10-18-2012, 04:24 PM | #1 |
Rep 2,709
► APEX | ARC-8 Light Weight Track Wheels
Thanks for your interest in our ARC-8 wheels! This thread will no longer be updated, but the discussion continues on our combined Flow Formed wheel thread at: https://www.zpost.com/forums/showthr...5#post25582445
We hope to see you there!
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by ApexWheels; 12-19-2019 at 11:12 AM.. |
10-29-2013, 09:07 AM | #3 |
Rep 5,329
z4m fitment can you check the AP bbk on the 17" rim in 9" width with et30 please..
heres the template... http://www.apracing.com/Drawings/P16230.pdf
10-29-2013, 04:03 PM | #4 | ||
Rep 7,080
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey |
10-30-2013, 03:08 PM | #5 |
Rep 5,329
thankyou david.... if this can clear i will order :-) payday in 3 days!!
11-09-2013, 12:57 PM | #6 | |
Rep 18
I really like how concave these wheels are. I have kw v3's on the highest ride height possible without camber plates. Would this setup fit on my car without any rubbing? I believe the car in the photo is running 18x9.5 et35 and 18x10 et 25 with -2.5 camber without camber plates. My car is driven daily. Thanks |
11-11-2013, 06:54 PM | #7 | |
Rep 7,080
Some people go with a stretched tire of a 245/40/18 on the front, but we do not believe this would be a good solution as it would not provide the proper wheel protection due to the tire stretch. The best solution is still to change the KW V-shaped springs to the 6" linear race springs for proper fitment. The KW spring perch accepts a 60mm spring, thus you should look for a 6" 60mm spring from Swift, Hyperco, Eibach, or H&R. This will allow you to remove your V shaped spring and raise the lower spring perch higher to avoid the wheels and tires interfering.
11-12-2013, 11:55 PM | #8 | |
Rep 18
I'm not really interested in changing my springs. Would the 18x8.5 et 38 and 18x9.5 et22 fit with my standard v3s and without need for camber plates? How much camber would I need? Would they still look as concave? What tyres would you normally run on these rims? Thanks Kerstien |
11-13-2013, 04:53 PM | #9 | |
Rep 7,080
12-26-2013, 01:43 AM | #10 | |
tosser
32
Rep 988
Problem is, I have kw v3 which have the progressive spring. I'm dialed in at around -3.5 degrees front camber. I don't rub at all with 19x8.5 et32 with 245/35 tire. Do you know how my car would respond to a 275/35 front on 18x9.5 et35? I am not opposed to using spacers.
'07 MCoupe lots of mods |
12-27-2013, 04:04 PM | #11 | |
Rep 2,709
This fitment will also depend on the model and brand of the tire you plan on running as some tires run wider than others. You may need to play with spacer sizes and camber settings to find the ideal setup for you. Please let us know if you have any other fitment questions and we'd be happy to assist you.
12-27-2013, 11:01 PM | #12 |
Rep 175
Hey Dave, any pics of an alpine white m coupe with concave all around in satin black and hyper silver? I'm undecided on the two colors.
winnipegz4m46.50 |
01-02-2014, 07:22 PM | #13 |
Rep 2,709
I will take a look for you and send over a PM!
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by ApexWheels; 05-06-2014 at 04:16 PM.. |
04-24-2014, 03:32 PM | #15 |
Rookie
33
Rep 379
Hello David, I have both a Z4 and Z4MC, could you please elaborate which one of the wheels you have below are flat-faced or concave? Thank you!!!
17x8.5" ET20 - 16.50lbs - $259 17x8.5" ET40 - 17.20lbs - $249 - Z4 Non-M Fitment 17x9.0" ET30 - 16.50lbs - $264 - Z4M Fitment 17x9.0" ET42 - 17.20lbs - $259 - Z4 Non-M and Z4M Fitment 17x9.5" ET35 - 16.95lbs - $269 - Z4M Fitment 17x10" ET25 - 18.45lbs - $284 - Z4M Fitment 17x10.5" ET27 - 18.95lbs - $299 18x8.5" ET38 - 18.45lbs - $289 - Z4 Non-M and Z4M Fitment 18x8.5" ET45 - 18.20lbs - $289 18x9.0" ET42 - 18.65lbs - $299 - Z4 Non-M and Z4M Fitment 18x9.5" ET62 - 18.20lbs - $314 18x9.5" ET35 - 18.85lbs - $314 - Z4M Fitment 18x9.5" ET22 - 19.20lbs - $314 - Z4M Fitment 18x10" ET25 - 19.95lbs - $324 - Z4M Fitment 18x10.5" ET27 - 20.45lbs - $344
2003 Z4 2.5i
2013 FR-S 1990 911 C2 1983 Wife |
04-24-2014, 06:47 PM | #16 | |
Rep 7,080
04-24-2014, 08:02 PM | #17 |
Rookie
33
Rep 379
Thank you... So, no concave front fitments for non-M Z4 even in 17"?
Also, when you say they will "fit" below, are you assuming stock suspension? Neither of my cars have any heavy camber plates (yet) because I want to keep them very streetable... Thank you for your response and time. Flat Faced - 17x8.5" ET40 - 17.20lbs - $249 - Z4 Non-M Fitment Flat Faced - 17x9.0" ET42 - 17.20lbs - $259 - Z4 Non-M and Z4M Fitment Flat Faced - 18x8.5" ET38 - 18.45lbs - $289 - Z4 Non-M and Z4M Fitment Flat Faced - 18x8.5" ET45 - 18.20lbs - $289 Flat Faced - 18x9.0" ET42 - 18.65lbs - $299 - Z4 Non-M and Z4M Fitment Flat Faced - 18x9.5" ET62 - 18.20lbs - $314 Concave - 17x8.5" ET20 - 16.50lbs - $259 Concave - 17x9.0" ET30 - 16.50lbs - $264 - Z4M Fitment Concave - 17x9.5" ET35 - 16.95lbs - $269 - Z4M Fitment Concave - 17x10" ET25 - 18.45lbs - $284 - Z4M Fitment Concave - 17x10.5" ET27 - 18.95lbs - $299 Concave - 18x9.5" ET35 - 18.85lbs - $314 - Z4M Fitment Concave - 18x9.5" ET22 - 19.20lbs - $314 - Z4M Fitment Concave - 18x10" ET25 - 19.95lbs - $324 - Z4M Fitment Concave - 18x10.5" ET27 - 20.45lbs - $344
2003 Z4 2.5i
04-25-2014, 12:43 PM | #18 | |
Rep 7,080
04-29-2014, 05:56 PM | #19 |
Rep 7,080
Here's an example of a track setup for a Z4M, squared 18x9.5" ET35 Hyper Black ARC-8s with 265/35/18:
Feel free to contact us directly if you have any questions.
04-30-2014, 01:06 AM | #20 |
Rookie
33
Rep 379
This fitment looks good! Will it work on a Z4MC with stock suspension?
2003 Z4 2.5i
04-30-2014, 05:41 PM | #21 |
Rep 7,080
Unfortunately, this fitment would require camber plates to fit on the front of the car without rubbing onto the fender. The OEM suspension would not be compatible without camber plates.
05-05-2014, 07:54 PM | #22 |
Rep 39
