01-15-2012, 06:58 PM | #1 |
Rep 28
DIY Strut replacement??
Hey guys,
I need to replace the struts on the front end of my 03 Z4 and was wondering how hard it is to do them myself.. I do have access to a lift so getting the car off the ground isnt a problem. Im also wondering how the Bilstein struts compare to the stock sport suspension? Phil |
01-16-2012, 01:22 PM | #2 |
Rep 148
non MZ4 use E46 front struts, any E46 DIY should be close enough if not the same.
Here's one involving the E46 strut among other things http://forum.e46fanatics.com/showthr...ght=diy+struts |
01-16-2012, 01:28 PM | #3 |
6 of Diamonds (ret)
82
Rep 566
Not hard if you are mechanically inclined and have access to some good tools. There is a lot of similarity bet the E85 and E46 suspensions. If you dont get in a rush it should be pretty straightfwd. Only tricky part is spring replacement. Not to insult your intelligence but an alignment is needed once its all done.
Here are a couple DIY's http://forums.bimmerforums.com/forum....php?t=1096399 http://forum.e46fanatics.com/showthr...aliper+rebuilt Note on the 2nd DIY he takes his struts to a mechanic who has a hydrualic spring compresser. Not saying this is the only way but spring replacement is the big dog in the DIY. If you have not done them before, threaded rod spring compressors can be difficult to dangerous. I think getting access to a proffessional tool is the way to go. Do a little searching on this site and the E46fanatic.com site for the Bilsteins. Both have suspension sections in the forums. If you havent done it already you need to decide what you are after: 1. BUDGET(600 to 3500) 2. Ride (comfy to chiropracters best friend) 3. Use(DD, track or both) 4. Height(slammed or stock HT to mildly lowered)
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
01-16-2012, 03:08 PM | #5 |
Rep 28
Current mileage is around 80K, I managed to go up over a curb and jacked things up a bit so it needs replacing.
And my intelligence is not insulted, I realize Ill need to get the alignment done afterwards.. |
01-16-2012, 05:49 PM | #6 |
Rep 855
The front is actually more like an e36 and the rear is like an e46. It is an easy install. If you have a roadster the rears can be a little tricky ive heard.
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
01-16-2012, 07:41 PM | #7 |
Rep 148
Only for M variant, which uses E36 struts/knuckle and E46 LCAs up front. The non-M is almost straight up E46
01-16-2012, 09:51 PM | #9 |
Rep 148
u already shimmed? if not, most go for that first...another cheap (er) solution would be the RE fixed plates...but adjustable are not much more for the added benefit IMO.
01-17-2012, 09:31 PM | #10 | |
Rep 175
e30's but nothing about these cars. Been doing a lot of reading. I'm trying to figure out how I can fit the Apex arc-8 18x9.5 et 35 up front on my car with the least amount of suspension change. (Sorry op, don't want to get off your topic). |
01-17-2012, 09:33 PM | #11 |
Rep 148
Z4M's use the E36 front knuckle which can be shimmed. For people looking for cheap camber, this is typically the first route. I personally never did it, but you should be able to find more info searching. However, I don't think it will give you enough to fit a 9.5...plates are best option...what tire/size were you planning?
