11-25-2018, 12:09 AM | #111 |
your average JAMF
3191
Rep 4,115
Mine was 10/07 build date and also still going strong. Replaced it today with a Duracell H6 AGM from Batteries+Bulbs, full 4-year replacement warranty.
Interestingly, the battery says "Made in Germany" on it. East Penn is allegedly the OEM for Duracell, and the ones that Sams Club shows all say "Made in USA" on them, but this one is apparently supplied by somebody else. All I care about is the 4-year full replacement warranty, that's some solid peace of mind, especially here in Arizona, where batteries go to die.
'21 M2 Comp
'19 Golf R |
Finnegan707.00 |
12-01-2018, 11:07 AM | #112 |
Rep 196
Had to replace me battery after 9 years. Amazon has an ACDelco AGM 48/h6 battery for 168.08 but with a 20% off coupon. Best price I could find and includes 2 day shipping with my prime membership.
12-01-2018, 12:55 PM | #113 |
your average JAMF
3191
Rep 4,115
I put that battery in my (former) ZHP and it died after less than 2 years. Local ACDelco dealer refused to warranty it, claiming it checked out "ok", but it was clearly unable to hold a charge. Hopefully you have better luck.
'21 M2 Comp
'19 Golf R |
12-10-2018, 02:43 PM | #114 |
707
I just fixed the sharing options for the linked spreadsheet in the original post. If you click the link you'll be able to add/update. Thanks for keeping this up to date!
03-17-2019, 05:46 PM | #115 |
Rep 2,882
My Duralast H6 AGM isn't holding a charge anymore after 4.5 years. The car had always felt weak starting since day 1 - you know, the feeling that the starter is strained? But it always turned over, just not as quickly as my X5. It gave me a scare on a few cold mornings. Decided to put in an Bosch H7 AGM today since Pep Boys is running a 25% off until the end of the month. WOW - the starter seemed so energized - No more slow, belaboring turning over! I am more than happy to sacrifice a bit of weight gain for the reassurance that it won't die on me on a cold day.
01-08-2021, 10:30 AM | #117 |
Rep 431
Braille #15 battery with Macht Schnell e92 carrier. Saves significant weight but needs a tender (or disconnect) for long durations of down time. Otherwise, cranks and handles the car's electronics with no issues.
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo |
3GFX722.50 |
01-19-2021, 07:12 PM | #118 |
Rep 99
Drives: 2008 M Coupe
No personal experience with this product, and it's definitely not cheap, but...
https://en.liteblox.de/ 4.4lbs, smartphone integration, integrated kill-switch, anti-theft. I used their configurator for the M Coupe, and my result was this... https://en.liteblox.de/shop/liteblox...redirect=en-GB 1.248,00 € |
3GFX722.50 |
01-23-2021, 04:07 PM | #119 |
Rep 162
Drives: 2008 Z4 3.0si Coupe
I've done a lot of work on my car but this was the first time I swapped a battery, so forgive me if this is a silly question...
I installed a new battery recently (Duralast Platinum H6-AGM). Does it need to be connected to the battery vent tube?
2008 Z4 3.0si Coupe
01-23-2021, 07:35 PM | #120 |
Rep 2,882
Yes
01-23-2021, 09:10 PM | #121 |
Rep 162
2008 Z4 3.0si Coupe
04-16-2021, 06:06 PM | #122 |
Rep 335
Anyone else install an Odyssey battery? I ordered this one back in November of last year. This week, my engine barely turns over and struggles to start. I checked the battery voltage and the reading at rest was 7.5V-9.7V. With engine running it jumps up to 14.7V. I have been using a CTEK battery charger to keep the voltage up but if I don't plug it in every night, it'll get very low again and I'm afraid it will strand me. Even if I unplug the battery for a couple hours, the voltage will drop to 11V and the car is not even locked.
I brought the car to a BMW specialist to check for a parasitic draw and everything checked out fine. They did say however, that the Z4 requires a 90 amp hour battery and this one is only 80? I couldn't find the stat on that, is that true? Working on an exchange/warranty return but I'm baffled. Odyssey are supposedly good batteries, and I ordered the H7 - the bigger battery. |
06-05-2021, 09:23 AM | #123 | |
Rep 2,882
3GFX722.50 |
08-03-2021, 01:40 PM | #124 | |
Rep 65
Drives: 07 Z4M Coupe
My O'Reilly Super Start Platinum - AGM Battery (Part #48PLT) failed at 3 years and 1 month (3 year warranty). |
08-04-2021, 09:51 AM | #125 | |
Rep 2,882
I had various batteries over the years and had come to the conclusion that they're all basically the same. Some examples that I could remember (you can tell I'm an old fart with the list):
03-16-2022, 10:04 AM | #126 |
Rep 912
So in the end I just went the Canadian Tire Motomaster replacement (Lead Acid).
In 2016 it was the Motomaster Eliminator and now in 2022 the equivalent is the Motomaster OEPlus. They rebranded the batteries and the Eliminator is now the AGM version. The Lead acid I got from them last time lasted ALMOST 6 years (2 years beyond warranty). So for $150 I just went with the same battery. The AGM was negligible weight savings and only a 1 year longer warranty for an extra $100. Which wasn't worth it imho. FOR THOSE LOOKING FOR THE INFO 2003 BMW Z4 3.0i battery is Group 48 I looked at other options like Braille and Antigravity (and many others) the weight benefits for price weren't worth it. My previous goals were to be a dedicated track car but that's no longer my goal. So I just couldn't justify that money where I could use it somewhere else. In summary when looking at Lead Acid or AGM they were about 45-55lbs depending. Ranging from $150 - 500 Canadian. The lightweight batteries being $450-$1500 Canadian. 40lbs of battery weight savings = $700-900 more than a run of the mill Canadian Tire battery. The mathematics worked out to roughly $20/lb.....there are some slightly cheaper options but don't have the Amp hours and I need that to run the accessories (ie cooling fan, water to air pump etc for the supercharger). $20 per pound is pretty good though compared to some other research I did quickly for comparison sake: 2020 M2 CS - 3517lbs $87,495USD 2020 M2 - 3600 lbs $59,895USD $332.53/lb 2022 M5 CS - 4089lbs $143,995USD 2021 M5 - 4345lbs $113,095USD $120.70/lb When you compare price $/lb compared to what BMW's charging it all seems reasonable 🤣😅🤣 |
Tags |
battery |
