Thread Tools |
| 02-18-2026, 04:07 PM | #45 |
![]() ![]() ![]() 402
Rep 518
| 02-18-2026, 06:39 PM | #46 |
![]() 2527
Rep 2,757
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX |
| 02-18-2026, 07:04 PM | #47 |
Rep 34
Drives: 2006 BMW Z4M Coupe
| 02-19-2026, 08:25 AM | #48 | |
![]() ![]() ![]() ![]() 22153
Rep 21,247
- ill-fitting POS aftermarket engine oil filter (i.e. not a MANN or Mahle OE/OEM) - and only God knows what oil CarMax used and how much they filled the sump with; I changed the oil right away after my initial 200-mile road trip driving home from CarMax - low coolant level - crease in right front fender above headlight - incorrect sized battery and completely missing vent tube* - Engine air box half-full of shredded newspaper (from Cincinnati, OH) and shredded fiberglass insulation. A mouse made a nice home for himself in there - Broken-off storage door pin that closes the interior cubby light (behind the seats) - Cabin airfilter nearly fully clogged with decaying leaves and Poplar tree seed - Loose-fitting passenger-side B-pillar trim (**tabs broken from the audio system install I'm guessing) - Bondo on inner right front bumper * a missing battery vent tube on a used BMW is the tele tale sign the car was not maintained properly by a BMW tech/enthusiast. Good easter eggs: - **the PO had the audio system upgraded with an amp, speakers, and subs all from JL Audio (I knew this going in because there is a small JL Audio button sticker on the instrument panel next to the traction control button) - it had a fresh set of Pirelli P-Zero's RFT - CarMax brand front license plate holder (but I like it, so BFD); looks like the plate is floating in front of the bumper Yeah, CarMax has a 100-point inspection by "industry experts". LFOL.
Piper1748.50 |
| 02-20-2026, 07:23 AM | #49 |
![]() 92
Rep 225
I second that that you are the winner! AND the fact that Steeler doesn't remember whether consumed or threw it away, well......
If you want to be happy for a day, drink. If you want to be happy for a year, marry. If you want to be happy for a lifetime, drive a BMW Z4!
| Bookmarks |
