01-21-2022, 07:03 AM | #1 |
Rep 1
Z4/E85-Convertible Emergency Cable Repair
While fixing the convertible hydraulic pump, the mechanic broke the emergency release cable. The cable with a red ring at the end tip is used to open the convertible top manually when the hydraulic pump fails to work.
I coached the mechanic to get the hydraulic pump replaced by removing the soft top compartment floor inside the trunk. There are many tutorials to get the pump fixed or how to open manually but none on how to repair the emergency release cable. Your help will be greatly appreciated. diamondiva |
01-21-2022, 09:24 AM | #2 | |
Rep 510
Drives: 2007 E85 Z4 / 2013 E93 M3
My question is, why the fuck are you on the forums looking things up for a MECHANIC?!?!? This sounds like a mechanic problem….what shit tier place did you take your car to get serviced?!?! -Duke |
