02-01-2020, 08:14 PM | #23 |
Rep 12,559
Garage List F15 X5 xDrive35i [8.33]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.33] E82 135is (Retired) [9.46] E85 Z4 M (Retired) [9.33] E90 328i xDrive (Re ... [9.00] E86 Z4 3.0si (Retired) [9.18] |
Any update to this? I too am missing the exotic tone from the Powerloops and may go back to them lol.
02-01-2020, 08:25 PM | #24 |
I like Coffee & Z4s.
106
Rep 366
Drives: 2007 Z4MC
Living with the drone around 1-2k, it's not as terrible as before, I think due to not overtightening the hangers but this is just speculation. I'm enjoying the tone especially during 3-5k rpm pulls where the bass + treble notes are balanced. I think it could afford to be louder > 4k rpm. Sometimes I wish I had a valved exhaust that I could use to switch to something more like supersprint race. Only for high rpms and when i'm in the mood hah.
I kind of miss hearing my aFe intake. It was more audible when I had the remus. I can still hear it but only if I stomp on the throttle. But I don't think I'm going back to remus, the powerloops are more exciting. Last edited by filtercoffee; 02-01-2020 at 08:32 PM.. |
02-01-2020, 08:31 PM | #25 |
106
Rep 366
Drives: 2007 Z4MC
I think if I had to do it all over again I would've started with modding the oem mufflers e.g.
https://www.zpost.com/forums/showthread.php?t=1398616 Seems like you'd get some of the bass cancellation of the oem mufflers and more high-frequency scream at high RPM. The oem muffler design seems pretty high-flow. Perhaps even more so than powerloops since the powerloops have a couple of 180 degree turns. |
02-10-2020, 11:09 PM | #26 |
Rep 12,559
Just occurred to me but have you thought of installing a “reducer” similar to the RPi silencers? I think the tips on the Powerloops are 80mm but they’re not perfectly circular. On the shortest diameter it’s probably close to 70mm, so something like this may work:
http://www.everyexhaustpart.com/cart...expander.htmlQ You basically need to drill a small hole underneath and secure the reducer with a nut and bolt: https://www.raceprecision.com/product/RPI-RP-023.html |
02-10-2020, 11:16 PM | #27 |
106
Rep 366
Drives: 2007 Z4MC
Nah, I don't want to drill into those beautiful tips, plus getting the fit right seems like it'd be next to impossible due to the curvature of the inside of the tip. Btw, how does that even work to reduce the sound level?
The drone is only annoying at 2k rpm ish and then I actually think the powerloops could afford to be louder higher than that :P. Pretty satisfied with the exhaust setup right now. |
02-12-2020, 08:36 AM | #28 |
Rep 343
I feel like it's impossible to go loud without massive drone on this platform.
I have a roadster w/ catless headers and stromungs mufflers (everything else in exhaust is stock) and with the top closed it drones bad (very bassy). Top down all drone is gone. Wanna go louder so bad but top closed drone will be unbearable. Some sort of valved system/muffler may be the only option but I haven't seen any good examples of this. For reference to drone tolerance I run a non resonated Remus catback with valves open all the time in my f80 m3 and don't mind it |
02-13-2020, 06:19 PM | #29 | |
Rep 12,559
https://www.totalflowusa.com/totalfl...l-race-muffler |
02-13-2020, 06:51 PM | #30 | ||
Rep 1,543
02-14-2020, 08:27 AM | #31 | |||||
Rep 343
Thank you for the recommendation. I haven't read much about using a J pipe but after doing a quick search seems like it helps a lot of people. Will have to find an exhaust shop by me (fort lee nj) and try this. Do you know if you need a specific length to cancel out the right frequency? Seems like some people weld these on before the mufflers but not sure what the best application is on our platform or with a specific muffler like my stromungs lol Sorry for thread jacking!! |
02-14-2020, 11:20 AM | #32 | |
Rep 12,559
02-14-2020, 02:02 PM | #33 | |
106
Rep 366
Drives: 2007 Z4MC
In order for the reflected sound wave to be 1/2 a wavelength delayed, the J-pipe must be 1/4 of a wavelength long. The sound will travel to the end of the J-pipe and back, 1/4 + 1/4 = 1/2. To calculate the optimal length of the J-pipe: 1. Identify the frequency you want to cancel out, using a sound meter app. 2. Calculate the wavelength of that frequency. Wavelength = How far the sound wave propagates in one wave cycle = speed of sound divided by frequency. Note that the speed of sound is temperature dependent. 3. Build a J-Pipe 1/4 the wavelength. For example, to cancel out 90hz, assuming you want to cancel it when the exhaust is hot (I don't know, 500 F?), the speed of sound is 460 m/s (calculator), the wavelength is 460/90 = 5.1 meters, a quarter wave is 1.25 meters! however, the air in the J-pipe may actually be cooler that the exhaust gas since exhaust gas doesn't flow through it. If we use 100 F, the speed of sound is 353.4 m/s, a quarter-wave is 1 meter, which is still a very long J-pipe. I suspect the J-pipe in the muffler above goes deep into the muffler and maybe does a bend. It's also possible that the muffler itself does a better job of cancelling low-frequencies than the stromung due to a different internal design. It's also possible that you don't need to get the optimal length in order to reduce the drone sufficiently. Ultimately trial and error is a simple and guaranteed way to get to the results you want. Depending on how much time and money you want to spend, you might be better off modding the OEM muffler because you'd get the good low-frequency cancellation it provides. |
02-14-2020, 02:53 PM | #34 | |||
Rep 1,543
filtercoffee106.00 |
02-14-2020, 03:16 PM | #35 |
106
Rep 366
Drives: 2007 Z4MC
Video + sound please!!!
02-15-2020, 04:39 PM | #36 |
Rep 12,559
Ended up rebuying Powerloops lol. Now we can do this comparison in person lol.
02-17-2020, 08:11 AM | #37 | ||
Rep 343
