      04-09-2011, 01:43 AM   #23
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
wow so with shorter tires, I might be able to fit 255's...interesting indeed!
I think I'm currently using 245/35/19's. That means, I'd need to look for 255/30/19's? Hrmm.....therein lies the issue haha. Will hafta tire shop next time around
      04-09-2011, 09:12 AM   #24
F360C
Drives: E86 S54
Originally Posted by cmark8 View Post
I'm already running 255/35/18 up front and it grips just fine. Problem is I have no idea how the nt05 run (wide or narrow), so I decided not to risk with 265/35... and they don't make 255/35/18s. I will report back as soon as I get them out in the track @ LVMS later this month!
Nice! I didn't know you were also running the 255 front. I am running a 255 R888 and it has a diameter of 25.1" and a width of 10.2". The 265 NT-05 has a width of 10.59 and a diameter of 25.31. So it is a bit wider then my 255 R888 but I did try to get a 275/25/18 R888 to fit up front last weekend and it was just a hair off from fitting. I mean just millimeters away from fitting. Th 275 R888 has a width of 11" and a diameter of 25.7". I don't know if you ordered your tires yet or not but based off this I think the 265 would fit. I know there is a guy on here running 265/35/18 Pilot Sport Cups and they are 10.9" wide and have a diameter of 25.2".
Yep go for the 255/30/19. It is what I am running up front on my street wheels. Fits perfectly. Interestingly I mounted my rear OEM ZCP with a 275/30/19 front tires on the front last weekend and it fit perfectly also. I think I will be changing to run four OEM rear ZCPs in the near future.
07 Z4 M Coupe AW/IR
      04-09-2011, 10:35 AM   #25
dorifto88
Drives: 88 Nissan Pathfinder
Game-plan changed... gonna run NT05, because it's just out of this world cheaper than other brands. I was researching and everything was approx. 1k or more... and NT05 I'm getting them for 734 shipped. No-brainer. If it's good, I'll keep them, if it's not great, then I'll use them for street.
whoa a set for 734 thats dope status ! whered you order from? and what rear sizes did you end up ordering?
      04-09-2011, 10:39 AM   #26
cmark8
M52, M62TU, S50US, S54, S65
cmark8's Avatar
75
Drives: E90 M3 6MT, E36 Touring MT
I got them from discounttiredirect... and I got 245/40/18 up front and 275/35/18 rear. I should've bought the 265/35/18 for the fronts though .
I didn't know we could squeeze in so much beef up front! What offset should we run to make 265 or more up front and with how much camber? Also, where do you get the overall diameter info for each tire F360C?
1995 E36 M3 USA / 2002 E46 M3 SMG / 2008 E90 M3 6MT
1996 E36 328i Touring 5MT / 1998 E36 323Ti M Sport 5MT
2002 E39 540i Protection
      04-09-2011, 10:49 AM   #27
dorifto88
http://www.nittotire.com/index.html#...ire.nt05.sizes
      04-09-2011, 11:08 AM   #28
cmark8
cmark8's Avatar
75
Thank you! I'm on the phone with discounttiredirect changing my order! 265/35/18! Overall diameter is smaller than the 245/40/18, downside is... it went from dirt cheap to just cheap . 112 dollars extra! Hahaha!
Now my order is 265/35/18 and 275/35/18.
      04-09-2011, 11:12 AM   #29
dorifto88
yeee... you GOTTA let me know if 265s fit in the front lol. i ordered my 275 rears but didnt order fronts yet cause i was waiting for someone to try the 265s !
but you have coils and i have just springs so im thinking you have more clearance =/
      04-09-2011, 11:37 AM   #30
cmark8
cmark8's Avatar
75
get the turner motorsport shim kit! that will give you more neg camber and you should have more clearance.
      04-09-2011, 12:17 PM   #31
dorifto88
i already have a shim kit, just worried about inner strut clearance =/
      04-10-2011, 01:41 AM   #32
mfanatic325
///M-fanatic
Taiwan
193
YeeYuh! DTD is what I recommend to all my car friends
      04-10-2011, 07:14 PM   #33
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Where you getting them from ? I'm about to get NT01 and they're about $250-300 more, I wish they were closer priced but at the track if you're an advanced driver there's a big enough difference in grip IMO to warrant the extra $$$.
2004 Porsche GT3 |White
HRE R40 Monoblocks | KW Clubsport Suspension | RSS Lower Control Arms and Suspension Links | GT3RS Wing and Front Bumper | Cup Car Lip | Euro GT3 Seat | GMG Half Cage | Europipe Exhaust | EPL Tuning
      04-10-2011, 07:56 PM   #34
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
I think he's getting them from DTD (DiscountTireDirect).
A set of NT-01s (245/40-18 & 275/35-18) are 907.54 Shipped from there.
      04-10-2011, 09:28 PM   #35
cmark8
cmark8's Avatar
75
discounttiredirect.com! Well, I'm not a track expert, thus I don't want to go with R888 or NT01 so I won't get used to bad habits. But nonetheless, I'm very satisfied with my purchase. Can't wait to mount these tires!
      04-15-2011, 08:01 PM   #36
cmark8
cmark8's Avatar
75
Update: I just got these tires mounted to my apex and they look gorgeous! I have a little problem though... my rear tires (275/35/18 on 18x10 et25) are rubbing on the fender on sharp turns. up front, no rubbing, no nothing with 265/35/18 on 18x9 et42. So what should I do? Should I raise my car or should I roll my fenders?
      04-15-2011, 08:15 PM   #37
johanness
Drives: 2008 Z4MC
Wow but your fronts fit w no issues. Now that changes things.
      04-15-2011, 08:15 PM   #38
dorifto88
dope dope news !! do you think someone with stock springs would rub with 265's in front? and, how much camber are you running in the front anyways?
      04-15-2011, 08:49 PM   #39
cmark8
cmark8's Avatar
75
I'm not sure if someone with stock springs would rub... with the drop my car sits at -2 degrees camber... I was thinking of adding the shim kit from Turner to go -3 degrees, but I would have to run spacers to avoid touching the strut tower.
      04-15-2011, 10:49 PM   #40
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
I put my wheels on today.
18x9 +42 with a 245/40/18 NT01 , I've got a BBK which clears no problem, but am running 4 degrees of camber, so I had to add a 12mm spacer to clear the inside of the tire away from the strut (TCK Coilovers), appears to be no rubbing now. These tires have a wide contact patch for sure.
18x10 with a 275/35/18 NT01, absolutely no issues, car sits very nice all the way around.
Can't wait to get out on the track tomorrow and see if I can make good use of the extra grip (was at the limits of the NT05, especially in Advanced Solo where I'm chasing people on R6's and blues trying to fend off the red myst).
      04-16-2011, 07:39 PM   #41
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
245/40/18 and 275/35/18 are NT01 working great for me at the track this weekend. Running a 12MM spacer up front to clear the shock with 4 degrees of camber (could likely get away with less spacer but didn't have anything hubcentric available smaller). Rear 275/35/18 are rubbing just slightly on the inner fender, a quick baseball bat roll job should solve this (It's literally just barely shaving the sidewall vertically).
Compare tire specs, I would be less concerned with the size, and more concerned with overall diameter and contact patch, these NT01s are very wide given their specs, and the traction shows.
      04-20-2011, 01:53 AM   #42
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Good to know, thanks! On the rear, with the 18 x 10 ET 25 and just to confirm, it's a tire rubbing issue given the NT01s dimensions, etc., not the wheel itself, correct? There's an APEX 18 x 9.5 ET 22 out now, and if the 10s (wheel itself) rubs, I might consider those over the 10s (they're a pound lighter too).
The NT01s like a lot of camber too IIRC. -4 up front might be a bit much for Star Specs or NT05s I think and -2.5 to -3.0 might be a better setting given those tires, yes?
      04-20-2011, 09:44 AM   #43
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
I think it's likely the tire, the NT01s seems to run VERY wide. It's VERY minimumal rubbing on the rears, as in the slight 1/2 lip on the fender is rubbing down the sidewall, but nothing were it's cutting it. A few passes with the fender roller should do the trick. On my street HRE wheels I run a 245/35/19 and 275/30/19 NT05 with absolute no problem.
I ran -4 up front with the NT05s for 6-8 track days and found they love the extra camber as well (I actually got 12-13k miles + 4 or so track days out of my first set of NT05s running this setup with limited toe) . If you're driving on the street, obviously go less, but for the track, these cars love front camber.
      04-23-2011, 08:59 PM   #44
cmark8
cmark8's Avatar
75
Ran the NT05 today on the track and they performed less than what I expected. The weather was around 90 degrees outside and the tires were greasing up very fast. I guess I'll use them as my street tires and buy Hankook rs3
Tags
hankook rs3, track, yokohama advan ad08
