06-03-2009, 06:35 PM | #89 | |
Rep 1,269
Or you're wrong.
2019 Porsche 911 4 GTS
2016 BMW M3 2008 BMW Z4M coupe |
06-03-2009, 07:42 PM | #90 | |
Rep 259
06-03-2009, 08:25 PM | #91 | |
LSU Tiger Fan
Rep 20
I have found that going from park to reverse or drive, the car sorta hunkers down, this might be what you are noticing, especially when cold, and the idle rpms are a little higher. This is with an automatic transmission. |
06-03-2009, 10:00 PM | #92 | |
Rep 374
06-05-2009, 06:45 AM | #94 |
Rep 259
No update
No new update. The status is that when I press the button it goes into SD mode and you can really tell the difference, the gas pedal gets really sensitive and the steering appears to get stiffer BUT the LED on the button doesn't come on. The light for the "Sport" on the button can be varied with the intensity of the instrument cluster, but the LED indicator on the button doesn't come on. Looking at the WDS (wiring diagram), the signal for for LED comes from the Electronic Power Steering. It's looking for a LOW signal (ground) from the EPS and it's not there. I can ground the pin and the LED comes on. My thoughts at this point are: 1)It's going in Sport Mode (because I can feel it, see SD on the instrument cluster and see the tach change) 2)I'm not sure if the DME is talking to the EPS (because the feel of the steering is subjective - I "think" I feel a change, but I can't measure it. Others with the "real" sport button imply the same.) 3)btw I have an old version of Carsoft Software. When I run it I see the EGS (gearbox) change from the "A" Drive Program to the "S" Drive Program when I have the button on. SO, to make a long post short: I press the button, there's a big difference in the way the car responds acceleration wise, there may be a little difference in the way it handles, but no LED..... I hope more to come.... Chuck I
07-15-2009, 06:01 PM | #97 |
Rep 140
Update: I got the Sport Button delivered today and plugged it in. It does everything Chuck has described and the light on the button doesn't turn on when it's in Sport Mode. However, it displays SD on the instrument cluster and there is a noticeable change.
07-15-2009, 06:43 PM | #98 |
Rep 1,090
^ Thats really cool it works thats easy.
I broke my sport button holder so now mine is in position but i cant press it other wise it will fall down in to the console haha.
135i N54 manual
MR-S with a 2zz swap and mods Sold EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold |
07-15-2009, 11:24 PM | #100 |
instagram 997turbotom
286
Rep 7,377
i did that before. I crazy glued a piece of plastic under it to keep it from falling through
08-05-2009, 09:41 PM | #101 |
Rep 259
Sport Button Update
I just want to bring everyone up to date on the Sport Button mod. The last status was that I had the Sport Button installed using the existing cable harness. There was a major improvement in the throttle response and a more aggressive shifting pattern. I thought I noticed a small change in the steering presure. The main issue appeared to be that the LED did not come on when the button was pushed. In an effort to figure out the problem I procured CarSoft 6.5, BavarianTechnic Diagnostic Tool and the GT1. It's amazing what you can find out with a little leg work. Running diagnostics with the GT1, I am able to see the DME respond to the Sport Button. It actually shows the button toggle on and off. However, the EPS (electric power steering) says the Sport Button is always OFF. The DMS talks directly to the EPS via the D_CAN bus. At the same time the DMS talks to the transmission via the same D_CAN bus. Using Carsoft, I see the transmission respond the the Sport Button by changing from the A Drive program to the S Drive program. The DME talks the Instrument cluster via the same D_CAN bus and I see SD come up on the cluster. So the issues appears to be the EPS module not responding to the data from the DME. I used the GT1 to update the EPS module to the latest revision BUT... The real issue is the Vehicle Order (VO) number... The GT1 uses this VO# to select the updates. My VO# says I don't have Sport Mode. So this is where I am tonight. The GT1 will allow me to modify my VO# but I first have to decode it.... Once I figure out which numbers are for the Sport Mode, I should be able to change them in the VO# and do a new update that should allow that light to come on... OR I could still be spinning my wheels... btw, none of the Dealers will even talk to me... I'm sure they think I'm nuts... But for me, this is what's fun... I'll keep you posted...
btw if anyone has a list of the 3 digit vehicle order numbers, it sure would be helpful... Thanks, Chuck I |
08-06-2009, 06:27 AM | #102 |
Rep 274
Drives: 2010 128i Conv.
Thanks for the update! It seems you are on the path to discovery. BTW, Ron Stygar over on Bimmerfest may have the info you need. Best of luck.
08-06-2009, 01:29 PM | #103 |
Rep 2,128
08-06-2009, 09:03 PM | #105 |
Rep 259
There are 4 tabs (you can see one of them on the left side). What you have to do is put a thin blade between the plastic cover and the console (I did it on the right sided about where the tab is). Then rotate the blade (like real thin screwdriver(in thinkness, not width)) towards the passenger door. That will compress that cover in and it will pop up. Once one tab is free, the other 3 come right out... Chuck I
08-06-2009, 09:35 PM | #106 |
Rep 2
thank you thank you thank. that wire is seriously hard to find...especially in the dark and when you can only get a couple fingers in there. now all i have to do is order the button. when you drilled the hole for the button did you take it all apart or did you just hold back the wires and drilled into the console?
08-06-2009, 10:08 PM | #107 | |
Rep 259
08-11-2009, 08:42 AM | #108 |
Rep 44
I am thinking about relocating my sport button (over to the air bag light position) and in its place install start button. But I would like to have the sport button function reversed so that I need to push to disengage as I always drive with it and the DTC engaged. (now you need to push each time you start engine)
You would think that if I could wire a start button I could figure this out. I am lost May not be possible but I thought I would ask. You see what I drive.
ALWAYS GO TOPLESS
08-11-2009, 11:50 AM | #109 | |
Rep 259
08-26-2009, 07:00 AM | #110 |
Rep 374
just wanted to clarify with you. does this mean that the EPS is not adjusting when the button is pressed? I had thought you did a test and the results showed a significant change in steering response
