09-22-2011, 02:09 PM | #23 |
Rep 2,138
Drives: Me
I would not bring my ///M up here because I cannot care for it properly and since I have a rental car. Plus, I have an issue where I cannot see the path through the cone field. The limitation is mine....
09-22-2011, 04:00 PM | #24 |
Rep 12,570
My first few sessions were like that but as I forced myself to look 3 turns ahead, the path became apparent. Plus having an instructor the first run or two helps.
09-22-2011, 09:02 PM | #25 | |
Rep 1,373
I will be at NJMP on October 8/9th with the PCA
07 Z4 M Coupe AW/IR |
09-29-2011, 08:07 AM | #26 |
Rep 196
I'll be at lightning the 16th and 17th. I'm debating on Summit for the following weekend but will probably join PCA for a late oct early nov at thunderbolt.
10-13-2011, 09:51 PM | #27 |
Rep 1,373
I will most likely be at NJMP for the early November Schattnebaum PCA event
10-16-2011, 09:13 PM | #28 |
Rep 12,570
Had fun today, saw maybe 5 other e86's including Sabbnick. The track got crowded at times but nothing feels better than getting th point by from a gt2 and 458!
10-17-2011, 07:18 AM | #30 |
Rep 12,570
Definitely... decided to do one more, trying to convince Andrew to do Summit with NASA MA in Nov.
10-17-2011, 10:31 AM | #33 |
Rep 12,570
You can't unless you get a rollbar so best bet is to then find a club that lets verts run in general, PCA and NASA tend to be the vert-friendly ones although there's always a chance that a region-specific rule may say otherwise (so check with your local clubs). CCA is a def no no, SCCA not sure.
02-29-2012, 04:07 PM | #36 |
Rep 505
