      07-21-2012, 10:01 AM   #89
3002 tii
3002 tii's Avatar
2387
^^ nice, I could've swore those were either 35 or high 30's like 37-38mm offsets.
Follow for latest mods
      07-21-2012, 11:03 AM   #90
Denton
Drives: '11.5 328xiT/6 - '99 M3/2/5
To be honest you might be right...38 sounds familiar. I can't believe I don't remember offset
Love the look of the RXII and since it's long discontinued was tough to find a set. Still battling TPMS since it was designed before these damned sensors.
      07-24-2012, 04:17 PM   #91
Twisted Six
Twisted Six's Avatar
Drives: Z4si-coupe
SSR GT-10
While I do love the BBS lace design, it just shows up on almost EVERY Z4 I see these days. Its almost the new STOCK look. Perhaps they should have come from BMW this way..
They are a engineering perfect design in my opinion and I LOVE your cars that run them.
So in an attempt to be different....I continued to look for a strong and light forged 3-piece wheel and bought these Japan made SSR GT-10's .
-19x9 et43 -245
-19x10 et24 -275
I'll need to slightly roll the fender arch in the rears to avoid max compression rubbing. Fronts are fine. These are the same offsets as I ran with my previous 19" wheels with the rears being 9.5" wide.
They also need a full restoration due to salt air in Japan and curb rash.
I have ordered CF -(blk. & Slvr.) center caps like I used on the Axxia Penta's to match my hood,trunk and side roundels.
What do you folks think ? Certainly not the common Z4 look....or German for that matter....but my roots do stem from the JDM world after all.
I'm thick, er.. thick-skinned .....so comment away,lol.
-(short vid)
http://s21.photobucket.com/albums/b2...t=IMG_0139.mp4
-(Stills)
      07-26-2012, 10:18 PM   #92
Denton
Just checked, 38mm. You were right!
I'm thinking a 10mm spacer in the rear, needs help.
      08-11-2012, 01:59 AM   #93
melbs
Drives: 2003 2.5i E85 Z4
thinking of replacing my style 107 18ers with the bmw performance 313 19ers.
will i have a problem with rubbing?
spec for the 313 19ers are 37F and 39R.
anybody with this setup?
i'm on eibach pro kit and bilstein sport on my 2003 z4 roadster
      08-30-2012, 09:29 AM   #94
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
for any interested... the X1 staggered setup is perfect for the non-///m z4's.
front: 8.0 et30
rear: 9.0 et41
stock tire widths
style #'s:
*18's-
322
323
355m
*19's-
225m
311
324
465
      09-04-2012, 09:09 PM   #95
jmos77
Drives: 2004 Z4, 20011 X5 5.0
Fit
I am looking at the following setup to buy but I don't think the offset will work. Can anyone confirm either way? Thanks
BRAND: VMR
STYLE: v710
DIAMETER
F: 19x8.5 et 25 wrapped in Yokohama S-Drives (235/35)
R: 19x9.5 et 22 wrapped in Yokohama S-Drives (245/35)
      09-04-2012, 10:09 PM   #96
3002 tii
3002 tii's Avatar
2387
BRAND: VMR
STYLE: v710
DIAMETER
LOL everything about this is wrong. First of all, a 235/35 and 245/35 don't match. You're rears are 1/3rd of an inch taller. Not to mention 255 or 265 would be more ideal for a 9.5 width.
Then your offsets are way too aggressive, assuming this is for a non-M Z4 (your info says you have a 335i). For an 8.5 front, you'll want an offset of high 30's to low 40's. For a 9.5" rear, you really don't want to go lower than offset of 35
      09-05-2012, 04:17 AM   #97
Jaguar_7777
Jaguar_7777's Avatar
Hong Kong
Drives: BMW Z4 3.0si Coupe E86 2007
Does having the M sport suspension option on a 3.0si change the setup to M hubs/rims etc?
I looked at some great
18 X 8 et35 225/40 R18
18 X 9 et 35 255/35 R18
today and the guy at the shop should fit fine, not rub or stick out the fender.
Thanks heaps for all the posts above, this has been an education!
      09-05-2012, 08:04 AM   #98
3002 tii
3002 tii's Avatar
2387
Nope, M sport suspension is firmer shocks and lower springs but hubs are the same. Those wheels/rims should fit nicely. Be sure to snap pics and upload here.
      09-05-2012, 08:54 AM   #99
jmos77
Thanks for the response. I now have an 04 Z4 and looking for a new setup as the car has the stock 17" which look anemic. I like the look of the M6 replicas. What would be the ideal size and fitment if I can find them? Thanks. I prefer to buy a set from a forum member but I am struggling with fitment so I may need to go new. I am also looking at a set of 336 189 Sport wheels and tires but I am not sure they fit and I cannot find any pictures of a Z4 with these wheels on them. Thanks again for the repsosne.
      09-07-2012, 11:30 AM   #100
Jaguar_7777
Hong Kong
Thats pretty out there, but that rear end looks ANGRY! Good job!
      09-12-2012, 08:01 AM   #101
3002 tii
3002 tii's Avatar
2387
Apex Arc8 17x9.5 et35 square, Hankook RS-3 255/40. Lowered approx 1" all around, camber plates and 5mm spacer used up front. This seems like the max you can push on our cars. NO rub during normal driving, rubbing front right liner on the track.
      09-12-2012, 08:33 AM   #102
v3.2mc
Not a New Member
v3.2mc's Avatar
i still can't believe you got those to fit.
you must drive in an alternate universe where fender liners magically vaporize when tires approach them because the unicorns that made them said it was ok and don't be sad rainbow house-sized mushroom goatboy faerie dust moon.
      09-12-2012, 09:12 AM   #103
3002 tii
3002 tii's Avatar
2387
Haha, thanks... being lowered and adding camber helps. W/o dialing in the front I'd most certainly rub although I the 5mm spacer up front effectively makes it 9.5" et30 lol. I have about neg 2.8 degrees but I'm fairly certain rears would work on stock setup. The fact that Tirerack says 10" rear et40 works, that's actually a third of an inch further out than what I have so there's plenty of room back there.
      09-12-2012, 02:07 PM   #104
kicker626
Drives: bmw
thanks for the info
      09-12-2012, 10:25 PM   #105
Jaguar_7777
Hong Kong
HAHAHAHAA
      09-24-2012, 02:33 AM   #106
Jaguar_7777
Hong Kong
So the 313 18inches are ordered. But i gotta wait 4-5 weeks ARGH!!
But, can anyone tell me what is printed or stamped on the 313 rims on the inside etc, so that i confirm that when i get them through the 3rd party company i had to order from that they are OEM legitimite.
Thanks heaps in a advance.
(Also ordered the BMW Performance brake kit. Should look great, and be somewhat
better stopping power too with the stainless steel brakelines i get as well).
      10-01-2012, 10:16 AM   #107
TSM330i
2006 330i, TSM, Black, manual, sport
TSM330i's Avatar
Drives: '17 C2, GTI, Z4 3.0si Racecar
This thread is great information!
We picked up a 2007 3.0 Si Coupe and want to get the largest R-comp we can on it.
I'm going to use my Enkei RPF1 (18x8.5 et40) square setup. Currently, I have BFG R1 in 245/40. They clear my e90 withouth any issues at all. Do you think we'll clear them on the Z4? With you running a 17x9.5 up front, I have a feeling it should work.
Do you think a 265/35 BFG R1 will clear?
Of course trimming fender liners won't be an issue since it'll be a race car.
2017 Porsche C2 - manual of course
2015 GTI S
2008 BMW Z4 3.0si Coupe - because racecar
      10-01-2012, 10:31 AM   #108
3002 tii
3002 tii's Avatar
2387
245 should be fine, but you'll most likely need a spacer up front for anything wider than a 245. 265's maybe pushing it because not only are you going wider but you're also going taller (as compared to a 255/35). To be honest, I don't think you'd benefit much from a 265 on a 8.5, 255 seems perfect imo.
Btw as your car progresses and you get to the point of installing a cage, let me know. I'm thinking about doing a half cage but chances are you'll beat me to it so it'd be good to know what's involved, who you went with, etc.
      10-01-2012, 11:59 AM   #109
TSM330i
TSM330i's Avatar
Thanks for the info! I figured 245s should work. With the lighter weight (about 2800lbs) and not too much HP, I think they'll be good, plus they're cheaper than 265s.
Unfortunately, BFG doesn't make a 255/35 R1, so they go from 245/40 to 265/35.
We're crossed who is going to be doing the cage right now. Either we have Chris at Bimmerworks do it slowly over several weeks or have a local shop do it in two days and just pay them. It's about $1,500 for a full - NASCAR style cage. I'm not sure how much a half cage will be, but would be excellent for harnesses to hold you in place and added safety.
2015 GTI S
      10-01-2012, 12:36 PM   #110
3002 tii
3002 tii's Avatar
2387
Yea, I wouldn't go the full cage route myself seeing how I only plan on doing DE's and I still plan the drive the car on weekends. But like I said if you go with someone local, I'd be really interested on the process, check out the end product, etc.
