06-06-2017, 08:19 PM | #463 |
Rep 194
Drives: 06 Z4M Roadster
Garage List 2006 Z4MR [0.00]
1972 For Sale Datsun [0.00] 2001 Dog/kayak haul ... [0.00] 2010 Daily Driver H ... [0.00] |
Love the stockers, what type of Graphite Metallic w/ Matte Clear ? As in what was done, by who and it you don't mind sharing what type of price did you pay ? I'm looking to do the same and have done some research in resurfacing them. My stock wheels I love, but the paint/clearcoat is peeling in a couple spots and it's an eyesore that has to go. I wrapped them in a new set of Bridgestone Potenza RE-71 R's F- 235/40, R-265/35. Been doing some AutoX and the grip is amazing !
Topless and getting my degree
06-07-2017, 03:02 PM | #464 |
soon to be (hopefully) Z4M Coupe owner
14
Rep 22
Why the difference in width
I see lots of indications that people have wider tires in the front (i.e. 45) than the rear (i.e. 40).
Why less profile in the rear? |
06-07-2017, 05:28 PM | #465 | |
Rep 142
The second number is an aspect ratio; meaning that the height of the tire (rim to outer edge) is equal to X% (45% or 40% in your quote) of the tire's width. To maintain similar overall diameters of tires (Top to bottom), as you go wider on the rear tire, you must eventually step down in aspect. I have attached a tire rack comparison in case I am not explaining it right. As you go from a 245/40 to a 265/40 and 265/35, look at what happens to the overall diameter. http://www.1010tires.com/Tools/Tire-...0R18/265-35R18
Light a man a fire, you keep him warm for a night. Light a man ON fire,you keep him warm the rest of his life.
06-08-2017, 08:10 AM | #466 |
14
Rep 22
"Wider" was a bad word choice on my part, but you got the crux of my question. And I totally follow - embarrassed that I couldn't figure that out on my own.
07-25-2017, 11:02 AM | #467 |
Rep 114
I just got an email from a friend. He has an '07 Z4MC (stock suspension, no track use) and wants to run a 285/30x19 Conti Extremecontact Sport with a tread width of 10.2" on a 19x10 ET TBD but hasn't ordered it yet so there's room for adjustment. He says his goal is a no-rub fitment but hopefully w/o the tire sticking out of the wheel arch very much. He thinks from a 3/4 front view the rear body/quarter looks too narrow and that too much tire outside the quarter will look stupid and I agree totally with that viewpoint. I told him around an ET28 but figured I better run that by here with those who are/have run 285's. Thoughts?
07-31-2017, 09:25 AM | #468 | |
Rep 735
I painted the barrels from the back first coat and then reapplied every 8 minutes using a deck of playing cards between the tire and rim .... see YouTube. I am lucky enough to have a second set of rims so it made the job quite easy. I used two cans of paint and one clear and all in was less than $50 cdn and it looks perfect
Current ///M: 2017 M3 Ultimate Past ///M Cars: E92 M3 ZCP 'CDN LRP' … E85 Z4M-R ... E92 M3 ZCP Frozen ... E90 M3 ... E46 M3 Cab ... E46 M3 ZCP ... E46 M3 Last edited by scrammer; 07-31-2017 at 09:34 AM.. |
JJZ4MR30.00 |
09-12-2017, 09:02 PM | #469 |
Rep 194
As soon as I get my " all four off the ground/lift problems figured out, I'm soooo doing this, as well as painting the calipers with G2 Red from Amazon ( $ 43 kit ) I've discussed with Z4M driver that did his and he is very happy. Pics on here somewhere.
12-29-2017, 04:54 AM | #471 |
Rep 310
Tried 285/30 Contis on the rear on 18x9.5ET22 wheels, too wide a cross section, not enough wheel well width, way too much sidewall flex in transitions. Did look cool and fill out the wheel well completely but scuffed inside and out on dips and bumps that compressed the suspension on both sides. 275's are the functional limit for best handling within the wheel well limitations.
And you may ask yourself, "Where is that large automobile?"
01-02-2018, 11:15 AM | #472 |
Rep 335
Finally got my wheels and tires mounted. Apex 18 inch Arc-8 anthracite 9.5 inch rear rim with 275/35 and 245/40 on 8.5 inch front. No rubbing. Stock suspension. This size preserves the original rolling diameter.
01-09-2018, 09:11 PM | #476 |
Rep 46
01-23-2018, 05:54 PM | #477 |
Rep 835
Looking at the Apex ARC-8 wheels.
Are people running 18x9 ET30 up front without issues? I'd like the more concave wheels up front, but the narrowest size is 18x9. The 18x8.5 ET38 wheels are known to fit - but they're flatter, less concave. 245/40/R18 tires in both cases. |
01-23-2018, 08:25 PM | #478 | |
Ammar
73
Rep 406
18/9.5/et35 with Michellin PSS 255/35 18/10/et25 with Michellin PSS 275/35 Completely stock suspension. Mine doesn't rub at all.
2018 F150 Platinum - Black/Black - Leveled on 34's - DD |
ried793.00 |
01-23-2018, 10:27 PM | #479 | |
Rep 835
Would love to hear from someone with the 18x9" ARC-8 wheel with a 245/40/R18 tire. |
01-23-2018, 11:03 PM | #480 | ||
Ammar
73
Rep 406
01-24-2018, 12:14 PM | #481 |
Rep 272
Your sidewalls are too skinny. You can get away with these tire widths and 35-series sidewalls both F/R without rubbing, too. If you opt for the 245mm, a 245/40/18 would be the ticket.
01-24-2018, 12:21 PM | #482 |
Rep 272
This will work with nearly stock camber settings (-1.5° or so; obtainable with stock tophats) as it's only 1mm less aggressive on the outside than my car. The sidewall will be a little bit more square on the 9" compared to the 9.5", but it'll look great and work well. Go 245/40/18 - not a smaller sidewall as mentioned above.
ried793.00 |
03-11-2018, 07:26 PM | #483 | |
Rep 835
These are brand new fender liners and seem properly installed. Is this normal? Didn't think 245/40/R18 on an 8.5 inch front ARC-8 wheel would be pushing the limit here. It only happens at or near full lock, but still... |
03-14-2018, 01:59 PM | #484 | ||
Rep 335
