      12-30-2013, 09:22 AM   #221
tikamak
Lebanon
58
See guys? beedub has nothing over there :S
only the connection from engine to catch can then back to intake.
      01-10-2014, 04:48 AM   #222
tikamak
Lebanon
58
Nothing? no one knows why my car and beedub's are different?
      01-10-2014, 01:04 PM   #223
Gt4
Gt4's Avatar
Drives: 2006 E46 M3 Estoril blue 6mt
Originally Posted by tikamak View Post
E46 M3s don't have that. check some S54 pics online. it's a bit wierd :S
I'm not able to find the fuel rail part number that has a T with a valve in it towards the top of the cylinder head, where all the steam escapes (is that PCV or ICV or something like that)
Later model production of E46 M3 also have this connect to the PCV
      01-11-2014, 07:14 AM   #224
Beedub
well apparently this limp issue is done and dusted??? would be really nice to see an update on here from ess officially!!!
http://www.m3forum.net/m3forum/showt...430966&page=10
      01-11-2014, 10:31 AM   #225
Gt4
Gt4's Avatar
I can't wait to see what was the problem and if they fix it for real.
Because back in 2009, they were having the same issue on the CRF500 kit on Earl/Palantirion's car (bimmerfest forum ) and were sure it was heat related.
      01-11-2014, 12:43 PM   #226
gmd2003
gmd2003's Avatar
356
I'll believe it when I drive it lol
      01-11-2014, 01:59 PM   #227
Beedub
the customer service Re this has been completely SHITE..... imo...
      01-11-2014, 04:41 PM   #228
gmd2003
gmd2003's Avatar
356
the customer service on Re this has been completely SHITE..... imo...
Beedub shit is wayyyyyyy to kind . It took me almost buying the farm for them to even take it serious .
      01-12-2014, 11:14 PM   #229
pandusr
pandusr's Avatar
Italy
Drives: BMW Z4M Roadster ESS CFR 525
Confirm fault with CFR525 kit.
Flaw only in low outdoor temperatures (carburetion?) despite increased oil and water cooler.
No longer happened since I deleted the kat.
You may be reading the exhaust gas temperature probe? Kat = Cap?
Z4M E85/2006 || ESS CFR525 || AEM Water / Methanol Injection Kits || Supersprint Exhaust (catless,XPipe,rear exhaust race) || 4.10 || front brake AP Racing 6 piston kit (cp5575-1010) || K-Sport suspension with camber plates || Sparco Pro2000 seat || 6 pti Sparco belts -|| Hankook S1 EVO 1 (front 245/35 19 - rear 275/35 19) || OZ Racing Ultraleggera HLT 19"
      01-13-2014, 04:28 AM   #230
Gt4
Gt4's Avatar
You mean the catalytic converter? In headers and section 1 too?
      01-13-2014, 02:20 PM   #231
pandusr
pandusr's Avatar
Italy
My Z is a European model without catalyst in headers.
I deleted the only catalyst present in the section 1 with front pipe Supersprint (http://www.supersprint.com/en/IT/pro...2i___06__.aspx).
      01-13-2014, 04:13 PM   #232
gmd2003
gmd2003's Avatar
356
Well I have no cats and still have the limp . Talked to Roman today and he says the fix they implemented was installing a true vacuum pump for the brake booster system . I don't understand why this works when placing a check valve does not ???? Anyway it HAS NOT been track tested yet , so I'm pretty skeptical at this point . They installed it on the EAS shop car . I hope they really beat on it like I do to see if this works lol .
George
      01-13-2014, 11:21 PM   #233
pandusr
pandusr's Avatar
Italy
Originally Posted by gmd2003 View Post
Well I have no cats and still have the limp.......
Ok! Then mine is a randomness. I had thought of exhaust gas temperature sensor with inconsistent readings with ecu.
...... Talked to Roman today and he says the fix they implemented was installing a true vacuum pump for the brake booster system . I don't understand why this works when placing a check valve does not ???? Anyway it HAS NOT been track tested yet , so I'm pretty skeptical at this point . They installed it on the EAS shop car . I hope they really beat on it like I do to see if this works lol .
George
I'm stumped too. VF Kit 570 has vacuum pump? I don't think so. Because they have no limp mode?
Gabriele
      01-14-2014, 12:50 AM   #234
StickMon
StickMon's Avatar
Drives: 2006 MR
If loss of brake boost is what's causing the limp mode, whether it happens or not would be a function of whether you're out of the throttle and under vac enough to keep up with the vac the brakes are using.
I think that could vary quite a bit depending on the nature of the course, and driving style.
If you heal-toe or trail brake you may be consuming vacuum faster than you're creating it.
Sounds like it's at the hairy edge between fine and limp mode.
Lifting just a fraction of a second earlier or later at the end of a straight could be the difference.
      06-06-2016, 08:03 AM   #235
longress
longress's Avatar
Drives: 2007 Z4M Coupe
I'm dusting off this two year old thread to see if anyone found the limp mode solution.
I had this same issue and it got my attention as I can see a crash resulting from this. Gmd2003 my car is NOT FI and you've described what has happened to me to a T.
I too thought it was heat or possibly fuel related but I think it's vacuum that's part of the problem (or should I say a lack of vacuum). My car had seen several hard track days without issue but it wasn't until this last track day that I started to heel toe shift that this issue began to occur. My point is that between high engine loads, to heavy braking (with HT downshift), and then back to wide open throttle there's very little vacuum available.
Anyone ever figure out a solution for this?
      06-06-2016, 12:03 PM   #236
gmd2003
gmd2003's Avatar
356
My issue was FI related and was due to undersized injectors .
George
