04-22-2023, 08:24 AM | #1 |
Rep 42
Wash and Ceramic Coating advice
Hello everyone,
Newbie here in the wash and paint protection game, so hopefully I don't get roasted too much. I have never cared too much for detail washing nor care enough for paint to not take the car to a regular car wash tunnel (I know swirls) But with this car, after a fresh touchless car wash I can't stop looking on how gorgeous the paint looks and I'm seriously considering Ceramic Coating. Now, as I said before I have always overlooked the appearance of the car and I have a couple of questions: - Are the microfiber towels really safe to dry the car? as absorbent as they can be they don't feel soft enough for me and make me think they can produce swirls (maybe I'm overthinking this) - I really don't see hand washing the car in my current situation due to not enough space plus winter months will make it really hard. What are the safe bets? I have been taking it to a self service touchless carwash and so far it seems ok, thinking on purchasing a pressure washer down the line to do it myself. any cons with this approach? - Mosquitos and bugs are starting to appear in the windshield and grill area, what's the best to facilitate wash them off without using anything abrasive? will ceramic coating help here? - I found a ceramic coating place with the following prices and menu, what are your thoughts on it? I really have no idea what am I looking at here. Thanks for the help! |
04-22-2023, 07:29 PM | #2 |
Rep 564
imo that kinda on cost is better off spent on ppf unless that a NO, something like Crystal Serum Light works and is pretty diy
quality count when buying towels with csl ceramic treatment, the self serve pressure wash with spot free rinse water and fwy air dry work for me to keep it looking decent most of the time. when i do touch the car i make sure to spend a lot of time with the pressure washer |
danielgmanm687.00 |
04-22-2023, 11:33 PM | #3 |
Rep 450
I would recommend finding a good mobile detailer and having them maintain the vehicle. Going down the rabbit hole of ceramic and right towels and methods/techniques is most likely not for you.
spammysammich1627.00 DocL1954.00 |
04-23-2023, 12:38 AM | #4 | |
Rep 58
Cos270608.50 |
04-23-2023, 01:45 AM | #5 |
///M driver
16791
Rep 506
Drives: 2022 M3 6-speed
My vote would be for ceramic coating and then use touchless auto car wash; I've had good luck with this approach the last few years. I do have a pressure washer for general use around the house and I use that on wheels.
I did Ceramic Pro on all three of my vehicles; expensive but worth it in my opinion. And they do glass as well; my experience is that the ceramic helps cut down on the summer bug splatters.
'22 G80 M3 6-sp Portimao Blue/Tartufo
04-24-2023, 12:17 AM | #7 | |
7456
Rep 10,259
FrankMstein1039.50 |
04-24-2023, 09:21 PM | #8 |
Rep 58
That $1500 could be split into 3 professional full paint corrections and full ceramic coating over 9+ years.
This is also considering the ppf never gets damaged. Big rock chip or gash in the ppf can't be touched up or buffed out like paint - you need to replace that whole section which can be expensive (easily a few hundred bucks). Same with chemical damage like bird droppings. That stuff will permanently ruin ppf if you let it sit for too long. Yes there are some self healing properties, but it's mostly for little scratches and swirls. And of course, the rest of the car will also be vulnerable. Sides can still be scratched up to door dings and road debris. Side skirts will especially be torn up, most notably if you have the gloss black trim and drive through dirt or gravel occasionally. Last edited by FunnyUsername; 04-24-2023 at 09:29 PM.. |
04-24-2023, 10:47 PM | #9 |
Rep 20
Ceramic is old school, graphene coating is the way to go. I have a mint 2000 XKR that a detailer friend convinced me to (pay him to) graphene coat a couple years ago, I don't drive it in rain or snow ever but a couple months ago I took my son to school and I got rained on. We were sitting in the line watching the rain stream down the car like it wasn't even touching it. Parked in the garage and by the time I got my chamois wet to dry it off the car was dry in the garage and floor was soaked. I was blown away. I also never have brake dust problems anymore, I can wipe wheels off with a cheap white towel and barely anything comes off.
It is expensive though and my friend usually only does graphene to lambo's or the high dollar classics around my area, but if you do it you may find your days of actually washing the car will be much more limited. I haven't washed the XKR once since I did it, just duster it and wipe droppings and bugs off with detailer spray after every drive. |
horseygrl22.50 |
04-24-2023, 11:19 PM | #10 | |
Rep 450
FrankMstein1039.50 Clark_Kent2241.00 |
04-25-2023, 07:18 AM | #11 | |
Rep 927
04-25-2023, 08:41 AM | #12 | |
Rep 836
I'm more a sand and respray the bumper once in awhile guy if it gets too bad. I care a lot more about function than it being pretty. However I wouldn't mind ceramic just so road spray tends to slide off without leaving gross water spots all the time. |
04-25-2023, 09:42 PM | #13 | ||
Rep 58
If you want hydrophobic qualities, I hear Opti-Coat Hyper Seal is very good and easy to apply. |
04-25-2023, 09:52 PM | #14 |
Rep 27
I use to wash my car/truck twice a week. I had xpel ceramic put on. By far the best money I've spent. You don't have to wash as often. People ask if my truck is brand new. As long as you don't go thru car washes and do your routine maintenance when washing it holds well. Car wash soaps can kill the ceramic over time and the towels also. You shouldn't have swirls in ceramic. Don't buff in a circle and you won't get any swirls.
04-27-2023, 07:25 AM | #15 | |
Rep 20
I emphasize my friend convinced me after I had much skepticism and it is intirely possible even he, with a detail enterprise, is not able to get the same stuff he used on my car anymore due to market inconsistency and products changing/going out of business. My point is I have ceramic coated my vehicles for years, but this XKR is only one that has had this result lasting years. |
04-27-2023, 08:21 AM | #16 | |
Rep 927
Not to start another topic here but I understand the initial need in the first few years for installers to be controlled via training/license for application, but not now. There is so much of this stuff out there now available to any consumer/installer that it is not viable. Some "pro only" products are no better given the same install. |
04-28-2023, 09:10 PM | #18 | |
Rep 674
