01-20-2009, 08:46 PM | #23 | |
Rep 339
http://www.hookedonphonics.com/ there ya go |
01-21-2009, 07:59 AM | #24 | |
Rep 4,726
01-21-2009, 08:57 AM | #25 |
Rep 164
The KW as just as good as the Tckline on the street. If using street tires and don't do a whole lot of track day. You just put them on the car follow the KW setup guide and your on your way.
The TCkline are better on the track only because of stiffer spring rates. However most people don't have any clue what spring rates work on their car listen to others that also don't have a clue and most of the time end up with too stiff a spring rate dampers that may or may not be valved properly for the springs. You have to know what you are doing to make the TCkline work well. The same goes for Ground Controls. Another option is the KW Clubsports. They are more talored for the track. KW did all the R&D and made an excellent coilover kit that works on the car. No need to guess at spring rates or shock damping. KW uses a shaker rig and actual testing on cars to come up with what works. KW simply as a much higher level of R&D than the other companies that make coilovers for the Z4M. |
01-21-2009, 11:17 AM | #26 | |
Rep 4,726
Unfortunately all that "R&D" is useless if your car is not like theirs. Depending on what tires you are using both compound and width alone will throw off that "R&D" and necessitate different spring rates and dampening. Let alone if you have rollbars or drop the car to a different height then their test car. And I'm really not being a TCkline leg humper here. But there is no comparing KW V3s with TCkline DA system for tracking (these are the same "trim" systems) I'd say the KW club sports are great, I'm sure comparable to the equal "trim" ones that tckline offers which are a step up from the DAs. I have no comment on to which is better as I don't have experience with either. But comparing the KW v3s and TCK DAs the better track setup is unarguable.
