is the LEDs. The H21W LED isn't quite as bright as the incandescent, but I expected that. It's bright enough, and the rest are brighter. The turn signals are insane.
TRiCC264.50 |
02-28-2014, 04:01 PM | #61 |
Rep 711
Wow that does look bright.
Shame about the fronts. I'll have to look into something else.
02-28-2014, 07:04 PM | #62 |
636
Rep 3,124
Some observations:
No "hamburger glow" from the rears. The brake light LEDs are so white that the brake lights are now a bit pink. If you're concerned you might be driving a hairdresser's car, it won't help. Worst of all, the 3rd brake light is still deep red, so they don't match. Red 1156s would have been better. Bimmian doesn't have them. It'll work great if you're going to do the red film. When you first turn on the ignition, it pulses the brake lights and turn signals in sequence for about 10-15 seconds. It's quite a show. Hopefully I can corner my Son and have him make a video for YouTube. For now, I need to go rest my rods and cones.
05-05-2014, 01:22 PM | #63 |
Rep 711
StickMon - Did you ever find any bulbs or attempt to replace the alternate corner lights? Not sure what you actually call them.
05-06-2014, 12:03 AM | #64 |
636
Rep 3,124
I didn't like the 5x5630 bulbs from Amazon. They were too blue, and not as bright as the 9x5050 that I had in the hamburgers. The ones that I couldn't remember where I bought them.
I finally figured it out they were "New 9 Led SMT Tower II" (fifth one down the page). I ended up moving those from the hamburgers to the front corner markers and putting these in the hamburgers. It was a little tricky, because they were too long to fit in the housing. I put them in as far as they would go, and then glued them in place with a blob of silicone calk. Cheesy, but the result is great.
05-06-2014, 12:07 AM | #65 | |
Rep 711
I'm talking about the other front/corner bulbs. The ones that are monitored and 2 per side. Have you done anything with them?
05-06-2014, 12:11 AM | #66 |
636
Rep 3,124
Still haven't done anything with the angel eyes or front turn signals.
Angel eyes will be next, but first I have to find the ambition to figure out NCSExpert. Turn signals will be a beatch. Monitored, need high wattage, and danger of damaging the amber bits jamming in a bulb that's too long.
