05-05-2023, 09:26 AM | #2795 |
Rep 12,570
New shoes, love my style 32’s but they unfortunately don’t clear the 996 Brembos I plan to put on, so needed something with better spoke clearance. Preference was to stick with OEM staggered setup (225/255) with slightly aggressive offsets.
F: 19x8.5 et27 R: 19x9.0 et29 + 15mm spacer Currently on stock suspension / alignment but I plan to pull the pins and add some washers up front. Last edited by 3002 tii; 05-05-2023 at 02:58 PM.. |
05-05-2023, 06:17 PM | #2797 |
Rep 66
06-02-2023, 12:56 PM | #2798 |
Rep 12,570
Received my refurbished steering wheel from Royal and I have to say it was worth every dollar (or pound). Tried alcantara before but wanted something more OEM-ish. The perforated leather really enhances the look and feel.
06-02-2023, 03:24 PM | #2799 |
Rep 978
Hi, did they wrap over or removed the og wrap. Is the wheel rim any thicker?
06-02-2023, 04:30 PM | #2800 | |
Rep 12,570
The wheel does not feel any thicker but it feels heavier. But that could honestly be a placebo effect in trying to compare against something that is normally attached to car. It’s just when I pulled wheel off first time it felt pretty light compared to what I got back from Royal. Not sure if helpful… |
E93Seattle (Racerbruce)799.50 |
06-05-2023, 09:49 AM | #2801 | |
Rep 978
06-05-2023, 11:24 AM | #2802 | |
Rep 103
2007 Imola Red Z4M
2005 Phoenix Yellow M3 6MT 2013 Interlagos Blue M3 6MT ZCP CF roof |
06-05-2023, 11:49 AM | #2804 |
Rep 12,570
They are style 641, which are not very common as it was marketed as the recommended OEM winter package for the F80 m3/4. The reason I like them is because as you noted, they’re similar in design to the 224s so it looks like an updated 19” version of the factory M wheels. And functionally, the winter wheel offsets tend to be slightly more conservative so they fit great on our cars and really address the weak-ish offsets on our factory fronts .
The 224s have grown on me over time but ultimately, I wanted something bigger to fill out the big brakes I have waiting to be installed so this was perfect for me. |
06-05-2023, 11:55 AM | #2805 | |
Rep 103
06-05-2023, 02:33 PM | #2806 |
Rep 12,570
Agreed the 326 remind me of a cross between 641 and 351. Here’s a more close up photo of the 641 I found online.
07ImolaRot134.00 E93Seattle (Racerbruce)799.50 |
06-09-2023, 11:12 AM | #2807 |
Rep 2
Drives: BMW Z4
New set of plugs and coil packs.
Glad I did after seeing the old plugs. 15 years and 43k miles they definitely needed to go. |
3002 tii2303.50 E93Seattle (Racerbruce)799.50 |
06-13-2023, 07:26 PM | #2808 |
eldortch
Rep 1
Hello everyone, I'm new to the forum. I purchased my 03 z4 last week. It had sat up about 7 years without running. After new platinum plugs, full synthetic oil change, thermostat, water pump, and rear brakes, she's on the road again. New issue to deal with is what I think is called sticky steering. The steering light is on when I start the car. As I start to drive, the steering kicks in, light goes off. Until the next time. Any help or advice you have is appreciated.
06-23-2023, 08:53 AM | #2809 |
Petrolhead
445
Rep 814
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Car slowly going through interior transformation from beige to black (+ sport seats).
For now, switched out the stock steering wheel and shifter to new M parts. Also just received my BlueBus and couldn't be happier with it. Love the integration and sound quality.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
06-23-2023, 04:59 PM | #2811 | |
Rep 583
greetings 3002
style 313's look somewhat similar and are very attractive: http://www.bmwstylewheels.com/bmw/313 i am grateful my new ride has this specific rim - i love the thin spokes, double spokes, and very small hub/bolt center that allows "less is more" and reveals the rotors, etc: |
06-23-2023, 11:08 PM | #2812 | |
Rep 12,570
06-23-2023, 11:13 PM | #2813 | |
Rep 918
Andre - 2J into a Z4 Coupe!
06-24-2023, 05:40 AM | #2814 | |
Rep 583
you've had a set of 313's; were they 18 or 19's? mine are 18's; i have read quite a few posts that the 313 19's were cracking @ rim areas; the supposition from the posts were from the run flats that are oem on many of the 335 series; as you know, run flats have a stiffer sidewall and are less forgiving and this + a 19 inch tire with very limited sidewall height = significant impact on rims during city driving (potholes, etc). quite a few posts were from 335 e93 (retractable/hardtop) owners; the e93 option added appx 400 lbs to the car placing the 335is e93 (my car) @ 4,000 lbs.... i have not experienced any cracking on my 18's and (regrettably) still have run flats at this time. were your 135is's rims 18 or 19? the "is" series is pretty rare; tell me about your previous ride - would love to hear it. regards |
06-26-2023, 08:19 AM | #2815 | |
dances with roads
4763
Rep 4,100
06-26-2023, 05:11 PM | #2816 | |
Rep 12,570
