New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      06-14-2018, 11:54 PM   #1
ray7792
Drives: '14 35is
diverter valve mod to atmosphere
Just found out the cheap mod to vent to atmosphere with the stock DV. Apparently some 335i and 135i guys do it.
Has anyone done this with the Z4? I understand that there shouldn't be any issues since there are no MAF sensors but primary MAP sensors.
How does it sound on a Z4 with the DCT? Any problems?
      07-26-2018, 03:25 PM   #2
Raged
Drives: 2009 E89 sDrive35i
Yeah it works fine. If you have the stock charge pipe, buy some new orings to seal the dv in.
      07-26-2018, 07:25 PM   #3
Cloudywolf
Drives: 2013 Z4 35i
What does this valve mod achieve?
___________________________
2013 BMW Z4 35i
2008 BMW 335i
2005 350Z Roadster
      07-27-2018, 04:08 PM   #4
NoQuarter
Drives: 2008 535xi / 2011 Z4 35Is
2018 BMW X2  [0.00]
2008 535xi  [0.00]
2011 Z4 35is  [0.00]
Sounds like a good way to spew oil mist all over the engine bay.
This is a 335 owner style mod. Don't stoop that low with the Z4!
      07-29-2018, 11:40 AM   #5
Raged
I have a catch can, so not much oil should go through. If there is alot of oil blow by, then your turbo seals are gone and you have bigger issues. I kept the stock hose and routed it down to the bottom anyway.
The sound it makes is worth it.
