04-27-2009, 09:27 PM | #23 |
Rep 374
id say just get a good set of 6 1/2 components for the speakers by your feet. these will come with tweeters that you can put in the stock spot (by the window). run the door and headrest speakers off of the headunit. no need to get all new speakers especially if you are only going to run the feet speakers and subs off of the amp.
this is actually how i have mine setup and it's great. |
04-27-2009, 09:48 PM | #24 | |
Rep 231
04-28-2009, 02:26 AM | #25 |
Rep 145
Stock speakers are 10ohms.. i don't know where you are going to find a stable 10 ohm aftermarket amplifiers... most if not all are 4 ohm stable, then going to 2 or 8.. never seen 10
04-28-2009, 08:55 AM | #26 |
Rep 374
xg3 is right. youre not going to get much out of 10ohm speakers. i recommended getting just a good component set since it will probably end up being cheaper than what that car audio place recommended (replace all 10 speakers) and it will probably sound 10 times better.
05-23-2010, 01:01 PM | #27 | |
Rep 1
Please tell me what right location is the "remote on" I am having a hell of a time with this and looks like you solved it. Help please |
09-06-2011, 07:00 AM | #28 |
Rep 16
guys i'm about to do the following to my 2003 2.5i z4 with hifi system (10 speakers, amp at the trunk, without dsp):
1. change my hu to pioneer p99 2. keep using the stock amp and speakers (hifi system, no dsp) i've been back reading and some posts says i cannot use an aftermarket hu (gvbelgium, reach) while others have posted it worked for them (blacksapphirez4 and strokez) if i understand correctly, all i need are the following parts: 1. scosche z4 radio bezel kit link: http://www.scosche.com/car-audio/product/484 2. scosche bmw link: http://www.scosche.com/car-audio/product/691 3. antenna adapter link: http://www.scosche.com/car-audio/product/212 to intall, i just have to plug the antenna power to pin 13 to power on the stock amp correct? |
09-06-2011, 08:06 AM | #29 | |
Rep 1,530
Let me know how it works out for you and post up pics. I contemplated going this route but after reading this thread last week, I'm looking at the Dice II Mediabridge with iPod ashtray mount, DSP connector and Sirius. Henry
09-06-2011, 12:04 PM | #30 |
Rep 16
^ will do, hopefully this works.
the reason i'm doing this upgrade is to tune the existing amp and speakers using a very good HU plus has the functions i normally use, i.e.. iPhone control using HU or iPhone itself, iPhone charging, without taking out majority of the vehicle trim (that is brittle already and costly to replace plus tremendous rattle after reinstallation) |
09-07-2011, 06:57 PM | #31 |
Rep 1,530
Wow, I just googled that p99. You're getting the Pioneer DEX P99RS? That's pretty hot.
09-07-2011, 08:16 PM | #32 | |
Rep 16
i'm currently researching what other head unit i can put. |
06-01-2013, 08:25 AM | #33 |
Rep 16
well after more than a year, i finally found a headunit that i'm looking for, which is the pioneer 80prs, lots of tuning capabilities like the p99 but most importantly with its own power out to 4 channels that can be used to simple tapped onto the factory wiring while keeping the amp and speakers stock. head unit's other features aren't bad too (blutooth, iphone control)
got all the parts ready: be doing the install on monday, hope everything goes well |
06-03-2013, 02:22 AM | #34 |
Rep 16
Well, like what blacksapphireZ and strokeZ says, hifi/10 speaker without dsp system can work with an aftermarket head unit
now i can tune the Z4's stock amp and sound properly here are the pics: pioneer 80prs harness connected to the scosche harness and to the car's harness. scosche bezel and the pioneer 80prs kit with a new black a/c vent to match stock hifi non dsp amp my prying tool to remove the a/c center vents plus ofcourse a flat screw. pass thru for the usb cable for my iPhone |
11-24-2013, 05:07 AM | #35 | |
Rep 51
My new headunit has a remote lead wire which I can't figure it out where it goes to the car harness....? How did you wire the amp lead? More pics would be greatly appreciated |
