11-14-2022, 12:16 PM | #221 | |
Rep 29
Hi, where did you buy the silicone intake boot?
11-14-2022, 03:13 PM | #222 |
Rep 490
Probably Bimmerworld. It's an E46 M3 boot. The brake vacuum line is routed on the top of the CSL intake plenum. The stock intake requires a boot with the fitting for the vacuum line in it. Although you could also buy the E46 M3 vacuum line that mounts to the stock intake plenum in front of the boot.
11-15-2022, 02:29 AM | #223 |
Rep 956
That's some really good numbers with stock internals. I know the stepped headers add around 10-11 hp compared to the stock Euro one's, how much difference does the dry sump do? Do you have underdriven auxiliaries? No cams?
The setup in my E46 M3 made 319 whp on the dyno. OEM headers and exhaust (except the mufflers) but catless, "CSL" plenum with an open air filter and stand alone ECU (MAP instead of MAF).
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
11-15-2022, 07:41 AM | #224 | |
Rep 490
Stock cams. I’ve heard the dry sump vacuum (10 in/hg) frees up about 10 hp on an S54. I didn’t verify. |
11-15-2022, 05:10 PM | #225 |
Rep 956
Gotcha, that adds up compared to mine when you add headers/dry sump/pulleys.
04-06-2023, 08:40 PM | #228 | |
Rep 365
As you may know, Karbonius ended up making a carbon plenum similar to yours. However, a lot (all?) of the people who have installed it have found that the factory rubber elbow slips off the inlet to the plenum. Some people (including me) have wrapped the plenum inlet in tape to get a better grip, but this seems like a short-term solution at best. When you made yours, did you do anything special to stop this happening? |
86Zed964.50 |
04-09-2023, 07:50 PM | #229 | |
Rep 490
Without seeing how Karbonius did theirs, it’s hard for me to say what they did wrong if your elbow piece won’t stay on. “If you want something done right, do it yourself”…😎 |
04-10-2023, 01:31 AM | #230 | |
Rep 365
I'm not totally sure why the elbow slips off the Karbonius version. Perhaps the angle of the inlet isn't quite right? It was prototyped on an E46 which uses a different rubber elbow, so it could be something like that I suppose. In your experience with CF, would it be feasible to add a little raised lip on the outer edge of the inlet so that the hose clamp has something to hold against? Maybe you could use some kind of resin to build up the lip? Thanks for your advice - if I can't find a permanent solution I think I'll take the plenum off, which would be a shame. |
04-10-2023, 03:57 PM | #231 | |
Rep 490
04-10-2023, 05:46 PM | #232 | |
Rep 365
As far as I know, everyone is using the standard elbow, but that could be worth a try. Is part 4 on the diagram below the air shutoff valve I need? Is it a direct replacement (ie no other changes required)? https://www.realoem.com/bmw/enUS/showparts?id=BL92-EUR-12-2002-E46-BMW-M3&diagId=11_3019 Thanks again for your help! |
04-11-2023, 06:02 AM | #233 | |
Rep 490
Using the OEM plastic elbow without the rubber band gasket would not work. Hard plastic and epoxy would not grip at all. |
04-12-2023, 12:06 AM | #234 |
Rep 1,016
The e46 M3 silicone elbow does not fit. I tried.
I have also given the solution on the other thread but people don’t read/listen. Use floor anti-slip tape, done! |
04-12-2023, 08:45 PM | #235 | |
Rep 12,635
Garage List E86 Z4 M [10.00]
F15 X5 xDrive35i [9.17] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.53] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [8.93] |
04-13-2023, 07:41 AM | #236 |
Rep 490
Pretty difficult…
They don’t make a Pro-shield fitted for the E86, so you need to buy a generic piece and form it to the glass windshield before installing on the Lexan (so keep your glass windshield in your shop for forming replacement film. Too much heat to do it on Lexan). They provide instructions on how to heat form the shield, but with the compound curvature of our windshield I could not get it to cover the entire windshield and settled for a 16” band that covers my viewing area. Basically covers from below the 11” banner to a couple of inches up from the bottom of the glass. The good news is one 36” x 60” will make two shields… |
3002 tii2387.00 |
07-06-2024, 03:34 PM | #237 |
Rep 490
Cooling
Been over a year since an update. Time flies! Hasn't been much to report. Just been running the car without issue. A good problem, eh?
This past winter I decided it was time to replace the radiator as it's been in the car for 5 years and is no doubt packing up with sand. I decided to also move my oil cooler under the radiator for a better forced, or captive, air solution. Oil temps with an 8" x 11" Fluidyne cooler were a bit warm at 240 at inlet on a hot day. Just not enough airflow with it being in front of the PS tire. So, I found a circle track LS style radiator from PWR for only $600 and TIG welded some tabs for mounting. This radiator is shorter than stock but thicker at 2.25" vs 1.62" (57mm vs 41mm) so it has more volume. It will require more air flow to get through a thicker radiator, but airflow up front I have in spades with my vented hood. I then paired it with a CSF oil cooler (8201) that is similar in thickness for balanced airflow. Air will flow the path of least resistance, so you don't want a thick cooler stacked with a thin cooler. This install required custom brackets to lean the radiator more forward for @20 degree lean. And then brackets to hold the oil cooler. I also had a replacement front bumper fabricated for a cleaner unobstructed front end that will better allow the all important ducting. The CF tube feeds the cold air intake. Here I mocked up the front side air box. Working with card paper allows you to get the cuts and bends right where you want them. The back side mocked up with an Improved Racing inline thermostat for the oil. It progressively opens starting at 212f. And then in .025" aluminum. The backside ties into the hood vent. Three weekends on this new setup so far, and it's working perfectly! Water is staying @190f and oil @210 at inlet. And best of all, no leaks! |
07-06-2024, 03:45 PM | #238 |
Rep 490
Air filter
Another small update. I didn't like the air filter on the Eventuri intake. Clogs up too much with sand and just doesn't look to me like it can flow air at high rpm. So, I sourced a generic K&N cannister filter that has 3x the surface area and used a velocity stack for smooth flow. I then molded a bucket with carbon fiber and created a cold air "box" that's fed by the intake tube. Just tried this out the other weekend. Seems happier at high rpm, but the butt dyno is a deceptive mistress...
07-08-2024, 11:13 AM | #240 |
Get off my lawn
965
Rep 1,183
Drives: 6MT
Great fab work and inspiration to dig into some of my own projects. Any videos on track??
