09-15-2018, 05:50 PM | #45 |
Rep 2,882
09-15-2018, 11:49 PM | #46 |
636
Rep 3,124
Why yes, yes it does. I think it adheres to the sides of the tube. I have to press my thumb against the air box to get enough force.
Once I yank it out it goes in and out fairly easily for that oil check. A week later it's stuck again. I've had limited success with Lithium or Silicone grease. Helps for a little while, but not for long.
XMetal1167.00 |
09-21-2018, 09:33 AM | #48 |
Rep 2,882
I 99% sure this isn't the case. As StickMon said, once broken loose, it goes in and out fairly easily for that oil check. Then it's stuck again a week later. It wouldn't act this way if the tip was the culprit.
09-21-2018, 06:24 PM | #49 |
Rep 97
Hmm, yes you may be right. But take a second close look at the tip in the last picture. The only place the plastic is damaged is at the very top end. The rest looks mint. This make me belive its catching an edge. Maybe its because rising engine temps expand the stick making it reach a ledge and get caught?
StickMon636.00 |
09-22-2018, 10:30 AM | #50 | |
Rep 2,882
09-22-2018, 11:24 AM | #51 |
Rep 202
Could the breaking of the tip be from not pulling the dipstick straight out for the entire length? If you pull the tip out with the rod at an angle, I can imagine that would put some undue stress on where the rod goes into the plastic tip.
2006 Z4 ///M, Interlagos Blue/Beige
09-22-2018, 12:23 PM | #52 |
636
Rep 3,124
Two separate issues.
The O-ring sticking is just an annoyance. The plastic tip gets stressed going around the bends in the tube. It will eventually break off, especially as the plastic degrades from heat and age. Mine seems to come out and go in easier with a half turn during the process. Hopefully that puts less stress on the tip, but it will eventually break off. You can see the crack in polar's last picture. Need to keep an eye out for that early sign. If ECS ever gets their stick the right length, keep in mind that their tip is crimped to the cable. Hopefully they do a good job of that. Word around is that the magnet in their oil drain plug falls out.
09-27-2018, 07:28 AM | #53 |
Rep 150
Before my tip broke off it showed no signs of weakness. I did, however, take it out for a while and left the short ESC dipstick in. Then when I went to check the stock dipstick that's when the tip broke off inside. Maybe keeping the stock dipstick in the engine helps and taking it out for any extended duration hurts? All I know is I'm not ever putting that plastic bit back in. ESC says "Your estimated delivery date is: October 29 - 31" and while this has taken so long I've bought a house in the interim, I'm holding out for their dipstick.
11-12-2018, 01:15 AM | #55 |
636
Rep 3,124
I have a crack in the top of the plastic bit of my OE stick. Not gonna last much longer.
Really interested in this, if ECS can get the length sorted, and make sure the tip won't fall off.
11-12-2018, 09:53 AM | #56 |
Rep 2,882
Yeah...I'm somewhat concerned about mine (OE stick) as well. Does anyone knows how that ECS bullet tip is being held on? I'm also concerned how that tip will last on there, especially if the braided line is made out of a different material than that tip.
11-12-2018, 10:39 AM | #57 |
636
Rep 3,124
I think it's safe to bet that it's crimped on.
And not safe to bet that it'll stay on, but maybe the lesser of two evils.
11-12-2018, 01:19 PM | #59 |
Rep 202
I saw the ones for S54's were now available and on sale. Hoping that these are suitable ones, not trying to clear out the bad stock. I guess I will find out, as I just ordered one. This purchase will let me know if I will keep shopping ECS or not.
11-12-2018, 05:11 PM | #60 |
///Multiple
2993
Rep 4,243
Just a couple more data points on ECS Tuning:
Last year I ordered new wiper blades from ECS which were supposed to fit an E85 Z4 M Roadster. The only way the new blades would go on was upside down! i sent them back and ordered elsewhere. Last month I ordered a charge pipe for my wife's '11 335is Coupe. I hadn't taken the old one off when I ordered but the description said that it would this particular model. The 335is has the N54 engine and there's only one charge pipe that will fit this engine. I took off the cracked charge pipe while I was waiting for the new one to arrive and as soon as I unboxed the new one it was obvious that it was the wrong one. I double-checked it on the ECS website and the one I got was supposed to fit. I sent it back (paid for return postage), got the part number from the cracked charge pipe and ordered a new one from getbmwparts.com. That one was correct. I'm already done with ECS Tuning. Used to order from them a lot. Do a Google search on ECS Tuning customer service and you'll see that they have had some real issues. Now under new management they claim that they're turning things around. Not in my experience.
11-15-2018, 01:46 AM | #61 |
Rep 1,130
I’ve been ordering from ECS Tuning for about a decade. Never had any issues with them. In fact, there’s been times that I miss out on a special deal or need help placing an order online. I call them up and they help me out taking care of the order and hook me up with the deal I missed. Just last week though, when placing the rod bearings kit order, I called ECS to find out why there was 12 hex bolts in the kit and asked them exactly where those bolts bolted onto. The guy over the phone said he couldn’t help me without the part number. I told him the website didn’t provide the part number for the bolts and I couldn’t look it up on realoem because it didn’t specify which bolts they were. He got frustrated and said “sir, if you don’t have the part number then there’s nothing I can do for you”. He was looking at the kit on his computer when he verified all the parts included, he just didn’t know the part number and placed the blame on me for not knowing it either. Other than that, no issues.
11-17-2018, 05:31 PM | #62 |
Rep 150
Good news boys, it seems like they got it right. The polished part on top of my dipstick had a nice gouge on the edge, but at this point I am cutting my losses and consider this a win. Also I am pleased to learn that after all this time my S54 burns no oil.
11-20-2018, 03:54 PM | #63 |
Rep 202
I just got mine in the mail. Looks to match up with the old dipstick just fine (sigh of relief). Got it on sale, so that also helps. The finish on mine was fine. A little smutz on it, but it rubbed off.
mainsoda171.50 |
11-20-2018, 04:24 PM | #65 |
Rep 202
I tugged and twisted the tip and it had no looseness to it.
