05-23-2008, 01:21 PM | #45 |
Rep 613
The coupe has, but the convertible has been out longer. Id be surprised if the 3.0 on the roadster doesnt share the same struts as the coupe. however I could be wrong, but then again I thought I was wrong once... but I was wrong.
05-23-2008, 01:23 PM | #46 |
Rep 15,083
Drives: '16 M2, '23 GT4
i looked into it and alot of components were not interchangeable
IG: Trackinheels
05-23-2008, 08:46 PM | #48 |
Rep 304
So it used to ride smoother than stock but now rides "like stock but not as bouncy".
Trying to determine if that means better than stock. My primary goal is to eliminate fender gap and secondary goal is to reduce the choppy bouncy ride. If the ride is less bouncy then it sounds like the ride is better no? Also in stock form the front seems to have a bit more gap which is why I was thinking coil-overs might be the only way to make them even. Yours look even in the pics - are they? I have also heard that the Eibachs make a clunk sound. Is this so? |
05-23-2008, 11:21 PM | #50 | |
Rep 240
-I would say the Eibach ride better than stock because elimanates the bouncy feel. The drop is perfect and even front & back.
-I haven't heard a cluncking sounds. -Am pretty happy with this springs, I was worry about the uneven front/back drop like H&R but the Eibach dropped perfectly. Quote:
05-23-2008, 11:23 PM | #51 | |
Rep 240
-I haven't heard a cluncking sounds. -Am pretty happy with this springs, I was worry about the uneven front/back drop like H&R but the Eibach dropped perfectly. |
05-26-2008, 07:26 PM | #53 |
Rep 1,541
i bought my springs from a local shop in Alhambra for $185 and i installed it myself - the rears should take you the most 30min per side.
2011.5 E92 ///M3 SSII/FR |
05-26-2008, 07:46 PM | #54 |
Rep 240
05-26-2008, 08:51 PM | #55 |
BMW Novice
69
Rep 237
Drives: M Coupe
Markers?
How did you paint the markers? What did you use??. BTW, it looks great
05-27-2008, 10:15 AM | #56 |
Rep 240
10-12-2008, 08:02 AM | #57 |
Rep 12
Could you just post the specs of the tires and the offset of the rims pls. I can see they are Bridgestone Potenza. Just cant tell what size. Thanks
Brilliant looking ride btw!!!!! Last edited by Tourist; 10-13-2008 at 05:58 AM.. |
10-16-2008, 01:27 PM | #58 |
Rep 12
Help required.
If anyone could help me out with my previous question regarding offset and tires, I would be really thankfull. PM to S2peed has been left unanswered. Cheers Sam |
10-16-2008, 02:36 PM | #59 | |
Smiling Politely
1384
Rep 29,118
nice volks ftw
