      08-20-2013, 11:26 PM   #199
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
Originally Posted by Sal@Evolve View Post
Would also like to make something very clear to readers.
WOOTS (Adam) is paying for this airbox. It's not far off full price less the shiny finish.
What we do not do is give away parts for free even if the car is given in. While this may not sound fair to some we have learnt from experience that unless someone pays for something they do not fully appreciate it. They also do not properly asses it and almost feel obliged to say only positive things.
It is very important to us that a true picture is painted of what the product does and this method we have seen ensures this happens.
If there is a complaint or something which is not right we want it posted in the open.
Transparency is key here.
The tuning, additional hardware and evolve-R are not something we are charging for. This is the gift.
Can I have a free airbox if I promise to only say negative things about it?
      08-21-2013, 04:58 AM   #200
Sales@Evolve
96
Drives: Slow
Originally Posted by sabbanick View Post
Whether this thought is rational or not, I have a hard time with the fact that these tune files you create are not car specific. My fear is that for instance just to make a point..... my car will be the THAT one car that although "feels right" running evolve's tune is silently being stressed in a way that is detrimental to its overall health especially when being stressed in a racing/on track environment.
General speaking....
How much variance to you expect to see car to car running an off the shelf tune?
Does aftermarket modifications add to the unpredictability of creating consistency in performance gains/ideal operating conditions from the tune you create from WOOT's car assuming it is in proper running condition to begin with?
Is there a benefit to remote tuning and if so is this a possibility you would offer to us North Americans?
Hi,
The tune files on all of the Z4M's in stock format are exactly the same. They all run the same and the only reason they all dyno differently is because of :
Temperature and therefore temperature compensation maps
Tyres on the dyno (yes they do make a difference)
Gear used
Fuel grade
Efficiency of spark plugs
Efficiency of other sensors
We have dyno tested hundreds of S54's on our own machine and the shape of the curves are almost identical on 99%.
The peak HP and torque figures can vary and this is down to how much ignition timing is being run on that particular test.
On cars with tunes the same variance applies.
Compensation is very aggressive on the MSS70 DME, far more aggressive than MSS54. As mentioned before in this thread and many others, there are multiple ignition target maps and they vary vastly. All depends on what ignition map the DME decides to run based upon it's logic. Easy way (but not so clever way) around this is to set all of the ignition maps to they are equal to each other :-)
As for the additional stress of the tune. Well, we don't run them lean. We don't use too much timing. We most certainly don't make them knock or even come close to that. We know this from thousands of miles of running them and logging the knock values. We have multiple race cars out there running our tunes and never once a problem.
Our tuning strategy is not aggressive and never has been.
After market parts can change things very much. Cheap headers with poor flowing merge collectors and incorrectly made deCAT pipes do cause issues and physical factors like these cannot be tuned out in some cases.
Incorrect setup of the cars also cannot be dialled out in a tune.
Blocked OEM CAT's cannot be dealt with.
There are multiple threads on m3forum.net where people have had problems and we spend as much time as necessary to fault find and make the cars run as they should. We have had cases of popular exhausts (not Italian) causing very high back pressure due to incorrect pipe diameters being used. We have seen headers with very much blocked CAT's. Poor headers.
You name it, we have experienced it and gone through hell and back with customers!
Then there is the discussion about the DME itself. This is mostly a target based DME. The ignition timing is not fixed and has huge variability. The AFR is fixed to a degree but that doesn't often tend to be a problem. VANOS is target based but has little compensation. So on and so on.
Custom tuning each individual car has never yielded much gain unless we change the strategy of the tuning.
We've had a few die hard guys come here and argue with us on custom tuning. We have put the tuning in their hands, explained how the DME works and then they immediately understand it is rather pointless in most cases.
What we say to everyone is this - make sure your sensors are all working. Make sure if you can your cam timing and valve clearances are where they should be. If you are going to invest thousands in tuning then at the very least make sure everything else is working as it should and DO NOT BUY cheaply made parts (irrespective of price) for these wonderful engines.
As a minimum I would say everyone should have new spark plugs, valve clearances and new pre CAT 02 sensors fitted before any type of tuning is done.
Adam's car is a 59,000 mile car and by no means a garage queen. This is a car that is used and enjoyed like it should be. Everything is in working order, no errors of any type, every sensor is doing what it should.
      08-21-2013, 02:18 PM   #201
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
Pretty excited for this! :excited: Can't wait for videos. Fly-bys, and inside the cab if I may make requests hahaha
Once the pricing comes out I'm sure I'll have a few more questions specific to my situation that I'll PM one of you guys about, to not clog up the thread.
      08-22-2013, 03:52 AM   #202
Woots
Woots's Avatar
Drives: Z4///M Roadster
Well I'm back in the uk
V excited for tomorrow!!
      08-22-2013, 05:20 AM   #203
Imran@Evolve
Imran@Evolve's Avatar
Drives: All of them
Videos made. Just sent them to my design guy for processing. :-)
      08-22-2013, 05:24 AM   #204
Woots
Woots's Avatar
Get chance to go on dyno this morning?
      08-22-2013, 06:35 AM   #205
Imran@Evolve
Drives: All of them
Was on dyno last night. Just collating the information and logs.
      08-22-2013, 07:30 AM   #206
Woots
Woots's Avatar
Fantastic!!
Quick question with regard to the raw carbon...on aircraft whenever we see bare carbon we have to refinish the damaged area before water ingress manifests and starts to delaminate the sheets....
How does raw carbon used in "my" airbox react to water due to driving in heavy rain or a quick sprinkle with a hose?
      08-22-2013, 08:07 AM   #207
Woots
Woots's Avatar
Oh I'll get into leagrave station at 1044 tomorrow morning guys, just so u guys can pick me up
      08-22-2013, 01:44 PM   #208
Sales@Evolve
96
Drives: Slow
Fantastic!!
Your air box won't ever see water. Well.... unless you start washing it!
Dyno tested.
+30 hp, graph is totally different now and the car now is finally out of lowered conditions.
We had another Z4M in today, dyno tested it and it over laid your graph almost exactly, also running lowered conditions.
See you tomorrow!
      08-22-2013, 01:46 PM   #209
Woots
Woots's Avatar
Dyno tested.
See you tomorrow!
Awesome!!! Looking forward to it!
When do we get graphs
      08-22-2013, 01:50 PM   #210
Sales@Evolve
96
Drives: Slow
Already planned your test drive route in the morning.
We will be scaring some sheep and horses :-)
      08-22-2013, 01:51 PM   #211
Sales@Evolve
96
Drives: Slow
Want to put the graphs up with the data logs.
The Z4M owner that came today is a well known poster on the UK forums.
He was massively impressed also. I think he knows you also.
      08-22-2013, 01:59 PM   #212
Woots
Woots's Avatar
Okay cool, scaring sheep sounds ace!
Hmm not aware of anyone paying u guys a visit except Byron but ill ask around....
I think ppl are desperate for videos
      08-22-2013, 02:31 PM   #213
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
875
Drives: 635/1815, X3M Comp
      08-22-2013, 02:48 PM   #214
Woots
Woots's Avatar
30hp is v impressive!!
John (exdos) just said it was him who popped over, he is v v impressed!
      08-22-2013, 03:00 PM   #215
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
875
Is 30 hp yield on top of stock configuration of the Z4m?
No other mods, just the airbox with the accompanying tune?
      08-22-2013, 03:03 PM   #216
Woots
Woots's Avatar
I had an afe Intake on the car when I gave it In
Everything else is stock euro car
      08-22-2013, 04:58 PM   #217
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
30hp sounds incredible. Was expecting low 20s at best. With cams as well it would be a beast!
      08-22-2013, 06:11 PM   #218
Sales@Evolve
96
Drives: Slow
The gains are a little larger on this car as it was running on the lowered conditions maps as mentioned.
Seems as though many of them are looking at many dyno tests.
Had it been running the optimal map setting the gain would be as you say around low 20's.
      08-22-2013, 06:14 PM   #219
Sales@Evolve
96
Drives: Slow
John was laughing everytime the insane noise was made :-)
He already knows you will be over the moon!
      08-22-2013, 06:22 PM   #220
sabbanick
Drives: 08 SBM M coupe
Nice work evolve and WOOT'S!
How is the idle?
...I've seen two e46 m3 with csl boxes that have an idle that hunts otherwise run flawless. One was your box and software other was bimmerworld box and epic software.
