10-07-2012, 04:39 PM | #1 |
Rep 880
Need help: OEM Navigation & Bluetooth retrofit
I sold my OEM Navigation system and Bluetooth from my 2007 M Coupe.
I will be installing everything into a 2006 Z4 3.0i and we are switching dashboard too. Is the Z4 pre wired like E46 or do I need to switch all the wiring harness from my car to the Z4? Thanks Marc |
10-16-2012, 03:29 PM | #2 |
Rep 518
did you were able to do the retrofit? I am also doing it to my car, what parts did you need to be able to do it?
2005 z4 2.5i/// Aero front bumper, m rear bumper,08 rear lights, custom quad exhaust, matte black front grill, OEM alarm, llumar security film,m wheels, HID lights, LED interior and trunk light,Ipod integration, stubby antenna,tein s-tech springsx
10-16-2012, 04:02 PM | #3 |
Rep 1,771
Drives: 2007 Z4M Coupe
pretty sure crfine did a similar thing. Look for his DIY thread
10-18-2012, 03:24 PM | #4 | |
Rep 880
Figure like 15hours of work if you are not too familiar with the z4 interior. The cockpit is so tight and there is a lot of trims to remove. Also the access in the trunk of a roadster is really tight. You will need those parts to do the NAV/Bluetooth retrofit: |
10-18-2012, 07:12 PM | #5 |
Rep 518
thanks!! bro I appreciate it!! let you know when I am done with my project!!
10-18-2012, 09:32 PM | #8 |
Rep 880
It is trust me, I would not do it again.
You basically need to remove all the interior of the car and if you don't want to remove all the carpet, you need to cut under the center console to have access to the wiring harness. |
10-19-2012, 01:01 PM | #9 |
Rep 95
Not really. I have retrofitted 2 of these.
Takes two hours to get everything in, and I took about 4 hours to cut the dash for the monitor. The cable needed is the one from the satnav computer to the screen at the front. On the Z4-forum I did a how-to at the time as I think I was the first one to ever do a retrofit in late 2005. No cutting required as the new partial harness just feeds under the carpet via the centre console to the dash. |
11-01-2012, 06:48 AM | #11 |
Rep 1
Hi Guys
Just a quick mostly on topic question. I am about to buy a Z4 without the GPS (therefore without the in dash pop-up) but am thinking I would like ot put in a screen at some point soon. Is it posible to get hold of the replacement dash with the GPS screen pop-up unit and retro-fit it? I really just want the motorised storage compartment and I'll put my own screen in there. Basically want to get a second hand or spare on of these (with the surrounding dash to prevent cutting the original dash and put it into this Does anyone know if it would it require cutting a hole into whatever is below the dash panel? Last edited by skywalkers; 11-01-2012 at 07:06 AM.. Reason: Add images |
11-01-2012, 08:11 AM | #12 |
Rep 95
Just cut the hole in the dash, that is what I did.
The monitor I bought new in Germany from a BMW dealer for just over $150, great price. **edit** You just updated the post before I replied Only the top has a cut, nowhere else. The mounting positions are already ready underneath the dash for the screen legs. Just put the screws in the existing holes to fix the screen. Cutting is not difficult, just measure it precisely. |
02-02-2013, 11:40 PM | #14 | |
Rep 178
