      07-21-2015, 01:39 PM   #111
-c-
-c-'s Avatar
Drives: bmw
Originally Posted by seventy5
So i did the swap today and after the install all the warning codes were showing on the dash. Is this normal? P.S I haven't got a ECU flash yet. Thanks!
No you should not have any codes. After install car drove just fine.
Their may be a miss somewhere, vacuum leak or something.
Might want to get that looked at.
      07-21-2015, 01:40 PM   #112
-c-
-c-'s Avatar
Drives: bmw
Originally Posted by DeutschRennfahrer
Originally Posted by -c- View Post
Oh no! I didn't realize the pics disappeared !!!
I'll work on re-editing the post this weekend if I get some time.
Thanks for letting me know the pics died.
Hey -C-, any chance you could throw those pics up again? It would be super helpful.
Hey I'm so sorry, with the new baby I'm having a heck of a time finding time. But will give it a try this weekend I promise.
They shouldn't have disappeared but I'll give it a look.
      09-14-2015, 11:25 PM   #113
Forbes
Daily driver/Weekend mechanic
Forbes's Avatar
Drives: '06 Z4 3.0i Roadster
2006 Z4 3.0i  [6.00]
2014 BMW 328i  [0.00]
I was able to compare the original 3-stage conversion tune with Active Auto's current tune. I prefer the current tune. After the ECU rewrite, I had 3 DTC codes (P2A87, P2E83, P2AD0) . I'm not sure what they mean, but after clearing them they did not return.
BTW,
      09-17-2015, 12:56 PM   #114
mad_presley
Drives: E39 M5
Is this the correct intake manifold for this conversion http://www.ebay.co.uk/itm/2818027739...84.m1555.l2649
      09-17-2015, 04:20 PM   #115
-c-
-c-'s Avatar
Drives: bmw
Looks to be the one but I'd cross reference the part number with REAL OEM.com just to be sure. I think their was small differences between some models.
      10-22-2015, 09:28 PM   #116
DeutschRennfahrer
DeutschRennfahrer's Avatar
41
Drives: 2006 Z4 3.0i - Saphire Black
Hey -C-, your new baby should be practically grown up and out of the house by now, so maybe you will have some time to update those photos?
      10-22-2015, 11:01 PM   #117
-c-
-c-'s Avatar
Drives: bmw
Har har!
Well I found that the photos are still on photobucket I just need to redo some of the post to get them working again.
Most of my time is posting from the phone while I'm out, and not on the computer to be able to fix this.
My priorities have changed a bit and I will try and get them back up. But I can only get to it when I get to it. Sorry I can't be more help.
      10-27-2015, 03:30 AM   #118
Samaran
Drives: BMV 320
I also just called AA and set up my info and am going to pute down a deposit to secure and have an SI Z4 dyno'd and its mapping gone over to use as a base, then when i get their my car will be tuned to upgrade over the origanal so in theory may get better numbers, im planning a cruise with my wife in feburary so either i will be in miami Fl. in feburary or the begining of spring to have the work done, I know its a bit of a wait but it will be worth it to find out what we can squeez out of the 3.0I.
      11-08-2015, 05:19 PM   #119
DeutschRennfahrer
41
Found someone local who has a 3 stage intake manifold with less than 10k miles on it. He wants $700 for it. Is this a good deal? Seems a bit high.
      11-08-2015, 06:09 PM   #120
-c-
-c-'s Avatar
Drives: bmw
Extremely high! Probably why he still has it.
I got mine of car-part.com for around 200 or so.
I've seen them go as low as 150 on eBay.
Just checked car-part.com and they have a whole slew of them for around 250. You'll have to call the others as they don't show price and may be cheaper.
      11-10-2015, 11:24 AM   #121
DeutschRennfahrer
41
Good to know. I'm calling a few of them on car-part.com now. Were the two adjuster units on yours in good condition? Those can be expensive to replace.
      11-10-2015, 12:16 PM   #122
-c-
-c-'s Avatar
Drives: bmw
Yea it was complete and in perfect working order
      11-11-2015, 08:01 AM   #123
DeutschRennfahrer
41
Just ordered one for $225 that came with a one year warranty! Also have an AA certified shop in my area that will do the tune. Can't wait!
      11-11-2015, 08:14 PM   #124
-c-
-c-'s Avatar
Drives: bmw
Glad you weren't taken for a ride ! Told ya 700 was way to high.
Some people just figure they have gold! But the prices have gone up since this has become a thing recently.
      11-17-2015, 06:58 PM   #125
DeutschRennfahrer
41
Manifold just came in today and it looks good. Pulled out both DISA valves and they look clean. Flaps won't budge (that's good, right?) I did notice that there is some oil on the inside of the manifold--is this normal?
Also, what's the best process for swapping in the new gaskets? The ones in there now look fine and fit very snug, so it seems like swapping them could be difficult. Any tips?
Finally, where do I find the cables that are supposed to plug into the two DISA valves?
Thanks!
      11-18-2015, 11:12 AM   #126
-c-
-c-'s Avatar
Drives: bmw
Thanks!
Oil is normal, the cables should be located on the outer right side of the manifold. Easy to spot. The plugs just plug into a female plug holder
      11-19-2015, 01:32 PM   #127
DeutschRennfahrer
41
Just to be sure, I can still drive the car with the new manifold before I do the tune, right? Will the DISA valves know what to do?
      11-19-2015, 03:48 PM   #128
-c-
-c-'s Avatar
Drives: bmw
Yep and it drives fine. Had mine on for over a year while developing a tune before the tune ever went on the car. You should notice a slight boost.
We were able to transfer the SI factory tuning onto the I ECU and the engine worked great, but the problem was the automatic trans. If the car where a manual it would have worked great. Ended up giving the car to my mom when I bought the 135is before I ever finished the tune as it hit a dead end trans wise. But other tuners have since broke that barrier since this had become a popular modification.
      11-19-2015, 03:50 PM   #129
rjahl
rjahl's Avatar
1000
Drives: Z4 35is
2012 Z4 35is  [0.00]
Yes the car will run fine, just not optimized.
      11-19-2015, 07:59 PM   #130
rjahl
rjahl's Avatar
1000
Drives: Z4 35is
2012 Z4 35is  [0.00]
I managed to splice all of the SI code into my DME and the car runs great, no issues with the Auto trans. I could not get winfkp to flash the file but BDM worked fine. The process works for 325s as well
I am now working on a custom tune from the SI file. I have a lot more to learn so Its slow going. It's not like anyone has posted a how to tune your msv70 on the Internet.
      11-20-2015, 03:54 PM   #131
DeutschRennfahrer
41
Thanks guys. I am planning on doing the install this weekend, and I will try to capture the process in a video. I'll be using C's writeup and the help of a friend, so hopefully it will be a smooth install. If there's anything I should watch out for that one could overlook, let me know.
      11-20-2015, 04:48 PM   #132
-c-
-c-'s Avatar
Drives: bmw
Just be carful with those vent tubes! Their brittle as hell and snap easily !
