04-17-2012, 04:11 PM | #1 |
Rep 2,737
show and go licence plate? anybody tried one?
hey guys i stumbled on this the other day and wondered if any of you have seen or heard of this, they have one where it fully retracts under the car then pops up when needed. and its fully powered from in the car.
do a search on you tube " show and go licence plate" and watch it on a mustang..... since we need one in chicago and i refuse to put it on my front end im thinking this may work!!! http://www.altecproducts.com/ |
04-17-2012, 06:56 PM | #3 |
MPOWERD
16
Rep 338
Drives: 2010 M6
I have the manual one that I retract for track events. Works good no issues.
2010 Dinan M6 Coupe--2006 Z4MC--1994 E36/M3 Track Prepped
BMWCCA #442445 YouTube Channel: http://www.youtube.com/user/Randy23185 |
04-18-2012, 10:24 AM | #5 |
Rep 452
These work well. For a little while. Like a few months or so. They are flimsy. The design does not match the exposure to the elements, and the control cables are nearly impossible to keep in the proper tension. As a result, they fail. Thought I had a bad one, ordered another, same experience.
04-18-2012, 10:45 AM | #6 |
Rep 12,570
I had one a while back, ended up lowering my clearance by an inch b/c the bracket was underneath the bumper. If you cut out a portion of the lower grills, that might work. I later got rid of it and got the Rho-plate...
If you're considering b/c you don't want to show a plate at all, I say just go no plate. If it's b/c you don't want to drill into your bumper, I say go Rho-plate since it attaches via tow hook. This show/go plate will still require some drilling, albeit underneath but still. |
04-18-2012, 11:01 AM | #7 |
40
Rep 1,481
I had been watching a few ebay auctions with the powered ones with plans to install just below the main face of the bumper-(thickest section).
It would require about 3/4" of trimming of the lower grid, but not very noticeable. This would keep it up higher from the elements a little better than down below. I'll document when I do it. No doubt additional strengthening and sealant might be required for a daily. |
