Go Back   ZPOST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion
      04-02-2008, 06:51 PM   #1
Expired
Fanatic
Expired's Avatar
Drives: N/A
Key Fob Failure
After I got my BMW back from the dealership and drove it home, I got out of the car and pressed the lock button on the fob and it didn't respond.
I then tried unlock/trunk as well and nothing.. I grabbed my spare and tried it out, and it worked perfectly..
My question is, should I make the dealership replace the fob and how much is a new one?? (I plan on making them replace it)
-Nathan
People only know what you tell them.Only in ROFL Copter.
      04-02-2008, 06:51 PM   #2
e92phreak
e92phreak's Avatar
Drives: E92 335i TiAg/E46 323i TiAg
2007 E92 335i  [9.50]
2000 E46 323i  [0.00]
Maybe it lost it's charge. You have to once in awhile insert it in to maintain charge.
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo
      04-02-2008, 11:05 PM   #3
Expired
Fanatic
Expired's Avatar
Drives: N/A
It couldn't have lost it's charge, it's the main one I use.
Any other possibilities??
-Nathan
      04-02-2008, 11:11 PM   #4
The_Blob
The_Blob's Avatar
488
Drives: 2008 E92 335i
Man, I hate dealerships. They mess everything up.
      04-02-2008, 11:15 PM   #5
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
I'd guess your battery went bad then. The batteries are replaceable. A new key costs around $200-225 programmed.
      04-02-2008, 11:25 PM   #6
The_Blob
The_Blob's Avatar
488
I wouldn't be surprised if the dealer did a switch-a-roo with your battery or something. They might have even dropped it.
Stealerships.........
      04-02-2008, 11:57 PM   #7
PresaMat
PresaMat's Avatar
Drives: 67 GT500,69 Boss 429, 335i
Check your battery...
-Mat
Tuned E92 335, Riss Racing downpipes! And hopefully over 400RWHP!!
      04-03-2008, 01:55 AM   #8
Expired
Fanatic
Expired's Avatar
Drives: N/A
On top of that they had my car waxed without asking me and left several spots unbuffed, just waiting to be caked in.. -___- Looked/Looks terrible..
If it's the battery, then I guess I will replace it myself.. If somehow it is messed up, I will make them fix it/give me a new one.
EDIT: After reading some sites, I've learned that my battery should never need replacement and it should charge automatically..
-Nathan
      04-03-2008, 02:03 AM   #9
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
-Nathan
No, the battery can go bad and it does need to be replaced from time to time. It recharges when it's in the keyhole when you drive. The owner's manual even says you replace the battery from time to time.
      04-03-2008, 08:15 AM   #10
CnoteMD
Commander in Chief
CnoteMD's Avatar
Drives: 2008 BMW 535i
2008 M5  [0.00]
2006 330i  [0.00]
You may simply have a bad remote. It happened to me while I was away on a trip. I had to use the metal key to unlock my doors, but when when I would insert the keyfob into the slot, the car would start normally.
BMW replaced the remote portion of the keyfob under warranty, otherwise it would cost about $250. In order to get a new one, you have to verify your identity and apparently have the replacement sent from Germany.
2008 BMW 535i Space Gray, Black Leather, Dark Bamboo Trim| Sport Automatic with Paddles | Sport Package
2008 BMW M5 (gone, but not forgotten) Space Gray, Silverstone Merino Leather, Madeira Walnut Wood Trim | 7speed SMG | All options
Mods: Corsa Exhaust | RPI Ram Air Intake | H&R Sport Springs | Rogue Engineering 12mm spacers
      04-08-2008, 10:50 PM   #11
Expired
Fanatic
Expired's Avatar
Drives: N/A
Apparently it became 'un-synced' from the bmw..
Made a trip to the dealership, he fooled around with it in the ignition and door for a little while and it was as good as new.
-Nathan
      04-08-2008, 11:26 PM   #12
Davinhci
Davinhci's Avatar
Drives: 08 M3 E92 & 08 E70 X5 4.8
2008 M3  [0.00]
i say make them replace it
08 E92 AW M3 | HRE P40 19" | APE Air Filter | BMW Performance Grills | White Side Gills | CF Mirror Covers | BMW Performance Pedals | F1 Pinnacle Tint | V1 Hardwire | Dinan Performance Software | Gintani Exhaust | H&R Sports Springs | RPI Scoops | BMW CF Spoiler | Challenge Diffuser | Lux H8 V3 | LCI Tail Lights |
