Thread Tools |
| 04-08-2026, 12:20 AM | #24 | |
![]() 205
Rep 171
Clay bar is a way to mechanically decon the paint. Generally you’d want to do some chemical decon with a strip wash and Iron Remover, then move to clay bar or a clay towel to remove what the chemical process didn’t. This can help to remove residual protection as well as contaminants from the paint. After decontamination you want to buff and/or polish the paint. Any imperfections such as scratches and swirl marks will be covered by the coating and therefore locked in for the life of the coating. Going through the paint decon before polishing makes it easier, and ensures you’re not picking up contamination on the polishing pad, which would then scratch the paint. Eg. Tiny iron filings imbedded in the paint from your brakes. But every car is different. Sometimes you don’t need to clay, or need to buff, or need iron remover. It depends on the condition of the paint. |
broniel3.00 tracer bullet6001.50 |
| 04-08-2026, 03:50 AM | #25 | |
Enthusiast
Rep 7
| 04-08-2026, 07:12 AM | #26 | |
![]() 4427
Rep 2,355
Drives: BMWs, duh
The idea is to do the whole shebang a couple of times a year and then do "maintenance washes" in between to keep it in good shape. The cleaner you keep the car in general the longer your coatings, etc. will last. The worst thing you can do is to leave stuff like bird droppings and tree sap on the paint for any appreciable amount of time. That shit kills coatings and paint. Hope all of that makes sense. *Don't freak out - you take off very, very little clear coat when you buff the car, so we're talking decades of buffing here, not years. If you have the car 15-20 years from now this is something to start considering. With the caveat that... **It somewhat depends on the type of car. Some makes have "softer" paint than others, meaning that the manufacturer's paint composition is literally softer, and/or they use a thinner clear coat layer than others. Again, this probably isn't really something to be terribly concerned with in the short- to mid-term, but it's a thing. As the car gets older you can use a paint gauge to judge how much paint is left on the panels in order to make an informed decision as to whether or how much to buff the car. If I'm off on any of this someone please feel free to correct/clarify, but this has always been my understanding and has served me well for quite some time. |
| 04-08-2026, 09:15 PM | #27 | |
![]() 262
Rep 147
Drives: 2026 Z4 M40i Handshalter
Started with a strip wash. Then chemical decon, Iron remover Another strip wash Then synthetic clay bar, Pan's new one One step paint correction Panel prep, CarPro Eraser Then ceramic coat. Pan's 8 year The next day I did the wheels: Heavy duty wheel cleaner Then a strip wash Panel Prep, Car Pro Eraser Then ceramic coat, Gtechniq Wheel Armor I still have to do my top with Ragg Top Thanks, Mike |
Phillies80084426.50 tracer bullet6001.50 |
| 04-08-2026, 11:59 PM | #28 | |
![]() 205
Rep 171
I tried the Adam’s Prep spray, as it came with a kit I bought, and that product left the paint very clean. You can actively watch it evaporate and not leave anything behind. I have a bottle of Gtechniq panel wipe here as well to try. I have Wheel Armor waiting for use this season. I’ve heard good things! Last edited by fiveightandten; 04-09-2026 at 12:22 AM.. |
| 04-09-2026, 12:15 AM | #29 | |
![]() 205
Rep 171
Clay picks up solids that have been imbedded in the paint, which then are imbedded in the clay. As you rub the clay on the paint, there’s potential for fine scratches from those particles being rubbed on the paint. So make sure you knead the clay often to reveal fresh material. And move to a new piece when it looks dirty. If you hear solids being dragged across the paint, it’s a good idea to stop and pick it out of the clay. But it’s generally pretty safe if you are careful with it. And use common sense; if you drop the piece of clay, it’s garbage the moment it touches the ground. There are different grades of clay with the softer stuff being less aggressive. The same is true of clay towels. They’re less aggressive than clay bar, but can be more difficult to tell if you’ve picked up something abrasive, and harder to tell when they’re getting dirty. And they’re generally less effective for stubborn areas like the edges of side skirts / leading edges around wheel wells. You’ll find the rear bumper and the areas right behind the wheels to be the areas most likely to need clay. |
| Bookmarks |
