12-31-2011, 08:01 PM | #464 |
40
Rep 1,481
My Datsun 2.6 liter inline six was boosted to 15psi with a high compression head which was ported/polished and port matched. 3" stainless exhaust with zero 90* bends and a T4 turbo and it easily hit 525whp.
I would think the Z4M would be closer to 6-650whp ??....as the Datto began with less than 200 NA hp. |
01-01-2012, 02:57 AM | #465 |
Rep 5,329
your reading incorrectly... im saying we need to get our boost upto 9-10psi :-) as the other kit manufacturers @ stage 2 are running 9-10psi, and if you saying meth is too expensive to run as a daily thing then we WILL need a better intercooler, but other than the fuel system need to feed the motor, it cant actually see it being majorly expensive... then ess just fire us the vt2-550 tune.... job done.
01-01-2012, 02:59 AM | #466 |
Rep 5,329
vt3 uses 14 psi to make 650 crank afaik.
01-01-2012, 07:51 AM | #467 |
Rep 2,460
Is the bore different? Stroke? I know for sure you need Forged internals. I would like to think you can swap the internals without pulling the engine....maybe im dumb....I saw an s54 last week at the shop with its oil pan out.....everything seemed straightfoward from the bottom up.....err out...whichever....
01-02-2012, 03:56 AM | #469 |
Rep 5,329
i believe its just better rods, forged pistons and to the heights that you set.... seeing what the turbo guys are doing with bone stock s54's im pretty certain we could hold vt3 easily..... i have no problem running 8-10psi on this motor completely stock, its PROVEN solid.... time and time again, and for LONG term, i see 600whp cars on 50k plus milege cars reguarly.
dont forget the s54 is forged from factory..... and the iron block is perfect for big power!!
01-02-2012, 09:40 AM | #470 |
instagram 997turbotom
297
Rep 7,381
I'm excited about the amazing build potential for these cars. Makes me wanna keep it forever.
You know we can drop it to 2600lbs with a full carbon kit? ($20k USD) 3.5L stroker kit (~$4000 found used, $7700 new) VT3 kit ($$$$?) actually, the VAC stroker kit comes with forged internals http://store.vacmotorsports.com/vac-...-kit-p757.aspx gonna buy a house in a few years, and the start saving up.... lol
01-02-2012, 09:47 AM | #471 |
Rep 5,329
i wonder how much vt2-550 is for the z4m as an upgrade from vt2-500
01-02-2012, 01:46 PM | #473 |
Rep 5,329
yeah thats the issue, dont forget its new fueling as well, and the all important tune which unlocks the power!!
01-03-2012, 12:54 PM | #474 |
Rep 153
You guys are making the things sound so easy...
ESS changed the DME software, fuel pressure, injectors and IC for the extra 2 psi. I had the 83mm pulley with 500 it was rare to see 7psi. With the 80mm pulley of the 550 it is rare to see 9psi. Maybe is my AEM boost gauge that reads lower, but there some guys saying that see 10psi with the 550. The S54 is a piece of art with a very high CR and is very dangerous to run more than 10psi on just pump gas, even if it is 93aki or 98ron. To go higher than that it need to be race fuel or meth dependent. ESS policy follow the same rules than the top brand manufacturers with a huge safety margin to their products. Every dumbass can buy their kit and they have to garantee their good name in the market. I went to the vortech website and found a 79mm pulley that fits our blower...why boost is so addicted.
01-03-2012, 05:00 PM | #476 | |
Rep 1,603
Drives: Imola Red Z4MC
///M - Some Mods 'N Stuff
01-19-2012, 03:37 AM | #477 |
Rep 5,329
thought youd like this!!! Note wheel spin at the top of 3rd :-) quite impressive really!!
Maybe vt2-550 is the next move!! smg gearbox is slow as fuck though..... Really interesting to see AFRs and boost building in real life pulls..... note tiago isnt seeing 9psi.....
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 01-19-2012 at 04:00 AM.. |
01-19-2012, 07:09 AM | #478 |
Rep 153
SMG is slow but is at S5 mode. I already have a HPF stage 2 clutch ready for install. I'm just waiting that the OEM clutch slips a bit more. At least this way is more friendly for the transmission.
That is what i always complained. Barely saw 7psi with 500 and never saw 9psi with 550, but the power seems to be on par with other ESS vids.
01-19-2012, 07:45 AM | #479 | |
Rep 5,329
the car looks really quick anyway..... nice to see wheel spin high up in 3rd, i can see the car has some serious power....... 550 kit seems to make a nice jump in Tq from what i see!! here my boost gauge in "peak recall" mode Any pics of the Ess spec fuel sytem you run on vt2-550?
01-19-2012, 09:25 AM | #480 | |
Rep 153
IMO, the torque increase is more noticible with the 550 compared with 500, than the 500 over stock form because the boost come from a dead spot of stock power. The fuel system is just the fuel regulator. IIRC, stock is 5 bar and ESS is 3 bar. The injectors seems to be custom made and don't show the flow spec like the 500 kit injectors does.
01-19-2012, 09:45 AM | #481 | |
297
Rep 7,381
01-19-2012, 10:35 AM | #482 | ||
Rep 5,329
01-19-2012, 10:37 AM | #483 | ||
Rep 5,329
Vt2-500 injectors are from the e60 m5 :-) Can u grab a shot of your injectors please??
01-19-2012, 10:51 AM | #484 |
297
Rep 7,381
Don't you mean the vt2-550s are from the e60 m5?
