05-25-2016, 03:05 PM | #1 |
Rep 126
Audio Aux cable doesn't work
Does anyone know why my Aux cable isn't being read by my radio unit?
I plugged it in to the far right corner where it says to plug in and it fits. But my radio isn't giving me an AUX option on Mode. Please help I'm tired of using an Fm transmitter to play my music |
05-25-2016, 04:31 PM | #4 |
More of this than that!
30
Rep 817
Some cables are wired wrong...and you need to 're-wire' into the current harness.
Check out this thread to read up on it. http://www.z4-forum.com/forum/viewtopic.php?t=79054 and this one http://www.bimmerfest.com/forums/sho...46&postcount=2
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector |
05-25-2016, 06:10 PM | #6 |
Rep 126
I purchased a cable from eBay. It has a red, white, & yellow wire in a clip. I removed them and placed them in the OEM clip (bottom right under fuse) like the diagram shows next to the last two brown wires at the end top/bottom.
I put the white and yellow wires in top center and red on bottom 4th spot down. Under yellow. Still nothing is working. Frustrated in Pasadena �� |
05-25-2016, 06:15 PM | #7 |
Rep 126
05-25-2016, 07:09 PM | #8 |
639
Rep 3,124
Looks and sounds a little suspicious.
At least you're only out $7. I would recommend the stock cable. The stock cable has a nodule in the middle of it with some mystery bits that may be needed for it to be recognized. Here's an interesting thread.
05-26-2016, 12:14 AM | #9 |
Rep 46
Had the same issue, and read somewhere here on the forum that z4 needed a different cable that had a resistor in it. Ended up just getting an original part, which worked as expected out of the box. Thread linked by StickMon appears to suggest the same...
05-26-2016, 10:55 AM | #10 |
Rep 126
Thanks. Ya, I plan on getting my money back for a part that knowingly doesn't work from the seller.
I'll just have to save for the OEM part that costs $115.00 at a dealer. Thanks everyone for you help!! Very appreciated |
05-26-2016, 05:51 PM | #11 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
https://www.ecstuning.com/Search/Sit..._174/ES194789/ Salty
05-27-2016, 02:47 AM | #12 |
Rep 126
https://www.ecstuning.com/Search/Sit..._Kit/ES194846/
This one Salty? I have Bluetooth in my car. No Nav. I'm guessing I'll have to place this in the Bluetooth plug in the back (far bottom right) |
05-27-2016, 03:17 AM | #13 |
Rep 126
I ended up buying this one on Amazon. It's from BMW/Mini of San Fransisco.
Part # 82 11 0 149 390 http://www.amazon.com/BMW-Genuine-Au...M+aux+cable+z4 Crossing my fingers it's going to work. Haha |
05-27-2016, 08:06 AM | #14 |
Rep 623
Have you tried using it with several devices. I know that most new Samsungs do not play through the AUX port due to some type of impedance. I would try with an older iPod or anything older with a 3.5mm output.
Steve |
05-28-2016, 04:06 AM | #15 |
Rep 46
Hope the amazon cable works!!! It does say only that it fits 5-series, X5-s and X3-s... In any case, the one I got is https://www.ecstuning.com/ES194789/. Pricey, but definitely works, and still cheaper than from the dealer.
05-28-2016, 06:20 PM | #16 | |
Rep 126
It is a dealer part and same stock number as needed for my Car model. It is from BMW/MINI of San Fransisco |
06-02-2016, 01:24 AM | #17 |
Rep 126
My ordered BMW OEM Aux Cable for $38.00 I ordered from Amazon WORKS!!!!!!! It really works!!!
Plug and play!!!!! I also have Bluetooth and I had to connect the two brown wires in the same plug into radio. Everything works perfectly!!! Thanks Everyone!! |
