      01-16-2020, 12:56 PM   #1
SDMCoupe
Drives: 2007 BMW Z4M Coupe - Imola Red
Z4M calipers -> M3 E46
Can someone confirm if I can pull the OEM calipers from a Z4M and install them on a E46 M3 (2001 w/ non zcp/csl brakes)?
At the same time I'd be swapping out the rotors to CSL ones on the M3.
Thanks
      01-17-2020, 09:59 AM   #2
Azeka1
Track Junkie
Azeka1's Avatar
Albania
232
Drives: E86 M Coupe
Thanks
Yes, same calipers and carriers. Just remember that the rear brake lines are different lengths.
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | SS Headers | Rouge Exhaust| APEX ARC-8 | APR Aero | Sparco Seats/Belts | Weichers Cage | Solid Motor/Trans/Shifter/SubFrame | Poly Bushings | Race Camber Plates/Arms | CSF Rad/Oil | BW Brake Ducts | Braille Battery | AC/EGR Delete | 3,100lbs
1991 SW20 MR2 Turbo | Widebody | 400WHP/355TRQ | 2017 Audi Q7 | 2010 VW CC 2.0T
Gone: 2014 Audi A6 | 2011 G37 S Coupe 6MT | 2004 G35 Coupe
      01-17-2020, 10:43 AM   #3
Terraphantm
Drives: E46 M3 Coupe
Front calipers are the same. Carriers are the same as the ZCP/CSL (i.e sized for the 345mm rotors). To use non-CSL/ZCP rotors, you need to retain the stock M3 carriers.
Rear calipers and carriers are different (pistons are 46mm instead of 42mm). They will fit the M3, but would move the brake bias significantly rearward (and thus would not be recommended without the front 345mm rotors)
      01-17-2020, 12:02 PM   #4
SDMCoupe
So for the rear brake lines I can reuse the existing M3 lines or transfer the rear lines from the Z4M to the M3 (or neither option)?
thanks
      01-17-2020, 12:37 PM   #5
Azeka1
Track Junkie
Azeka1's Avatar
Albania
232
Drives: E86 M Coupe
The rear ZCP/CSL E46 M3 calipers also use the same 46mm piston as the Z4M. In short, the Z4M brake system is identical to a ZCP/CSL E46 M3.
I agree, if you're going to use the Z4M front calipers, be sure to pair them with the Z4M/ZCP/CSL rear calipers.
Yes, you can reuse the M3 rear brake lines.
      01-17-2020, 02:42 PM   #6
SDMCoupe
got it. thanks!
