10-18-2019, 09:09 AM | #1 |
Rep 25
GROM BT3 for bluetooth
Big props to GROM for making such a great product for bluetooth connectivity.
Originally I bought an aux bluetooth device that plugged into the factory aux port. However, I was unhappy with the sound quality. I tried 2 different aux bluetooth products and both did not sound as good as the radio. Then I came across GROM.... I chose the BT3 (bluetooth/handsfree) that installs in the trunk. The install was painless and only took about an hour. The majority of the time was spent taking out the battery (located in the trunk) and putting it back in. The GROM connects to the car via 2 connectors, no cutting or splicing needed. Once installed, just turned the key and worked perfectly. Best part, it works with the steering wheel controls. Also, my car has the factory bluetooth and when a call comes in, it automatically switches to the car's bluetooth. Can't reccomend the BT3 enough, its worth every penny. If you are wondering, I've got a 2007 Z4M roadster with factory nav and DSP. Turns out I did not need the DSP conversion kit that GROM offers, so that will be returned. So if you are looking for great bluetooth and sound. Get a GROM! https://gromaudio.com/store/all-bmwt.html YouTube link that shows how easy it is. |
10-19-2019, 09:52 PM | #2 |
Rep 145
are you only streaming music via bluetooth? have you tried streaming audio via the usb connection with an android phone? if so, does it work for you? For some reason I'm having issues with android phones.
04-26-2020, 01:12 AM | #4 |
And yet
32
Rep 67
I just installed this in my car last weekend. 100% agree most of the time is spent dealing with the battery - my positive connector took 3 people to get off because of the awkward angle and being (as I discovered during the install) an 8 year old battery that was beginning to leak, fusing itself with everything it touched. I replaced it during the upgrade and cleaned up accordingly.
My steering controls didn't work until I set bluetooth to use the grom for calls and media, not just media. I also have the factory bluetooth - your grom unit doesn't snag the phone calls from the factory unit? Mine seems keen on it, but I haven't installed the mic because I've no idea yet how I'd get it from the trunk into the cabin without pulling out the entire center console. |
05-05-2021, 06:37 AM | #5 |
Rep 35
GROM-BT3 Issues
Based on this thread and others, I bought the same unit, Grom-BT3. I have an '08 Z4 3.0 Si. The battery must be in a different location because I didn't have to contend with it at all. (Under the trunk floor.) My two plugs were stuffed behind the wall between the trunk and cabin.
With that said, I never got the unit to work properly. It would work anywhere from 47 sec to 2 minutes and then randomly switch to the radio. I would then have to click the Mode button 8 times to get the radio back to Track 1 selection to hear the BT again. Occasionally, the sound was extremely muffled. I contacted GROM and they sent me a "jumper" to install on the circuit board which did nothing but remove the ability to see the song selections on the radio. If anyone has a fix to this please let me know. |
06-10-2021, 09:32 AM | #7 |
Rep 35
I can confirm that the GROM does not work with my '08 Z4. It would work great for about 2min each time, then switch back to radio. It would also show BT mode while playing the radio. GROM gave me a full refund. I guess they new it was a problem with our cars.
06-10-2021, 09:34 AM | #8 |
Rep 35
I'm seriously considering a BlueBus unit, but someone just posted this in another Z4 forum. What is the difference? According to the poster, they both work with the steering wheel controls. https://www.ebay.com/itm/Audio-Bluet...UqAEGy1IXMZPcw
06-10-2021, 02:05 PM | #9 | |
Rep 21
What type of OEM radio did you have. I am assuming my 06' wouldn't be any different from your 08' but I see others on this forum praising the GROM |
06-11-2021, 11:46 AM | #10 | |
Rep 35
645 Radio control US 662 In-dash CD player 677 Premium hi-fi system 692 CD changer preparation |
06-17-2021, 10:59 AM | #12 | |
Rep 35
06-19-2021, 04:55 PM | #13 |
Rep 71
I'd definitely go for the bluebus over grom all day after buying the grom unit. I initially bought the grom unit because it had the feature to show what song is playing and wasn't keen on the cheap ebay unit. Unfortunately it bugged out my navigation screen and would prevent the use of the menu. My understanding is that not all radios are affected. In order to fix it you have install a little jumper on the circuit board but it removes the song title feature... Sometimes it bugs out and I have to reboot spotify in order to hear any music. Another annoying bug is that my prev/next song buttons don't always register. I have to press them multiple times on occasion which is annoying. The bluetooth sound is flawless though so no complaints there.
$150 Grom vs the $18 BT ebay module... definitely get the $18 module. Gets you the basic bluetooth audio and radio button integrations. For $200 more, the bluebus basically gets you more features, customizations, and overall much better refinement. It has bluetooth autoplay when you start the car which is actually something I wish the grom had. This guy reviews the bluebus and compares it to the grom (which would also be valid against the cheap ebay module) |
07-03-2021, 06:14 AM | #14 |
Rep 1
Have just installed the BT3 today in my 07 coupe. I’m impressed with the quality and connectivity seems flawless so far. The only minor complaint would be Siri is slightly muffled. I don’t know why since the music quality is perfect. I had tried one of the cheaper Bluetooth units and found it only connected as aux and wouldn’t provide steering wheel controls, it ended up in the garbage. I have business cd with no nav. You have to disconnect the 6 disc changer from the trunk (if you have one) otherwise the system gets confused. I would have bought BlueBus but I’m impatient (:
