05-11-2022, 11:18 AM | #1 |
Rep 45
Z4M Oil Drain Plug
Hello,
Does anyone know if there is a magnetic drain plug for the Z4M engine oil. I'm only finding results for magnetic plugs for the differential. Also, when using the stock plug, do you replace it with each oil change? A 6mm hex seems like it would be prone to stripping. Thanks |
05-11-2022, 02:26 PM | #2 |
dances with roads
4763
Rep 4,101
I don't know of a magnetic drain plug but I have also not looked. I just replace the copper gasket when I change oil, not the plug itself. If you're stripping it you're using far too much torque; everything is aluminum including the threads themselves. Go easy.
bob'smerlot10.50 |
05-11-2022, 03:31 PM | #3 | |
Rep 783
Even though the filter comes with a new copper washer I generally don't replace it and it seals just fine, no leaks.
2008 E86 M coupe
05-11-2022, 05:50 PM | #4 |
Rep 3,004
It is important to follow the torque spec for many items on the Z4M.
It is my understanding the following is the torque spec for: Oil Pan Plug: 18 ft lbs Oil Filter Bolt: 24 ft lbs Overtightening is the most common mistake that causes failure(s). Strongly suggest using a torque wrench to ensure torque values are upheld.
Racerbruce
05-11-2022, 08:42 PM | #5 |
Rep 45
Thanks for the info! I haven’t changed the oil yet. I was just thinking ahead, so this is good info for me.
racerbruce3857.50 wdb4762.50 |
05-12-2022, 11:15 AM | #6 |
Rep 410
I also suggest getting a hex driver set. Makes it way easier and less likely to strip the hex portion (not the thread).
racerbruce3857.50 |
06-05-2022, 08:06 PM | #7 |
Rep 355
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
06-09-2022, 12:46 PM | #9 |
Rep 267
Drives: 2006 Z4 M Roadster
Folks - prompted by this threaded, I ordered and received one of the DrVanos magnetic plugs. I haven't installed it yet but thought I'd give you my initial impressions. First shipping was very fast. Order it on Monday, received it on Wed. Shipped from TX to Mid Atlantic (VA). Packaged well. Quality looks very good. Comes with a new aluminum crush washer.
Magnet is quite strong given the size. Probably Neodymium. I used a suitcase scale to measure its strength. The magnet can support 2.2lbs (1kg). So plenty strong to capture metal shavings in the oil. I'll be installing at my next oil change and will report more then and after the subsequent oil change.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic 2012 X5 M - Monte Carlo Blue Metallic 2017 X1 xDrive28i - Alpine White |
07-31-2022, 09:57 AM | #13 |
Rep 783
There is also this one from Mishimoto, a little more surface area and less expensive.
https://www.garagistic.com/collectio...-e24-e31-z3-z4
2008 E86 M coupe
tomjonesBT33177.00 |
