      02-20-2014, 02:28 PM   #23
M Theory
Drives: E46 M3
Should chime in for people considering these. I've had them since last summer and they're have worked great. I have the swift upgrades and radial bearings. If you're going to be fairly low, the radial bearings are a must, otherwise they can be noisy and annoying. If you're considering these for the street, pull the trigger. They are a great choice at this price point.
      02-20-2014, 02:50 PM   #24
R0ME0
"The Midas Touch"
R0ME0's Avatar
521
Drives: F87 LBB ///M2
2017 M2  [10.00]
2008 Z4M - SOLD  [0.00]
How do they compare to H&R coils in terms of stiffness, handling, and height adjustment?
      02-20-2014, 03:01 PM   #25
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
They are fully custom so stiffness is up to you, they are way more adjustable than h and r, and handling depends on how you set them up(spring rates, dampering setting, alignment)
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      02-21-2014, 12:31 PM   #26
M Theory
Drives: E46 M3
Redman pretty much covered bases here but want to add they go lower than H&Rs.
      02-21-2014, 01:12 PM   #27
Barryb97
Drives: 2006 M coupe
Think these would stand up to several track days a year?
CDV delete, clutch stop, BMW pedals, Strongstrut bar, CF rad & coil cover, M3 reps, roundel under hood, Intravee II, air bag sticker delete, first aid storage, painted reflectors, headlight washer disable, Skyer CF front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler and diffuser, oil pressure and water temp guages.
      02-21-2014, 02:46 PM   #28
M Theory
Drives: E46 M3
I'm sure they'd make it, but personally I would go with something beefier like clubsports or ast's.
      02-22-2014, 12:06 AM   #29
m5m3mc
Drives: M-B C63
Originally Posted by DRedman45 View Post
I went with 9k (503lb/in) front 11k (615lb/in) rear
Most people on here seem to run 500lb/in-550 up front and 600-650 rear, so that's why I decided to do custom. I'm sure the 10k all around would be fine for the street, but I do some autox and light track time.
These Fortunes really interest me. For a street application with 2-3 track days a year - with the goal of dialing out understeer - does 550/550 make sense to you (thinly crappy L.A. area roads)? Perhaps even 500/500. I'm not seeing 500/600 as perhaps ideal for what I want. FWIW I have H&R coil overs in my C63 and find them a little too soft, but great for a comfortable street ride.
      02-22-2014, 12:01 PM   #30
DRedman45
DRedman45's Avatar
35
Most people stagger front and rear spring rates on rwd cars, the softer front helps with front end grip and the stiffer rear helps rotate the rear. Either way you go it will feel stiffer than the h&r's because they use linear springs not progressive
My Build Thread
      02-22-2014, 11:28 PM   #31
E8SEHHX
E8SEHHX's Avatar
Drives: 06 GTO & 07 Z4M Coupe
Daily driven here. I have had mine on for about 8 months now and love em. Such a comfortable ride and not noisy at all. I got the swift spring upgrade and radial bearings. I also went 9 and 11. My car is dumped and I have no problems. I would highly recommend them.
07 BSM Z4 M Coupe | Fortune Auto Coilovers | Super Sprint V2 Headers| Epic Tune| RPI Exhaust | RPI Ram Intake | RE RaceBrace | ZHP Knob | CF Kidney Grills | CF Stubby | Work Meister M1R wheels | Mstache 2 | Euroboutique Shark Fin Diffuser
06 PBM Pontiac GTO M6 | 1 of 417 | BC Racing Coilovers | SAP Fascia | WCS Air Splitter | CF Rear Diffuser | GMM Ripshifter | Lingenfelter CAI
      02-23-2014, 03:59 AM   #32
m5m3mc
Drives: M-B C63
Thanks. My door sticker say 30F/32R tire pressure. I started there but over time I settled on 33F/30.5R. I like that MUCH better than the factory recommendation. I know that it's more complex than simply saying I just added 50# or 100# to the front spring rate but if I'm fine-tuning spring rates then it's figuring out the appropriate baseline starting point and whether my preference in tire pressures as stated above translates into an adjustment of spring rates for said baseline calibration, if that makes sense.
      02-26-2014, 09:13 AM   #33
p1nk50ck
HNIC
Drives: Z4M Coupe
the 500's are a street coilover that can see occasional track time. however, FA has multiple setups for different driving needs.
the 5th gen versions of the 500's can be upgraded to a dual canister setup for those who are a bit more track heavy.
unlike most other companies, these guys have a pretty solid website. i suggest reading it if you're interested.
http://www.fortune-auto.com/
      03-12-2014, 01:32 PM   #34
R0ME0
"The Midas Touch"
R0ME0's Avatar
521
2017 M2  [10.00]
Thanks for the review on this. Which vender did you pick yours up from and how much did you pay if you don't mind me asking? Looking to pick up a set as well
      03-14-2014, 01:16 PM   #35
Cybmx
Drives: 06 Z4MR
Can anyone recommend a place to get those Fortune500 suspension for the z4m? I went on http://www.broadwaystaticsuspension.com/ and it doesn’t seem to have the option for Z4m…
Thanks
      03-14-2014, 02:05 PM   #36
DRedman45
DRedman45's Avatar
35
Thanks
You can call them and they can help you, or fortune auto direct
My Build Thread
      03-14-2014, 02:07 PM   #37
DRedman45
DRedman45's Avatar
35
Also mine will be up fir sale sometime in the next couple months
My Build Thread
      03-14-2014, 02:22 PM   #38
E8SEHHX
E8SEHHX's Avatar
Thanks
You can call VEX Motorsports in San Jose, CA and ask for Anthony. He helped me with my order.
      03-14-2014, 02:23 PM   #39
E8SEHHX
E8SEHHX's Avatar
About $1500 shipped. Vex Motorsports in San Jose, Ca.
      03-14-2014, 02:34 PM   #40
E8SEHHX
E8SEHHX's Avatar
Or reach him at anthony@vexmotorsports.com
      03-14-2014, 03:17 PM   #41
PLCZ4MC
Proud E86M Owner
PLCZ4MC's Avatar
Have some one got the 500 for a Roadster with costume springs? When I ask Fortune witch set up I should go for they told me the stock one is the best choice? Should I just go for the stock or get customize springs? Roaster Daily car, few track days 4-6 times during summer months.
2007 Z4///M Coupe Monaco Blue (Weekend + Track)
2018 S1000RR San Marino Blue Wrap (Weekend + Commute)
2016 Honda CR-Z EX Jet Black (Daily Commute)
2008 Kawasaki ZX6R Plasma Blue (SOLD)
2008 Z4///M Roadster Space Gray (SOLD)
      03-14-2014, 03:23 PM   #42
DRedman45
DRedman45's Avatar
35
I did a bit of research on what people run before I ordered mine, if recommend the same, and not their rates
My Build Thread
      03-14-2014, 03:25 PM   #43
The HACK
The HACK's Avatar
1821
The staggering spring rate is because the rear springs sit further away from the center of the wheel, or closer to the fulcrum/pivot point of the suspension thus requiring stiffer rear spring to produce the same wheel rate for front AND rear.
Equalizing the front and rear spring rate would actually result in more pronounced understeer IMO.
      03-16-2014, 06:31 PM   #44
R0ME0
"The Midas Touch"
R0ME0's Avatar
521
2017 M2  [10.00]
Did any of you guys upgrade your rear camber arms and end links with the fortune coil overs? I know some of you went pretty low and are running more aggressive setups. Feedback would be nice. Getting ready to order mine! Thanks!
