07-01-2011, 12:54 AM | #23 |
Rep 53
07-01-2011, 03:36 PM | #25 | |
Rep 416
Im trying to figure out if the Stock carver amp will have enough juice for the speaker replacement up front. I would like to replace the 2 mids in the rear seat too and unplug the subwoofer. What is your take on this since you seem like you know what youre talking about? |
07-04-2011, 02:44 PM | #26 | |
Rep 53
The rear mids are very difficult to get to and you're not going to be able to get much out of such a small speaker. Mine are disconnected. Again with a small cabin there is not much need for rear fill. Purely preference though. I can't really say about the stock amp. Make sure you check the impedance. The stock amplifier also has the crossover circuitry internally so you will have no choice but to use summing interfaces to hook up aftermarket components if you wish to use their crossover. I don't know what the stock crossover points are. At the end of the day I decided to just replace everything and it was without a doubt the correct approach. |
07-04-2011, 03:00 PM | #27 | |
Rep 820
Drives: 2007 Z4MR silver grey
John |
07-26-2011, 06:55 PM | #28 | |
51
Rep 397
I had a 400 watt RMS amp, and a 10" in the back. Took up very little space. Well recommended. This was my install http://www.zpost.com/forums/showthread.php?t=248228
07-27-2011, 10:19 PM | #29 | |
Rep 416
08-02-2011, 10:57 PM | #30 |
Rep 1,107
I've had my roadster now for 3 month's now. It has the NAV/DSP Carver system. I've been slowly planning my system upgrade, I say slowly because the stock system is not horrible...certainly lots of room for improvement though.
I can't believe how the system is engineered/configured. Subs? Is that what those are? Subs are supposed to put out some bass. Just tonight I finally had some time to while away and I figured out that the "Subs" fade with the rear speakers. You think whatever bottom end the system has comes from the Subs? Dead wrong, it's from the kick panel drivers. Do this test, put on a nice bass filled test song. Make sure your equalizer setting is at least flat across the board, now set the fader all the way to the front. Sounds ok, right? And it's got some decent bass. Now, move the driver's seat and seatback forward and get an ear next to one of the subs....NOTHING! No sound. Now set the fader all the way to the rear and get an ear next to a sub again. There is some sound coming from the subs...but it's definitely not bass and the level is incredibly low. Absolutely worthless. Am I alone in this conclusion regarding the subs? They literally produce very little sound...even if I push the 80hz equalizer band setting to full tilt. Can someone who has the Nav/DSP system like mine confirm this for me? Maybe there is something wrong with my system. None the less, I'm thinking of using a JBL-MS8 on the back end of the OEM amp, re-using an amp I have, reusing a set of CDT 3-way separates for the fronts, and maybe another amp and Tang Band subs in place of the OEM subs. |
08-03-2011, 12:29 AM | #31 | |
Rep 820
John |
08-03-2011, 07:56 AM | #32 | |
Rep 1,107
My only unknown right now is finalizing what sub to use and how to finish the existing sub enclosure with it. I want to use the existing mesh cover, so depending on finding a sub that will fit and will work with the given volume of the enclosure.....a project. |
08-03-2011, 10:25 AM | #33 | |
Stupid as shit
26
Rep 367
08-05-2011, 12:25 AM | #34 | |
Rep 820
John |
08-05-2011, 01:45 PM | #35 |
Rep 1,107
Looks like I'm going with plan "B" first
I got a good deal on a new JBL-MS8 ($500 shipped). So far my strategy is as follows: 1. Hook up the MS8 to stock speakers just for sh*ts and grins 2. Swap in my CDT HD-642's in the fronts running just off the MS8's internal amps just to see how that sounds 3. Add an amp, with the MS-8 amps running the tweets and the amp running the mids and mid-bass' 4. Add another amp and subs Will probably start in on it around Labor day. Nothing quite like pulling a perfectly good car all apart |
08-05-2011, 09:00 PM | #36 | |
Rep 820
08-05-2011, 10:06 PM | #37 | |
Rep 1,107
08-06-2011, 12:01 AM | #38 | |
Rep 820
http://www.crutchfield.com/s_161DQL8....html?tp=37274 |
08-11-2011, 03:42 PM | #39 |
Rep 165
Well I guess you can keep throwing money at it and allow your brain to think you have a great sound system. It can never be true audiophile quality in this car - even if you throw tons of dynamat and subs and other shit to it. Yeah, it will be loud, boomy or whatever, but it will never be audiophile. Never.
08-11-2011, 05:10 PM | #40 |
Rep 416
well, it would still be nice to have mid bass. That is all im lacking. the notes from the highs sound great stock and i have nice bass from my Sub. I just want the mid bass that is lacking in music that fills up the rest of the song. Mid bass is usually the bass guitar of alternative and rock music
08-11-2011, 11:03 PM | #41 | |
Rep 1,107
08-15-2011, 06:39 PM | #42 | |
Rep 152
Just as a heads up, the CDT-HD642 4" mid won't fit in the door. I just tried it this weekend, I ended up drilling another hole in the frame of the 4" to match up with the funky bolt pattern (2 of the 3 originals line up no problem) but when I put the door panel back on the speaker was too deep. The original ~3.5" speakers that are in the door are only 1.75" deep, the CDT 4" mid from the HD642 set is 2.25". You could maybe get away with a 2" deep mid, anything else would be pushing it.
I have some Diamond audio 3-ways sitting around, but I didn't feel like trying to hook up that 4" though it was only 2" deep. Quote:
08-15-2011, 10:27 PM | #43 |
Rep 1,107
I can't thank you enough for this info, really. I planned to, but haven't gotten around to pulling the door panel yet and confirming whether the 4" would fit and I may have missed checking the depth. I'll have to investigate other options now for the mid in the door. Perhaps the CDT 3" which is a little shallower or something else.
Again, thanks for letting me know. BTW, you didn't happen to check the depth on the install of the HD-6 mid-woofer in the kickpanel, did you? Last edited by elerner61; 08-16-2011 at 12:09 AM.. |
08-15-2011, 11:14 PM | #44 | |
Rep 820
