08-23-2009, 06:01 PM | #1 |
Rep 137
Not Loving My Brakes
Hey guys...to cut a long story short.. my brakes suck after 4-5 brakes at 200+... anyways do u have any suggestions for braking system ? 6 pistons ? which ones ? cost ? or just change my pistons and leave the rest same ?
08-23-2009, 10:28 PM | #2 |
Imola Lover
26
Rep 749
You're going to need to define what you mean by "my brakes suck after..." Is your pedal "mushy"? Is the pedal firm but you're just not stopping? What?
08-24-2009, 09:23 AM | #3 |
Rep 137
i mean after 4-5 heavy braking on high speed or coming down from a mountain...they are unable to work good...they over heat i dont know...many ppl suggested me to change to ferodo ds 25000 and motul rbf 600...i hear some shacking and noise also from brakes
08-24-2009, 11:19 AM | #4 |
Imola Lover
26
Rep 749
Is the pedal mushy or is the pedal firm but the car just doesn't stop?
08-24-2009, 05:03 PM | #6 |
Imola Lover
26
Rep 749
You've likely boiled your brake fluid and warped your rotors. Most likely due to prolonged and improper braking by "riding the brakes". If you're going downhill you should be engine braking and/or getting on the brakes hard and then getting right back off of them.
08-24-2009, 07:09 PM | #8 | |
Rep 606
You need to do a brake fluid flush. I recommend Motul 600. It's worth the extra money. And if you're feeling a vibration under braking, you've either warped the rotors (doubtful, actually) or you have deposited brake pad material on the rotor. This happens when you get the brakes very hot and then you stand on the brakes while stopped. Either way, I'd change the rotors too.
08-29-2009, 09:24 AM | #9 |
///M'n it Up
17
Rep 344
The real answer here is, learn to down shift and not use your brakes when going down hill. Your car has a pretty good brake system. If you use it correctly, it will more than suffice for your needs.
